69 FB factory A/C
Getting ready to put my 69 FB back together, have front clip off, motor/tranny out, front subframe out, and rear suspension out.
Question is, while I have the front clip off and the A/C is easily accessible, is there any way to check out the evaporator and other A/C parts to make sure they work BEFORE putting everything back together? Thanks Stan |
Only thing I would know of doing would be flushing evap and condenser, and maybe a leak check of system components if you pressurize them with air and do a rate of fall pressure check. Or, put it under vacuum and do a rate of rise. Some a/c shops might have more sophisticated equipment to do a leak check.
POA valves can be bench tested with air pressure to see if they regulate pressure properly. It would require an air compressor and a/c gauges.
"...ridge reamer and ring compressor? Do they have tools like that?" |
Thanks, pretty much what I wanted to know, just hate to put the whole damn car back together and then have an issue. I will pull and check the fan motor and while I'm at it I will either check or replace the heater core, as this car has sat for 12 years. |
Replace all the rubber hose with the new barrier type hose.
The metal fittings can be reused.
Its ok to giggle and snicker, Dont laugh and point |
Are you planning on using 12 or 134a?
If 134a you will want to drain the compressor and flush the condenser and evaporator to get rid of the mineral oil. I would change the the hoses as Ollie suggested, and I would replace the o rings at all the fittings as well with the green ones. They have universal kits at NAPA for about $10 on the pegboard. You might think about putting a larger condenser in the car as well. You will need to change the service ports to the 134a fittings as well, kits are available. A new receiver dryer would be a good idea if the system has been opened for awhile. I would do the 134 conversion since the system has been empty for awhile. Now would be the time.
65 Bonneville Brougham 4DHT 65 Grand Prix 2DHT......now parts 65 Catalina 2+2 2DHT 65 Catalina Safari 4DSW |
Appreciate the suggestions from both you and Ollie, I guess this is kind of my dilemma, should I just bite the bullet a put in a new vintage air system and be done with it. I see they do make them now for factory A/C cars, at least that way I would know it would work, plus I would still have A/C but with a lot more room in the engine bay. Big problem is that the car has sat for 12 years, and the A/C NEVER worked as long as I have owned it, so it's kind of a crap shoot. Thanks Stan |
