Old 01-30-2014, 02:56 PM
njsteve's Avatar
njsteve njsteve is offline
Both are autos with A/C.
The Following User Says Thank You to njsteve For This Useful Post:
  #4202
Old 01-30-2014, 03:24 PM
Firebird 2's Avatar
Firebird 2 Firebird 2 is offline
Default 73 Front Valance
As some of you may know I'm restoring Larry's red 73 SD - I have an ad in the "wanted" section for a correct fiberglass/plastic front valance...any help would be greatly appreciated!
J
  #4203
Old 01-30-2014, 04:02 PM
Originally Posted by RicksGTO View Post
Steve, was your friends car an auto or 4 speed? Just wondering if the transmission made the difference on '73 SD's like it did on some if the GTO's in regard to the resonators?
I wonder if maybe the SD TA got them as part of the TA package.
(Formula extra cost?)
  #4204
Old 01-30-2014, 04:51 PM
njsteve's Avatar
J
Ask for Polyethylene only (otherwise it's a reproduction) :-)
NJSteve (a.k.a. PolySteve)
  #4205
Old 01-30-2014, 05:24 PM
Larry Navarro's Avatar
John, keep us posted on the progress.
  #4206
Old 01-30-2014, 05:50 PM
transam1972 transam1972 is offline
Default poly valance
I know I will get this name wrong but a while back one sold, and he said he had another that needed work...I did not really want a damaged one..not saying that's bad...tough to find perfect poly .....try,ready?!...TELLYSHEVELLI
  #4207
Old 01-31-2014, 03:03 AM
REFORMULATED's Avatar
REFORMULATED REFORMULATED is offline
Default OEM in line resonators
Are the OEM in line resonators or should I say lead pipes on the cars that got them 2.25" or 2.5". Anyone repro them?
70 Formula 400
69 Grand Prix 428
70 Buick GS 455 Convertible
66 Oldsmobile Toronado
Always looking for more
  #4208
Old 01-31-2014, 08:56 AM
RicksGTO's Avatar
RicksGTO RicksGTO is offline
not sure on the size on the original systems. The Parts Place Inc. makes a repro system for the SD exhaust with resonators so he might have the resonators for sale separately.
'72 Formula 455HO TH400, Revere Silver, black deluxe
'74 Trans Am SD 4 speed, Admiralty Blue, blue deluxe
  #4209
Old 01-31-2014, 12:27 PM
63Longtop's Avatar
63Longtop 63Longtop is offline
Default Y8
A lot of the 1974 SD blocks were cast like yours.
1973 had a lot of the 72 cast dates, but still some 74 had them.
What is the EUN on it?
EUN Input Form
To see some others like yours:
EUN Search
Type 1974 in year and 490132 in block code.
EUN is 373423
The Following User Says Thank You to 63Longtop For This Useful Post:
  #4210
Old 01-31-2014, 04:06 PM
frank.g frank.g is offline
Hello everyone. Long time viewer, first time posting. 27 year owner of an unrestored, Brewster green SD. Re: resonators, another source is Gardener exhaust. They only sell complete exhaust systems, though. You should also know that the resonators are butt welded into the system, not clamped on. So, they are 2 1/2" inlet/outlet.
According to what I have learned over the years, Pontiac made up the initial run of the exhaust systems with the resonators that were used on the 73's, then decided the resonators did little for the cars, so left them out. The change over occurred near the end of the 73 model run. As far as I know, no '74's got the resonators, and the service replacement exhaust system for the 73 and 74 excluded the resonators.
  #4211
Old 01-31-2014, 04:13 PM
hada76's Avatar
hada76 hada76 is offline
welcome, good info...now post some pics!
___________________________________________
the more im around people, the more i like my dogs
The Following User Says Thank You to hada76 For This Useful Post:
  #4212
Old 01-31-2014, 04:41 PM
Rocky Rotella's Avatar
Rocky Rotella Rocky Rotella is offline
It makes you wonder if the resonators (or attenuators, as Pontiac called them) had something to do with taming the snarl of the intended 041-spec camshaft.
  #4213
Old 01-31-2014, 05:04 PM
njsteve's Avatar
Hey Frank! Did you get your differential seal done and back in yet? I haven't touched my car since I got back from the show in Chicago in November....I've been working on the truck, which runs great now....just in time for the wife's car to start breaking down.
  #4214
Old 01-31-2014, 05:05 PM
Rocky - as good of a theory as one can up with 40 years later. I know they had "problems" at the time with the EPA drive-by decibel test. I'm sure you know it was the reason why the hood inlet was riveted shut. The attenuators seem to do little on the "Y" cam. I have a friend who put a "K" profile cam into his SD - but he also put in a low restriction exhaust system. Snarls plenty - it would be interesting to know if the attenuators would affect it.
  #4215
Old 01-31-2014, 05:06 PM
njsteve's Avatar
go here:
http://forums.maxperformanceinc.com/...71844&page=203
  #4216
Old 01-31-2014, 05:14 PM
Hi, Steve. Rear is in, brakes are back in, half the exhaust system is in. Have to get the left exhaust manifold off, and that's where the project stalled. Been plowing snow ever since. LOL. Glad to hear the truck is living again. I followed it's saga from the wings. I had to laugh when I learned that it was fixed about a mile from my office.
Also, I got the plastic solder iron. Read the directions, looked it over, and set it aside until the spring. Gonna be leg ironed to my desk soon. Hope your wife's car is nothing serious. Gotta take care of those Hemi's. Can't believe you haven't found something to do on the SD for almost three months!
  #4217
Old 01-31-2014, 05:27 PM
njsteve's Avatar
After getting the diesel's head gaskets replaced at the dealer, I upgraded the exhaust system, air intake box, and replaced the remainder of any lines that could eventually rust. She runs a bit peppier now. Wife's 300 AWD needed front half shafts and wheel bearings...a week later the front driveshaft started rumbling. Hey, it does have 140,000 on it and has been relatively trouble free til now....
As for the SD, I do need to replace a couple of worm clamps that someone put on the rubber fuel pump lines running under the engine. I need to locate some original, factory spring clamps - red and green, 2 of each, I think?
  #4218
Old 01-31-2014, 05:40 PM
Steve - I can take a look at mine and tell you what's on it. I may not be able to tell color though. Z bard was sprayed everywhere back in 1973.
The Following User Says Thank You to frank.g For This Useful Post:
  #4219
Old 01-31-2014, 11:33 PM
Brewster's Avatar
Brewster Brewster is offline
From what I seen, read, heard all 73 built cars had resonators however 74 cars and all over the counter replacement sd exhaust system did not.
Steve, your exhaust system might have been replaced at one time or another. Whats the muffler date code?
  #4220
Old 02-01-2014, 09:00 AM
njsteve's Avatar
Never replaced. 1973 date codes. Not a bolt turned since August 1973 when Enrico loosened the chrome tips and adjusted the angles. (One tip still rubs the lower rear quarter on acceleration). Nothing's better than being able to pick up the phone and talk to an original owner with a photographic memory.
