Old 07-08-2012, 10:43 PM
brockb455's Avatar
brockb455 brockb455 is offline
Default Question about 73 TA carb ports
I know the one on the left is the EGR port. What are the two ports on the right. (You do realize it is not polite to laugh at rookies?) I am sure one of them is the gas vapor port. This is an early 73 TA - first generation emissions.
BrockB
1973 Trans Am
Old 07-09-2012, 12:19 AM
Formulabruce's Avatar
Ill take a stab
just to left of Fuel inlet I "believe" goes to the Charcoal canister ( both my 73's did)
on right of fuel inlet goes to vac advance
Others can chime in please correct if needed.
Old 07-09-2012, 06:02 PM
brockb455's Avatar
Ill take a stab
I assumed the small nipple on the power brake port was distributor advance. Wrong? If not - what is it?
BrockB
1973 Trans Am
Old 07-09-2012, 10:59 PM
that is primary vacuum... Ac ductwork? Ill look through some stuff and see but... Im sure others can say exactly
Old 07-10-2012, 10:45 AM
MescaBug's Avatar
MescaBug MescaBug is offline
The dist vacuum advance connects to a tee at the back (brake booster).
Far left is EGR, far right is charcoal canister, left of fuel inlet is thermal spark advance valve.
Vacuum maze diagram
Old 07-10-2012, 11:54 AM
Great diagram, shows the spark retard ( that we can make look like its all working! lol)
Old 07-10-2012, 08:23 PM
Held for Ransom's Avatar
Held for Ransom Held for Ransom is online now
The two ports of the base plate, on the right side (everything is viewed as if you are sitting behind the wheel), are EGR relay (far right) and transmission vacuum modulator (center, right of fuel inlet). The one on the left goes to charcoal cannister (canister).
Back port goes to distributor vacuum advance relay switch (TCS).
ID:	290712   Click image for larger version
ID:	290713   Click image for larger version
Old 07-11-2012, 05:01 PM
brockb455's Avatar
Default Suppose I just left all this crap off?
I live in God's country (Texas) and don't have to pass any emission inspections. I replaced the original maifold with a non-EGR Performer. Also, when cliff rebuilt my carb we left off the EGR and auto-choke. I have all the emissions stuff saved in a box if I need it. What is the down-side to just connecting the vapor cannester and distributor and plugging the rest?
BrockB
1973 Trans Am
Old 07-11-2012, 05:04 PM
brockb455's Avatar
Default Another stupid question - fuel lines
The fuel and return hoses that run from the hard lines on the passenger side to the fuel pump on the drivers side - is there any bracket to hold them in place? How are they routed.
BrockB
1973 Trans Am
Old 07-11-2012, 11:23 PM
1973 underside, your fuel pump may be a bit bigger though............................................ .................................................. ......
LAST PIC IS UNDER A '74 'DUTY
Old 07-13-2012, 11:44 PM
brockb455's Avatar
Thanks for the info. It was very helpful.
BrockB
1973 Trans Am
