Old 02-09-2009, 11:01 PM
Firebob's Avatar
Firebob Firebob is offline
Default Basic question about rods
I've had rods re-sized before putting them back in before but I don't really know what that is. So maybe somebody would be kind enough to enlighten me.
Robert
Old 02-10-2009, 12:08 AM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
a machine shop mills some off the cap and or the rod big end, then resizes the rod journal end of the rod.
Old 02-10-2009, 07:28 AM
steve25 steve25 is offline
Will you be putting your motor back together, or will a shop assemble it for you?
Old 02-10-2009, 11:11 AM
DiamondJim's Avatar
DiamondJim DiamondJim is offline
I once visited an (mass) engine rebuild shop and stood beside a guy resizing rods, it was amazing. For measuring. he had a cone shaped device that he slid the rod on (it was marked with demensions), it literally took him less than 2 minutes to resize a rod! -Jim
Old 02-10-2009, 03:20 PM
Schurkey Schurkey is offline
Another reason to avoid production-line rebuilt engines.
Old 02-10-2009, 10:18 PM
Firebob's Avatar
Is it just the cap end that becomes deformed? Seems like the new bearings wouldn't fit right afterward if the hole was cut offset to the original parting line. I'm sure they don't recut the locating groove too.
Robert
Old 02-11-2009, 03:26 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Both rods and caps get deformed. More than .005" is never milled from the cap (and maybe also from the rod) for resizing- if more than that is needed, the rod gets scrapped. Bearing tangs will fit fine- the locating grooves are sized "generously" enough, depthwise.
Old 02-11-2009, 12:42 PM
72blackbird 72blackbird is offline
Alot of builders say there's nothing wrong with resizing cast rods, and IMO they're good for grocery getters which will never see more than 3000 rpm, but I'd pass on them if you're planning to rev your motor over that. The price of a new set of 5140 forged rods is maybe $50-75 more than what it would cost for a set of cast resized rods, but they are much stronger and won't fail if you buzz them to 6000 rpm.
Geno
