Oil pan gasket
I have a question about oil pan gasket .At the rear of the motor there à 3 tab black gasket .In the kit it comes with à cork gasket .Also .Do i use both gaskets back there .Or just the black 3 tab .And the kit came with à 1 inch round white plastic seal Don t know where that goes .?Thank you .
The cork gasket is for an earlier style oil pan. Usually the pan gasket comes with 3 different gaskets. 2 rubber and 1 cork. I have no idea what the plastic seal is. could to post picture?
Drain plug?
costs too much |
See if i can post the pic .Could be drain plug .
Yup drain plug
I don’t think I would be wrong to say that 90% of use prefer to use the cork seal even when the pan we are using has the holes for the rubber seal.
The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
The earlier rear main for the cork seal has the deep groove cut in and probably 50% of the height of the cork seal resides in that groove. If the rear main is the later flat style, I'd just use the correct rubber seal with the sails.
Mick Batson 1967 original owner Tyro Blue/black top 4-speed HO GTO with all the original parts stored safely away -- 1965 2+2 survivor AC auto -- 1965 Catalina Safari Wagon. |
The Following User Says Thank You to lust4speed For This Useful Post: | ||
Thank you everyone .Got it now .The cork strip is for 1970 and earlier .Is what i am getting from this .And drain plug gasket .
Always use a cork seal and a light coat of Ultra Black. Make sure to get the right thickness gasket. The rubber seal will split and leak like crazy! Clean first with brake clean, lacquer thinner, etc.
The Following 3 Users Say Thank You to JSchmitz For This Useful Post: | ||
X2 on the above. I always use the cork seal on the seal with the tabs on it. Had much better results over the years with it.
62' Lemans, Nostalgia Super Stock, 541 CI, IA2 block, billet 4.5" crank, Ross, Wide port Edelbrocks, Gustram intake, 2 4150 style BLP carbs, 2.10 Turbo 400, 9" w/4:30 gears, 8.76 @153, 3100lbs |
The Following 2 Users Say Thank You to Gary H For This Useful Post: | ||
Thank you .
Are you saying you use both seals together?
Will Rivera '69 Firebird 400/461, 290+ E D-Ports, HR 230/236, 4l80E, 8.5 Rear, 3.55 gears ‘66 Lemans, 455, KRE D-Ports, TH350, 12 bolt 3.90 gears '64 LeMans 400/461, #16 Heads, HR 230/236, TKO600, 9inch Rear, 3.89 gears (Traded) '69 LeMans Vert, 350, #47 heads: Non-running project |
x3 on the cork seal even on pans made for the rubber. i had a leak that i thought was a rear main, turned out to be the early poor design 3 prong rubber seal that was leaking, re did the pan gasket using a standard felro gasket but used the cork gasket as MR P body explains here, been pretty much leak free for 7+ years now. the later 5 prong rubber U seal is better than teh eralier one but the cork is much better when installed properly.
https://pontiacstreetperformance.com/psp/Sealit.html |
The Following User Says Thank You to 78w72 For This Useful Post: | ||
Not together. Cork only. This has been talked to death on here. Do a search if you want more info.
I’m aware of that and agree the cork is better. But the way Gary H worded it wasn’t clear he was suggesting the cork in place of the rubber seal verses in conjunction with
Yeah kind of did .Put the cork in front of the black 3 tab .Half was on .Going with the cork .Buying the felpro 1814 kit .I ll rtv it let it set for a few . Thanks everyone .
Isn t that the answer .To not use the 3 tab black neoprene seal ..And just use the cork in its place ..
It wouldn't make any sense to use the 3-tab seal in conjunction with anything if it splits right? To me this is very similar to the SBC intake to block seals. Everyone figured out years ago to just put RTV there. |
I kind of glad i messed it up ..I was going to go with the black 3 tab .But it didn t seem good enough .So i added the cork in front of it .Half was. on half wasn t .So was worried .But thanks to all of you .I feel confident in rtv ing the cork on .Thank you everyone ,appreciate it .
Here is the best way to seal the rear of the pan. Forget any type of rubber seal, they have a BAD habit of squishing out and starting a major oil leak. I cut a custom seal from a piece of 1/4" thick rubber impreganted cork material. It's available on-line.
Then just apply a dab of RTV to the ends, set the pan and not one drop of oil will every get past it.......
The Following User Says Thank You to Cliff R For This Useful Post: | ||
