Heater problem
Got into my 70 formula the otherday to take it for a short drive and turned the heater on but no heat. I had no heat coming through the defrost or below to the floor. I had air comming out of the a/c vents but that wasnt hot either. The temp. gauge works and the temp is steady when driving or idling. Any suggestion where i should start to look for the problem? thanks for the help
Does this car have a heater core valve on the inner fender that one of the heater hoses connects to? If that stays closed it will prevent the coolant from flowing through the heater core.
The Following User Says Thank You to Dens71TA For This Useful Post: | ||
could also be rust,blockage in the heater core comming from the head.
"The Future Belongs to those who are STILL Willing to get their Hands Dirty" .. my Grandfather |
The Following User Says Thank You to Formulabruce For This Useful Post: | ||
Or the cable that opens the heater door on the top of the heater box has snapped. When you adjust the hot-cold lever does it feel like it is moving anything or does it move every loosely? If there is no resistance the cable broke.
heater problem
It doesnt move easily and its not loose at all but that doesnt mean its not broke? i will have to get under there and check a few things out.
Yes it does. I will have to check that out and see if its working propperly.
Did you check the radiator fluid level? Low level could be the problem.
The Following User Says Thank You to Mezzo For This Useful Post: | ||
heater problem
yes, its full
Might be a good idea to check for a malfunctioning (stuck open) or missing thermostat?
Eye Candy......garage band? https://www.youtube.com/watch?v=QUPcHxHRx3s Go full screen & turn it UP! |
heater problem
well the thermostat seems to be working normally.
After 2 months, have you fixed this?
Or are you frozen?
