#121
Pictures really do help.
I should be able to make those changes without serious problems, I think. So the LARGE fins/crosses on the supports need to be 0.16" tall from the back of the plate? And the small locating lugs don't fit into the radio holes? What is the diameter of the radio holes? Are we sure there are no differences between the 70-77 models? Same radios and bezels fit in all those years? That lower radius bothers me ... that one you have now is based on a very accurate trace of a 70-77 radio bezel. Are we sure that the OEM part tracked the radius of the dash pad that closely? Dash pads aren't particularly uniform in their dimensions. If I change the lower radius it is NOT going to the be same as the OEM radio bezel. Anyone have any close up photos of how their radio bezels fit in those corners? One problem here is as the stand-off height changes, the dimensions of the hole the entire plate fits in will change (again the funnel scenario). For instance if I shorten the supports to 0.16" ... it will fit father into the dash pad hole ... where the dash pad hole will be smaller .... will the 1/16" reduction in height and width accommodate that? In the final analysis though, the objective is to make one that fits YOUR car.
I'm World's Best Hyperbolist !! |
#122
I've created revised files, while retaining the originals.
The lower corner radius on the OEM radio bezels is 0.625, changed our plate to 0.75" (bear in mind that the hard plastic parts are a fixed dimension, while dash pads shrink and change shape as the years go by, so I am keeping the original files also, in case we find that those corners are not uniform car to car) Reduced total height and width 1/16" Reduced the large fins on the supports from 0.30" to 0.16" (I am thinking about doing away with the locating lugs, I think they are causing more problems and confusion than they are worth. Is the 0.16" fin height based on those lugs NOT fitting into the radio holes? If so, then the height of the large fins needs to be slightly more than 0.16" ) Trying to decide whether to reduce the length of the attaching posts .. it's tapered, so the farther the plate sits into the dash, the farther you have to screw on the nuts, not sure if that will be a problem or not. I'll go ahead with this print if I can see some photos to gauge how the radio bezels fit into a 50 year old dash.
I'm World's Best Hyperbolist !! Last edited by dataway; 03-05-2023 at 04:14 AM. |
#123
You raise a good point that the dashes might be pretty inconsistent; both from original production tolerances and from shape changes caused by ageing.
The holes in my dash are boogered up by a previous owner to install an aftermarket radio (without a bezel) so I'm no help on that. If the factory bezel measures 0.625 on the lower radii, I'd go with that. Eric
The Following User Says Thank You to Elarson For This Useful Post: | ||
#124
Not sure if this is correct, but just looking at the pic I think the angle needs to be smaller? (which would change the radius?)
The Following User Says Thank You to johnta1 For This Useful Post: | ||
#125
The thing that really complicates this job is that the factory dash isn't a very precise piece. The sides for instance aren't truly a perfect straight line....there is an almost imperceptible curve to them. There's probably some rationale that molding plastic needs some soft corners and draft angles to keep from getting hung up on the mold.
I'm hoping that making the plate 1/16" smaller in both directions makes it less sensitive to the subtle tolerance and shape variations. Huge thanks to dataway for all of his patience. I'm hoping everybody appreciates the amount of effort he's put into this. Eric
#126
I would think that the proverbial wild card here is that the dash boards are fibreglass/plastic backed structure covered in vinyl;
This vinyl is prone to shrinking - and likely at openings this might make a bezel seem to not fit. I would bet that an original radio delete plate follows the dimensions of a radio face plate exactly.
The Following User Says Thank You to unruhjonny For This Useful Post: | ||
#127
I have a spare uncut 78-81 dash. I just measured the radio mounting depressions, 6mm and 13mm deep. I'd imagine the 70-77 would be similar, they just change the layout and size of the face. Or the samples would tell you the same.
The Following User Says Thank You to Trevor78 For This Useful Post: | ||
#128
Trevor, you would think they would be about the same, but I'm getting measurements more like 4mm from the 70-77 owners.
