Old 04-28-2024, 01:31 PM
PAUL K's Avatar
PAUL K PAUL K is offline
Default 1820 HP 505 CID pump gas engine
Scott Brown at Competition Components just finished up a 505 E-85 build using aftermarket RAV heads. Bore was 4.310 and used a 4.25 stroke. Heads were ported by a board member here (hopefully he chimes in) and the cam was just right for the application.... Torque was stout!
PONTIACPOWERTTF!!!
ID:	632763   Click image for larger version
ID:	632764   Click image for larger version
ID:	632765   Click image for larger version
Go fast, see Elvis!
The Following 6 Users Say Thank You to PAUL K For This Useful Post:
Old 04-28-2024, 02:19 PM
mgarblik mgarblik is offline
Those look like DCI heads from the small picture. Great power and results. Pontiac power!!!
Old 04-28-2024, 03:05 PM
Awesome results!
What vehicle will it be going in?
Old 04-28-2024, 05:28 PM
BILL BOWMAN1's Avatar
Awesome results!
by that ET estimate, a heavy car.
Old 04-28-2024, 05:45 PM
JSchmitz's Avatar
JSchmitz JSchmitz is offline
Amazing!
Old 04-28-2024, 05:57 PM
Drag Star Le Mans's Avatar
Video? Perfect for my rusty GTO how much? OK never mind
DragStarLeMans
The Following User Says Thank You to Drag Star Le Mans For This Useful Post:
Old 04-28-2024, 07:07 PM
i82much's Avatar
i82much i82much is offline
what's that funny-looking thing on top with the belt connected to it?
True!
Old 04-28-2024, 10:47 PM
PAUL K's Avatar
To answer some questions
Yes, they are DCI head castings
I believe the engine is going into a 68-72 Pro Street style A-body
I have a video of a power pull and the engine idling but can't figure out how to post them here..... I don't think we can post videos.
i82much...... Joe mama
Go fast, see Elvis!
Old 04-29-2024, 07:53 AM
Hope the car has a rather large fuel cell. Very clean well though out build.
Old 04-29-2024, 10:48 AM
Nice to see the 5 heads being used too. Dare to be different!! 👍🏼
Tom Pugh Tom Pugh is offline
so how do you hook up 1400 ft. lbs. tq.?
Old 04-30-2024, 08:07 PM
triathlonx13's Avatar
$ per HP ?
Old 05-01-2024, 09:51 AM
Now that is a freaking blower!
Old 05-01-2024, 11:35 AM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
Scott is top notch. I picked up just at 50 hp and 50 ft lbs using a hyd roller cam he spec'd for me over a larger solid lifter cam in my stock bottom end, 557 block 406. I would recommend him to anyone.
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
Old 05-02-2024, 08:56 AM
Slick's Avatar
Slick Slick is offline
It's a power sucking crankshaft snapper. Used to be pretty common until the turbo and centrifugal monsters culled most of the herd.
Old 05-03-2024, 10:37 AM
Jim Robertson's Avatar
Jim Robertson Jim Robertson is offline
Very nice results at a very mild boost number. Congrats to Scott and Don S. on a super cool build using some very special custom pieces.
Not sure how many on here remember or were at Norwalk a few years ago when DCI Don brought the first load of his RAV heads to the pits that year. The entire back of his SUV was full of V heads. …The heads on this blown hot rod are from that first load. IMHO excellent quality casting with accurate dimensions and machine work. Castings were easy to port and to finish for the application.
Street car???!!! Go to it!
Jim
www.raceV8s.com
1972 Trans Am drag car, 3300lbs, 468 ci, Iron D ports, 428 block, 9799103 crank, 9.48 @ 143mph, 6.0 @ 114mph in the 1/8th.
The Following 2 Users Say Thank You to Jim Robertson For This Useful Post:
Old 05-03-2024, 12:30 PM
J.C.you's Avatar
J.C.you J.C.you is offline
He gonna have turn scoop around driving in rain on street
1966 GTO dragcar
1966 GTO Ragtop
1969 Tempest ET clone street/strip
1969 GTO Judge RA lll, auto
1969 GTO limelight Conv. 4speed go and show (sold)
1970 GP SSJ
1972 GTO 455 HO, 4 speed, (build)
Old 05-03-2024, 05:35 PM
cgeise's Avatar
cgeise cgeise is offline
I call BS.
Old 05-03-2024, 05:58 PM
Very nice 1380-1440 ft-lb TQ. Wonder what TQ would be NA. 600ft-lb?
