Old 05-10-2004, 06:34 PM
MR. May MR. May is offline
were the venturi rings on these carbs ground off at the factory or were they not even cast in?
Old 05-10-2004, 10:17 PM
Not cast in I believe.
Old 05-10-2004, 10:28 PM
Jack Peters's Avatar
John above has it right.
JLP
Old 05-11-2004, 05:23 AM
Cliff R's Avatar
Cliff R Cliff R is offline
The 71 HO carbs are not only lacking the outer rings they are completely different castings. The single booster will extend nearly to the bottom of the main casting. On the other models the inner booster only extends a short distance into the casting. Removing the outer booster ring on std carbs requires completely different calibration specs than even the 71 HO carbs used......Cliff
Old 05-12-2004, 01:00 AM
Kenth's Avatar
Kenth Kenth is offline
These carbs were considered inefficient at low engine rpm´s so Pontiac went back to the earlier design year after.
1966 GTO Tri-Power
1970 GTO TheJudge
http://www.poci.org/
http://gtoaa.org/
Old 05-12-2004, 02:53 PM
a few more questions. would a service replacement carburetor not have the two letter plant code on it? also what is the value of a 7041267 service replacement carb that was made by Carter?
Old 05-12-2004, 03:08 PM
carbking's Avatar
carbking carbking is offline
Mr. May -
As a general rule, service replacement carburetors did NOT have the plant code.
A service replacement 7041267 made by Carter is a 1 of none! According to Carter records, Carter made zero HO or RA Pontiac Q-Jets following the 1967 model year.
Jon.
Old 05-12-2004, 04:36 PM
GREAT! I purchased a carb that doesn't exist. Is there a way to figure out what this thing is?
Old 05-12-2004, 05:07 PM
carbking's Avatar
Give me a call during normal business hours.
Jon.
