Old 11-22-2023, 09:26 AM
Norwood's Avatar
Norwood Norwood is offline
Originally Posted by bob prichard View Post
Did you spray this on or brush on? Thanks.
It’s very thick and is brushed on.
Old 11-22-2023, 01:07 PM
bob prichard bob prichard is offline
Just put them on and run them, no need to bake the manifolds in an oven. The brush marks pretty much disappear after they dry.
They look fine with just brushing on the paint but do whatever method you prefer.
Thanks.
Old 11-22-2023, 01:23 PM
78w72 78w72 is offline
Thanks.
The cure instructions by por15 say to heat them above 300° for a short time then let cool to fully cure them. Im sure they can just be ran to full operating temp too but the correct way is a lower temp then to let cool, very easy to do that by just running the engine for a minute or 2 to get them above 300 but not full running temps, then let cool.
https://por15.com/products/high-temp...39607014424743
Old 11-22-2023, 01:25 PM
For what it's worth, I used some VHT on my manifolds years ago. Took them to work with me and baked them in an industrial oven following the label directions and that paint didn't last any time at all. In fact they started rusting sitting on my paint shop's parking lot for a few weeks in the weather. Completely rust coated now.
Old 11-23-2023, 01:10 AM
Formulabruce's Avatar
Ceracote dry times affect the high temp range. Mine will be at 1086 degrees oF I was told. Between that and the 421 Mods I expect to keep Paint on the 12's...
Old 11-23-2023, 02:13 AM
Bummer.
Old 11-24-2023, 09:59 PM
I have found a local ceracote shop. For those who used ceracote, what color did you use? Thanks.
Old 11-24-2023, 10:45 PM
POR-15 manifold paint after 5 years and 30k miles of daily driver duty in Southern California. Those of you who live in wet or humid climates may have different results than I had.
These were 1967 GTO reproduction manifolds bought new from RARE. I ended up selling these because I wanted to go back to log exhaust manifolds for slightly better ground clearance and less installation hassle, that put money back into my pocket for other things I needed for my car that were more important than a few extra horsepower.
ID:	623725   Click image for larger version
Old 12-08-2023, 10:20 PM
Baba O'Riley's Avatar
Baba O'Riley Baba O'Riley is offline
FWIW I ended up going with the the POR-15 manifold gray, after a good sandblasting. The Master Blaster told me it's really important not to handle them post-blast without gloves, the oil on your fingers impacts header paint adhesion / performance he says. But the results have been excellent.
"A MAN IS ONLY AS OLD AS THE WOMAN HE FEELS."
-- Groucho Marx
