Old 08-04-2000, 03:54 PM
Chris Baillie Chris Baillie is offline
I am trying to put my 455 pontiac and m-21 from my 73 trans am into my 79 that had a 455 olds and turbo 400 and can't find the proper motor mounts. I found a 400 to 403 conversion but will this work with a 455 pontiac to a 455 olds? any help would be appreciated alot.
Old 08-04-2000, 06:37 PM
Held for Ransom's Avatar
Chris, I think you typed in things backwards. If you want to put a 455 Pontiac in your '79 Firebird, use the "Frame Mounts" from your '73, or any '70-'79 V-8 Pontiac Firebird. Also, use the same year "Motor Mounts" as the "Frame Mounts". You should use a TH350/Manual Transmission crossmember instead of the current '79 Olds TH400. Driveshaft???.
[This message has been edited by Held for Ransom (edited 08-04-2000).]
So long, farewell.
