Old 12-22-2017, 01:56 PM
455hota's Avatar
455hota 455hota is offline
Default 70 Fire wall Pad Question
I bought a 70 fire wall pad from our sponsor. I am removing the cut outs prior to installing it, but i have a question.
The pic above is where the pedal assembly mounts and the 4 studs go through the firewall. The upper two studs are obvious as well as where the brake booster shaft comes through the fire wall.
My question is I think I am missing one of the lower pedal assembly studs (driver side). The passenger one is the oval shaped hole that I have not removed yet.
I guess I need to cut in the missing hole, or am I missing something? Has anyone else had the same missing hole?
Thanks, and have a Merry Xmas!!!
...Steve T.
"Resurrection of a 1970 Trans Am" Blog
www.455hota.wordpress.com
1966 GTO 4 speed Hardtop Alabama car (Marina Turquoise w turquoise interior)
1970 TA 4 speed Canadian car (Lucerne Blue w bright blue interior)
Old 12-24-2017, 06:10 PM
FunctionalShaker FunctionalShaker is offline
Here is what the other, molded padding Ames sells looks like.
Old 12-24-2017, 08:17 PM
455hota's Avatar
Thanks for the pic!
Sure would be nice if “attention to detail” would make a comeback and the focus on quality would return....
...Steve T.
Old 12-24-2017, 10:35 PM
Definitely a difference in price between the two, but the more costly one appears to match original more closely.
Old 12-25-2017, 08:48 AM
455hota's Avatar
I agree. I first was leaning to the higher priced one, but then it said it had the foil layer on the back side, which was not on the original one, so I chose the rubber jute version.
I will cut mine and make it work and move on. No need to drag this restoration on any longer than it already has!!! Lmao
...Steve T.
Old 12-25-2017, 10:18 AM
Yeah, the foil between the rubber and jute isn't correct, but other than that I think it better matches original. Once again it's one of those deals where one asks: Why not reproduce it correctly in the first place?
Old 12-26-2017, 02:21 PM
455hota's Avatar
Amen Brother!!!
...Steve T.
Old 12-27-2017, 11:37 AM
455hota's Avatar
I have a related question:
In the first two pictures the assembly manual says that part #1 is a washer, part number 3868762.
After an internet search I believe this is a mastic or sealer washer.
The third pic is of the InLine Tube foam washers.
I think I am going to make my own washers from strip caulk.
My question is: are the mastic washers 100% mastic with no metal backing? I think the answer is 100% mastic.
Thanks..
...Steve T.
Old 12-27-2017, 01:23 PM
Never seen evidence of foam or metal washers when removing heater boxes, so I'd say just use mastic
Old 12-27-2017, 03:35 PM
455hota's Avatar
You confirmed my past observations. Mastic it is.
...Steve T.
Old 12-27-2017, 03:59 PM
455hota's Avatar
Anyone have a source for this under cowl insulation pad, that is under the dash area?
The original one disintegrated during disassembly.
Ames does not seem to list it.
...Steve T.
Old 12-27-2017, 04:38 PM
Dens71TA's Avatar
Dens71TA Dens71TA is offline
There is no known source for the under cowl insulation used on early 2nd-gen cars. REM makes a version for the 68-72 A-body but I was never able find it for F-body. Since it was only used for a short time there may not be enough demand.
Old 01-02-2018, 05:26 PM
TA455HO's Avatar
TA455HO TA455HO is offline
I'm a little late to the party....
Mastic is correct. AMK Products makes these.
http://www.amkproducts.com/bulk5.asp?part=B-13742
Chad
1966 Ford F250 Deluxe Camper Special Ranger Custom Paint - San Jose plant
http://www.ford-trucks.com/forums/12...al-ranger.html
1966 Ford F250 4x4 Red/White 4-speed - San Jose plant
1966 Ford F250 4x4 White 4-speed - San Jose plant
http://www.ford-trucks.com/forums/11...-f250-4x4.html
1971 Trans Am White/Blue 4-speed limited options - Norwood plant
http://forums.maxperformanceinc.com/...d.php?t=757496
Old 01-02-2018, 05:32 PM
455hota's Avatar
Chad
Thanks for the response Chad!
...Steve T.
Old 01-16-2018, 06:10 PM
unruhjonny's Avatar
I find post #11 inspiring...
If it wasn't so cold in my garage, I'd be tempted to "play" in the garage each night after putting the kids to bed...
1970 Formula 400
Old 01-16-2018, 09:42 PM
455hota's Avatar
I made a template from my pictures I took during the disassembly of my 70.
I called REM and asked them is they would sell me the material in bulk so I could make an under Dash insulation pad for my car.
They offered to make me one from my template, and then they will add it to their catalog.
Hopefully I will see their results shortly.
...Steve T.
Old 01-17-2018, 12:35 AM
Sounds good.
Old 01-17-2018, 11:22 AM
unruhjonny's Avatar
nice!
1970 Formula 400
Old 01-25-2018, 08:32 PM
455hota's Avatar
Here is my update on the 1970 under dash insulation. Please note my car was built 2nd week of June, 1970 at Norwood:
This pic shows the first prototype (on the left), made from the template I made from my disassembly pics. These were made by REM. I had them make it from their yellow fiber glass material. It ended up being a bit thick compared to the original material even though the material was very similar. REM said this fiberglass material would not be used on their production version. Once I got it and test fit it I discovered that they made it opposite of that I wanted. I wanted the gray side to be against the underside of the dash. So since I needed another one, I decided to go for the REM mastic/jute material. This is what they plan to use for this part.
You can see it on the right side in the above pic.
I am glad I went this way, because is more pliable and fits up under the dash nicer. I will post pics once I install it.
I am not sure when REM will have the part listed, but I am sure you can call them and they will let you know when and a price.
...Steve T.
Old 01-27-2018, 11:35 AM
455hota's Avatar
ID:	473707Click image for larger version
Here are some pics of the under insulation pad installed.
I think it turned out pretty nice. I do like the flexibility of the jute better that the fiberglass material of the first prototype. The mastic jute version payed down around the curves very nicely.
...Steve T.
