This is not EXACTLY what you are asking for, but I think it will give you a general idea.
This is a basically stock 455, except a slightly more aggressive camshaft and a Performer Intake. Unported "66" heads with huge 114cc chambers, resulting in CR < 8:1 The first set of results were with stock "log" manifolds and 2" headpipes, which then fed into 2.5" pipes and to 3" Flowmasters and then to 2" tailpipes. On the second set, ignore the apparent "loss" below 3600 - I had to ease into the throttle to avoid making the tranny downshift.
'73 T/A (clone). Low budget stock headed 8.3:1 455, 222/242 116lsa .443/.435 cam. FAST Sportsman EFI, 315rwhp/385rwtq on 87 octane. 13.12 @103.2, 1.91 60'. '67 Firebird [sold], ; 11.27 @ 119.61, 7.167 @ 96.07, with UD 280/280 (108LSA/ 109 ICL)solid cam. [1.537, 7.233 @93.61, 11.46 @ 115.4 w/ old UD 288/296 108 hydraulic cam] Feb '05 HPP, home-ported "16" D-ports, dished pistons (pump gas only), 3.42 gears, 275/60 DR's, 750DP, T2, full exhaust |
John;
keep in mind that the #66 heads are 1971 L75 castings for an engine which had a gross rating of 325hp; Those heads are large valve heads... so stock vs stock they do have a slight edge over you http://www.wallaceracing.com/head1.htm
Thank you both for the info. Just trying to to do some comparisons. Thanks, John
