Old 02-05-2009, 10:54 AM
67cruiser 67cruiser is offline
Default Ive got a weird question??
Why is it everytime i see a street or drag car that the guy or guys come up the pass side with there fuel lines?? I brought mine up the drivers side with no issue,s so far. I still have to come up over the valve covers regardless of witch side i use. Is this just a personal issue thing?? Seems like i can tap into my regulator alot easier for my fuel pressure gauge with less line and less time. Whats your thoughts on this subject??
Old 02-05-2009, 11:00 AM
Jeff Walker's Avatar
Jeff Walker Jeff Walker is offline
Stop looking at all them Chevies...
North Dakotas fastest REAL GTO
10.10 @ 131 MPH in the 1/4
Hoping to get it back together some year.
www.jandjrepairandrestoration
sleepy's Avatar
sleepy sleepy is offline
Most stock location fuel pumps are on the passenger side of the motor. Most carbs have the fuel inlet on the passenger side.
Old 02-05-2009, 11:10 AM
On Chevys that is, never seen a passenger side mounted fuel pump on a Pontiac engines...I think most Fords had them on the drivers side too.
So to sum it up whatever side the fuel pump is mount on the engine is usually (but not always) the side the fuel line will come up on.
Old 02-05-2009, 11:19 AM
BILTIT's Avatar
BILTIT BILTIT is offline
My factory feed line comes up the pass. side so i just ran my feed and return on that side.
Derek B.
Current best: 11.97@110 1.65-60' !!!
'74 ventura, (Fired july 14/06) '74 462 4-bolt (9.5-1), SCAT, Ross, T-II w/850DP (shaker455), TH350, Conti 10'' 3800, Supercomps, Magnaflow, 3'' Pypes, 3.73's, 28x13.5-15 ET streets.
1970 Beismeyer 17' flatbottom vdrive, 11.8:1 455P, ported heads, dual Qjet tunnel ram.
Old 02-05-2009, 04:34 PM
Sorry, never said fuel pump on pass. side of car, don,t know where you got that at?? Ive been to alot of Pontiac drags and i would say that nearly 50% or more come up the pass side of the car, yes just like the chevy guys, and no i don,t look at those cars, just wondering why things are done that way. Oh last thing fuel outlet go,s to pass side of car???? Thats a new one on me, every Pontiac carb. came stright out the front.My 67 gto fuel lines , factory came up driver side.
Old 02-05-2009, 05:31 PM
sleepy's Avatar
Until Pontiac went to corporate motors. The brake lines run down the drivers side that leaves more room on the passengers side for fuel lines. On race cars It's just personal preference. It also keeps the gas away from the driver in a crash.
Old 02-06-2009, 01:03 AM
lust4speed's Avatar
All the Pontiac pieces run down the driver's side -- wires, original fuel line, original return line, and brake lines. Emergency brake cable and speedometer cable are also in the near proximity on the driver's side. Go over to the passenger side and it's bare frame -- just too tempting to not take the easy way out. With the fuel cell and battery in the trunk, it also seemed like a prudent idea to run the battery cable down the driver's side (starter side) and keep the new fuel line on the opposite side.
Mick Batson
1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon.
Old 02-06-2009, 01:30 AM
gtofreek's Avatar
gtofreek gtofreek is offline
Personally, I would prefer to have the fuel lines on the passenger side incase they they catch on fire or something. There are too many things already that "fry my ass", so that would be one less thing!
Paul Carter
Carter Cryogenics
www.cartercryo.com
520-409-7236
Koerner Racing Engines
You killed it, We build it!
520-294-5758
87 S-10 Pickup, 321,000 miles
99Monte Carlo, 293,000 miles
86 Bronco, 218,000 miles
Old 02-06-2009, 09:16 AM
Goat-Racer's Avatar
Goat-Racer Goat-Racer is offline
The simplest reason is that alot of guys run 4150/4500 style carbs, and the fuel inlet nuts are on the passenger side. Just plain cleaner to have lines and regulator on the proper side to begin with.
Brian Rock
'65 GTO - Pump gas 496" IA2 w/ High Ports, 200-4R trans, 3.73 gears, 275 Hoosier radials, and 3925 lbs.
9.88 @ 134 N/A on Cali 91 octane.
http://www.youtube.com/watch?v=NJEIY5OJ68g
Old 02-06-2009, 11:09 AM
quicksilver97ta's Avatar
Don't forget about the pickup lines at the tank, that will dictate which way the lines are ran also.
Old 02-07-2009, 05:18 AM
stimpy stimpy is offline
me don't like fire . and too much stuff on drivers side ( steering gearbox )
Old 02-07-2009, 09:33 AM
JKrull66's Avatar
JKrull66 JKrull66 is offline
Send a message via AIM to JKrull66
Dito on the too much stuff. Brakes steering starter wireing. Easier to run the new bigger lines down the pass side at least on the one I did.
John
Beers Bikes Babes and Pontiacs Rule!!!
63 Lemans in the 9's race
66 GTO HT Cruiser
06 Triumph Rocket III TURBO! 2300 CC Bad boy
KTM 525 Dirt Terrorizer
POLARIS 900 RZR
10 GMC SLT Duramax Haul anything anywhere
http://www.facebook.com/profile.php?...app_2392950137
Old 02-09-2009, 07:24 PM
Region Warrior's Avatar
Fuel lines on the passenger side along with the E-fuel pump and battery, etc, help off set the drivers wieght.
