My R.A.C.E. ported highports....
As some of you know, I'm in the process of building a 505ci IA2 based street/strip engine for my '63 Tempest. My choice in cylinder heads has changed a few times throughout the process of gathering parts. I started with a E-head, moved on to a rockershafted Wenzler, and then finally settled on the KRE highport heads. Based on the feedback I received from Steve Coombes and a few other board members, I decided to give the highport head a shot. Based on a recommendation from Jim "Old Man" Taylor, I chose to have Jim Robertson do all of the cylinder head work and intake manifold porting. Judging by the results, I'd say I made the right choice. The mid-lift numbers are incredible!
Keep in mind this is a standard pushrod location head, not a wideport. There's no need for rockershafts and off-set roller lifters. I ordered the heads bare, with the seats installed, but not cut. I also added a set of the Ferrea 1200 series 2.20 intake and 1.70 exhaust valves. Here's what they flowed on the R.A.C.E. flowbench before and after portwork was done. The only modification to the stock head is the competition valve seat work. Stock 28" on a 4.21" bore - 2.20" intake/1.7" exhaust valves - No tube __Intake_______________Exhaust__ .100__75.78_________.100__66.49 .200__137.9_________.200__118.8 .300__197.1_________.300__152.5 .400__258.0_________.400__179.6 .500__299.5_________.500__189.8 .600__311.5_________.600__196.5 .700__325.7_________.700__202.5 .800__326.9_________.800__205.0 .900__330.2_________.900__209.3 R.A.C.E. Ported 28" on a 4.21" bore - 2.20" intake/1.7" exhaust valves - No tube Intake ports ended up @ 2.55" x 1.35" at the pushrod constriction Sorry, I don't have all of the exhaust numbers. __Intake_______________Exhaust__ .100__82.40_________.100__ .200__151.7_________.200__ .300__222.0_________.300__ .400__296.7_________.400__205 .500__349.6_________.500__ .600__367.8_________ .650__374.3_________.650__264 .700__374.5_________.700__ .800__377.9_________.800__ .900__382.4_________.900__
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ Last edited by R 70 Judge; 07-02-2007 at 08:51 PM. |
Stir the pot my friend.....
lookin good
Beers Bikes Babes and Pontiacs Rule!!! 63 Lemans in the 9's race 66 GTO HT Cruiser 06 Triumph Rocket III TURBO! 2300 CC Bad boy KTM 525 Dirt Terrorizer POLARIS 900 RZR 10 GMC SLT Duramax Haul anything anywhere http://www.facebook.com/profile.php?...app_2392950137 |
I sent my highports to Jim.From what I've seen and heard he's about as good as it gets.
Those are some very impressive numbers.The mid lift #S are phenominal.Looks like you will be making some serious power.Jim is very good with head porting for sure.
Ding...Ding...Ding!!! We have a winner!!!!
Due to the current economic conditions...the light at the end of the tunnel has been turned off. Meet you at the finish line.....don't be late! |
Congrats.
The Bandit Rules - Make mine with a SD-455 Engine . |
Great improvements and astonishing flow numbers for a standard pushrod location head!!! How long did it take to have them prepared and how much for the work? (you can answer in a PM if nessesary)
Awesome numbers!
Very Nice. OMT is the Man!!!!
You know it's going to be a good day when you wake up breathing! |
your mid lift numbers are very close to mine with the offset pushrod (mine go around 350@ .500) congrats, sounds like jim does some good work.
'78 Ford Fairmont 526ci pontiac; true 10.5 tires and stock suspension. 5.14 @140.5 w/nos; 8.86@151 all motor.8.17@172 1/4 mile w/nos |
Are you sure they measure 1.350" at the pushrod pinch? If so then he had to have moved the pushrod hole over. The widest you can go is 1.200" and that is with pushrod tubes pressured in. Unless something has changed with them.
if you don't mind james, what id the work cost? thanks, mike
James 1970 Trans Am Spotts Built 484" IA2, Highports, EFI Northwind Terminator X sequential EFI fabrication and suspension by https://www.funkhouserracecars.com/ |
I don't want to misquote him on a price. When I get a concrete answer I'll send you guys a PM.
Jim,
If you don't mind could you send me a PM with the price, I just bought a set of High Ports and need to get some work on them, Thanks, Bob |
Just call Jim.He will go through what you want and give you a price.He loves to talk about this stuff.
I talked to Jim this last weekend and will be sending him a set of Highports. Good guy to talk to as R 70 said. He has some realistic goals in mind if you don't want an all-out race engine or a race engine if you want.
James ordered the hi ports with seats, guides, valves and "standard" pushrod hole locations. The valve location and thus the pushrod holes do not appear to have the same spacing as original Pontiacs. Pushrod holes also appear to be angled. We discovered this while machining for the pushrod sleeves. I have not measured them or asked for the dimensions. I do know the intake pushrod location allows a bit more width than original Pontiac spacing. Heads are at the shop at this very moment so I cannot measure them.
Pricing depends on many factors but we price it per the customers needs/requirements. More flow = more $$ :-) Thanks for your interest, Jim |
Can you post some pics?
What type of cam are you planning (RMP limits) did you have do anything to address the added weight of longer valves?
1969 Firebird, Tx3-455/468 machined by CVMS E-heads by Dave Wilcox/Comp Cams 300B-6 flat solid 850DP on E-85 by Eric Niefert/T2 1" plastic spacer T-400/PTC 4000/390's/30x9 Hoosier radial slicks,#3400 1.38 60' 6.32 @ 108 MPH at Northeast Dragway NC 5/23/15 (9th pass on new engine) https://m.youtube.com/watch?v=ePCu2v...ature=youtu.be 1.37 60' 6.26 @ 109 half track, 9.86 @ 136 1/4 mile, #3350 11/26/16 at Richmond Dragway (125th pass on new engine) |
In order to go more than 1.200 on the port width. You have had to grind up the interior wall. I bet the interior wall between the ports looks like a razor blade. Dont get crazy with the cam to much duration will make the ports lazy! You can run more lobe sep with this much flow. you should make 850 to 900 hp with now problem. Congrats.....
