Steering box intermediate shaft
I asked this in the suspension section, but thought more folks here would have experience with the 69 GTO set up. I am having problems removing the intermediate shaft off of the steering column. I have removed the steering box and removed the bolt from the top collar that, I'm guessing holds the shaft to the steering column. I have tried pulling it off, banging it off with a mallet, and prying it off with a screwdriver to no avail. When I try wedging it off with the screwdriver I can get the shaft to move down, but when I release pressure on the screwdriver the shaft goes back to its original position. I even removed what appears to be a clip on the bottom of the steering colum thinking maybe it's keeping the shaft from sliding off, but it Has not, I still cannot remove it. Asking for help before I damage something.
Thanks. CB
1966 GTO Vert automatic. 1969 CR Judge Ram Air III 4sp Pattern Car. 1969 GTO standard 350HP TH-400. 2006 GTO Phantom Black 6spd. 1972 Formula 455HO Ram Air. 1976 LE Trans Am 50th Anniversary Edition with T top. 1976 Formula 350. 1977 Grand Prix Model J 350. 1978 Trans am 400 Pontiac. 1979 Trans am 403 Olds. 1968 Olds 442. 1971 TR6. |
Finally got it off. I had to put some penatrating fluid around the spline and let it soak in real good. Once it broke up all the rust and dried up grease I was able to wiggle/twist the shaft free.
There's a lip on the edge of the clamp that is deeper than the splines, so you have to remove the bolt and open the clamp up further than you'd think to get the shaft off the column.
