Knock sensors
Is there an aftermarket "knock" or detonation sensor that can be added to a Pontiac? Between my mufflers, the wind noise, trany whine and being almost def I cant tell if what I hear is detonation or just the normal rattles of an older car.
Based on what I have read and the parts I have used, doesn't seem like I should have a detonation prone car but at 14* without vacuum advance hooked up, I am hearing "something" at cruise when I try to give it power to pass a car on the hiway. thanks
462 Yc Block, zero deck Probe forged pistons 6cc relief, Scatt Hbeam rods floating pins aprox. 10.21 CR Comp Hyd-roller cam,roller lifters,springs ect. 236 244@ .050 108 LSA .511 lift, duration 289,297 @.oo6 Edelbrock Aluminum 87cc round port heads Larger valves ,ported polished and cut Powerjection3,T2 manifold, Try-y’s Flowcooler water pump. 71 formula with TKO600,hydraulic clutch 3.42 posi and 26 inch tire. 17x9 YO Honeycombs with Nitto 555's |
