Old 12-13-2013, 04:13 PM
SD73's Avatar
SD73 SD73 is offline
Okay. I think I'm finally making sense out of this. It seems like I've found a lot of varience in the length of that center tube ranging from in on average at 11.5 give or take 1/4 inch.
I think the most critical element is the last section of the cable that comes out of the end grommet by the gas pedal. I think this needs to be a fixed length and when it is that center tube section can be longer or shorter as I've seen in the 2 NOS examples and on a few of the vehicles that have been measured.
If any one else can confirm this measurement, I should be on my way.
Any other measurements are always welcome! And anyone with one to sell is even more welcome. But I think with this info we'll all be able to make our own out of a few more common junkyard finds if this pans out.
The Following User Says Thank You to SD73 For This Useful Post:
Old 12-15-2013, 07:42 PM
Pepi's Avatar
Pepi Pepi is offline
I measured my cable today between the grommets and I had 11.5"
1973 Formula 400 4 spd 04C build date Norwood assembly plant.
The Following User Says Thank You to Pepi For This Useful Post:
Old 12-15-2013, 07:51 PM
SD73's Avatar
Thank you, Pepi!
Old 12-26-2013, 04:03 PM
Don't know if this will help:
I would think the Firebirds had their own codes?
(plus 2 bbl and 4 bbl would be different also)
The Following 2 Users Say Thank You to johnta1 For This Useful Post:
Old 12-26-2013, 09:18 PM
SD73's Avatar
Thanks, John! I'll have to check to see if my Service Manual has that supplement. Great find! There is an ebay seller that was selling a supposed NOS FIrebird one marked PD that sounds like it really wasn't for F-Bodies.
In any case, we can put a merciful end to this thread. Thank you all for your help, but a special MASSIVE thanks to Transam1972 for all the extra help, sending his cable to me to examine, then offering a trade to me that was more than generous! He's really a great guy, and an exemplary member of what this hobby is all about. It's truly great meeting yet another friend in this hobby that's made the big world of working and researching these cars a lot more smaller and intimate. Thanks again, Glenn! You really are a great guy and a great friend!
The Following 2 Users Say Thank You to SD73 For This Useful Post:
Old 12-27-2013, 12:27 AM
Held for Ransom's Avatar
I'm back to address a few threads.
The '72-73 cables are marked PA (2 bbl) and PB (4 bbl).
The '74 cables are marked SE (2 bbl) and SF (4 bbl).
SE measures (mine have smooth ends)
A-B 6-1/2"
C-D 4"
D-E 11-1/2"
G-H 2-1/4"
A-F 21"
SF measures (mine have ribbed ends)
A-B 6-1/2"
C-D 4"
D-E 12-1/2"
G-H 2-1/4"
A-F 22"
I have a cable marked as a '72 2 bbl. and it has the same dimensions as the SF cable and is a close match to the PP repro (I had to rework the G placement and shave the accelerator arm a little).
The Following 5 Users Say Thank You to Held for Ransom For This Useful Post:
Old 12-27-2013, 01:46 PM
transam1972 transam1972 is offline
Default Lost In Translation
I do want to point out to any one who has been able to follow this thread...the repo. that is sold by P.Y.,Ames,P.D.,etc. is correct for at least 72&73...possibly 70-74?...I really don't know,since I don't own those cars...the cable is $59 and works 100%...and it is as close as possible......100% correct=No close enough=Yes...if you want more reproductions made, we have to buy them...in 200 years what do you think they will use to restore your car?
The Following User Says Thank You to transam1972 For This Useful Post:
Old 12-27-2013, 02:19 PM
SD73's Avatar
Thanks HfR.
Transam1972 is right. While the repro is not dead-on in appearance, it is a functional equivalent to the 72/73 (and maybe other years too). The total length is the same (22.5in) and the black tube center is also the same length (11.75in) with key difference being some of the visuals. In any case, here's a pic of my mangled, brittle, and many times repaired original on top, the repro, and then the one transam1972 sent over for comparison.
Old 12-27-2013, 02:59 PM
You must be measuring from the end, where I measure from the mounting points.
The Following 2 Users Say Thank You to Held for Ransom For This Useful Post:
Old 12-27-2013, 03:12 PM
SD73's Avatar
Yup. My measurements are end-to-end. and the actual black tube between the gromments. I'm not sure how they'll compare to your '74s, but I'd think at least the black tube section would be about the same. It seems like a few members had a bit of a variance between the centers, but 11.75 was pretty common.
Old 12-27-2013, 03:57 PM
Default 70 thru 74?
does the repro. work only for 1972 and 1973...or can we include...1970,71 &1974?
Old 12-27-2013, 04:12 PM
SD73's Avatar
That's a good question since they're marketed for those surrounding years too. I suppose if we got some measurements from those years we could see how they compare. I think the Total Length and the black tube without the grommets will tell the story. It may be that the cable protruding from the end of the grommet going to the gas pedal is a different length so some extra measurements would be good to be extra safe.
Old 12-27-2013, 04:30 PM
Default ?
that's easy for you to say since you already have a cable...it is the 1970...1971 ...and 1974 cars that I am concerned with...it is about a hobby...right?
Old 12-27-2013, 05:08 PM
I'd say the 70 is different for sure.
It mounts differently in relation to the newer intakes.
(71 may be the same mount also, been too long since I looked)
Plus the ends are different also, I believe.
(carb side )
Old 12-27-2013, 05:22 PM
SD73's Avatar
At this point if there's anyone out there that has a cable loose to take some measurement of we can come to a conclusion on the other years as well, but without them I can just say the 72/73 cables are a fit with the repro. I know some of the surrounding years John mentions have a different connectors so I'm not sure if they would even interchange. But if we find the total length of the cables, the length of the black tube area, and for the 71 and 74 the length of cable protruding from the grommet to the gas pedal we can see if those crossover too.
Old 12-27-2013, 06:58 PM
blue71ta's Avatar
blue71ta blue71ta is offline
1970 uses a pin style attachment on the throttle arm of the carb, rather than the ball stud that is used on the '71 - '74 models
The Following 2 Users Say Thank You to blue71ta For This Useful Post:
Old 12-27-2013, 09:36 PM
SD73's Avatar
I just verified HfR's D-E measurement and it's the same as our 72/73 Cables. And that extra half inch is accounted for too since I'm doing end-to-end and he's doing mounting point to mounting point. Again, except for cosmetics, the repro should work for 74s as well.
If someone has a 71 4bbl cable handy to measure we'll have all our bases covered.
  #38
Old 12-29-2013, 03:18 AM
Formulabruce's Avatar
I have a 71 Formula400 cable, Ill dig it out on Monday
  #39
Old 12-29-2013, 12:19 PM
SD73's Avatar
That would be great, Bruce. I think at this point just the total length and the length of the black tube will tell us what we need, but the types of grommets would be nice to know too for aesthetics.
  #40
Old 12-31-2013, 03:18 AM
pics...Note 4 speed car, no TH400 bracket on the pedal mount.
ID:	347998   Click image for larger version
ID:	347999   Click image for larger version
ID:	348000   Click image for larger version
ID:	348001   Click image for larger version
The Following 3 Users Say Thank You to Formulabruce For This Useful Post:
