Old 01-02-2024, 07:11 AM
steve25 steve25 is offline
Leave it be till spring.
Old 01-02-2024, 12:08 PM
bhill86's Avatar
bhill86 bhill86 is offline
Ok, thanks.
1977 Trans Am 400/4speed (swap)
Brian
Old 04-16-2024, 11:48 PM
bhill86's Avatar
Thought I’d come back to update. I snuggled up the bolts on the timing chain cover and got 6 or 8 good heat cycles on the engine since adding the stop leak and the leaks appears to have…well, stopped. Coolant level in the reservoir has remained consistent. Never tried anything like that but I’m glad it worked. Time for fresh oil and another analysis at the end of the season. Fingers crossed. Thanks for the assistance.
Brian
The Following User Says Thank You to bhill86 For This Useful Post:
Old 04-17-2024, 12:40 AM
Sirrotica's Avatar
There are only a few mechanic in a can potions I recommend, but Bars Leaks is one I have used in my personal cars, as well as customer cars. It won't fix a head gasket that has a 1/4 inch piece missing, but it will certainly stop a small seep internally, or exterenally.
If you've got a rotted radiator core, it's not going to repair it, but a stone nick in a tube will seal.
Glad the fix has worked..
Brad Yost
1973 T/A (SOLD)
2005 GTO
1984 Grand Prix
Old 04-20-2024, 12:23 PM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Glad to know it worked! You probably had some tiny capillary leak in the timing cover - overall, no big deal and the perfect application for a stop leak product. I'd feel bad using one too, but even GM put in those stop leak pellets in brand new motors at the factory.
Post back up here once that oil analysis comes back! I'm curious.
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
Old 04-20-2024, 09:35 PM
bhill86's Avatar
Will do
Brian