Eric, what I'm leaning towards right now is going to make one that fits your car and looks good. Since we have no original 70-77 to go by, just a 70-77 radio bezel, we have a certain amount of freedom. Now I'm wondering of your insert plate is going to fit the new slightly smaller plate. From Johnta1's picture it appears that the lower corner radius is not matching up on another car ... so that change is making sense, regardless of the radio bezel I traced. Now ... on to the supports, lots of various dimensions I'm getting for those. I'm going to do away with the center lugs, or make them a tad smaller so I know they fit into any radio hole. What about leaving the supports LONG and the installer trimming them down to position the plate? If you look at the photos from Trevor's post #40 ... the later model OEM plate has supports WAY longer than the measurement I'm getting from Eric, and way longer than the depressions I saw on the 70-77 OEM radio bezel. The PETG these are made of it pretty tough, not the easiest thing to cut or grind, so I'm not that keen on making them "installer modified" So right now, two questions for you Eric, are you confident that the 0.16" measurement for the large fins will get the plate where you want it .. WITH the locating lugs INSIDE the radio holes? And ... are both the radio holes depressed the same amount? (to be clear, the "locating lugs" are the quite small fins attached to the "top" of the large fins ... in the OEM application the top of the large fins seated in the depression OUTSIDE the radio hole, and the small locating lugs centered it IN the radio holes.) Next would be ... is the 1/16" reduction in height and width ... the TOTAL reduction in height and width, or do you mean 1/16" on all edges? (which would mean a 1/8" total reduction in height and width) This process gives me a bit more sympathy for companies making re-pop parts ![]()
The Following User Says Thank You to dataway For This Useful Post: | ||
#129
All good, I had one out for an unrelated reason and thought hmm, I'll measure that just for fun!
#130
![]() Quote:
#131
Comments added in bold.
#132
![]() Quote:
![]() Eric
#133
OK then, I will proceed with the new version with the changes.
1/16th smaller in total on height and width 0.75" radius on lower corners Going to go with 0.16 on the Large post fins, and do away with the smaller locating lugs. I think the post needs the support the fins provide to keep from snapping off. I suspect you are not the only one with messed up radio holes, so it makes sense to keep those attaching points as simple as possible. I'm going to assume that most people downloading the print files will be reasonably familiar with printing, and how to alter the files to their liking as far as the attachment method. The critical point will be how it looks, so the work on the plate shape and contours is worth it. Will print something out today and should have it in the mail tomorrow ... I do have a left over insert plate here I can check for fit. Revision 3 coming up ![]()
#134
The new print came out nice. But, going to have to print a new insert also. The 1/16" change isn't a problem, but the change in lower corner radius makes the fit there less than great.
But the inserts are very easy to print. I'll throw one in the box with the new plate. Eric, save the last plate I sent, and the insert ... maybe send them to someone else what needs a delete plate ... might work for them, might not ... I mean better than nothing if someone needs one.
#135
New insert fits nice. I'll get them in the mail Tuesday.
#136
![]() Quote:
think about it... I suspect you'll enjoy this mental image. ![]() |
The Following User Says Thank You to 242177P For This Useful Post: | ||
#137
Think about it a bit longer .... I'll give you a minute
![]() There are only two centering lugs ... four fins, two centering lugs (little projections on top of the fins) which were oriented vertically ... so turning the support 90 degrees would orient them horizontally ... so they would miss the trimmer holes ![]() Several pages ago I should have posted a diagram with all the features labeled so we'd all be on the same page with terminology ... probably would have sped this whole process up quite a bit .... I guess that's why people use parts diagrams ![]() Eric, latest version going out today.
I'm World's Best Hyperbolist !! Last edited by dataway; 03-07-2023 at 08:55 AM. |
#138
Watching waiting with anticipation...
The Following User Says Thank You to cnc For This Useful Post: | ||
#139
I didn't think it would take this long.
Dimension of the radio pocket depth is 0.17". Add to that the vinyl thickness of approx. 0.035" and glue thickness and any wrinkles. I would think the 0.30" height would be fine, 0.25" min. Radio hole opening is approx. 0.48", 0.45" width should be suffice. And, turning the stands to x's, instead of +'s would work too, maybe better.
So long, farewell. Last edited by Held for Ransom; 03-07-2023 at 10:35 PM. |
The Following User Says Thank You to Held for Ransom For This Useful Post: | ||
#140
Ugh. Assumed (I know, I know) the standoffs were symmetrical.
Figured the fins were centering the plate. In my defense, it was almost 2AM, and I can be an idiot with the best of them when tired. Yeah, yeah, that's it. ![]() |
