I've seen 90% quarter for 69s but are they available for 67/8s yet ???
67 Firebird Convert 455 +.060 TH400 74cc KRE d-ports piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.50 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s |
Checked with Dynacorn and they do not and will not be making these. Guess I need to find a wreck with the parts of the rear quarters I need to fix my trunk area.
you shoulda said something
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
Well I thought I had what I needed already. Will send you some pics of what I need to fix later this weekend once I have a chance to get everything all cleaned up. Also, still trying to get you an engine code for the cammer over here.
![]() Quote:
I could use everything off the front of motor tho including the fan and the idle speed up device on carb.
