Old 06-26-2012, 08:26 PM
6 Grrrs's Avatar
6 Grrrs 6 Grrrs is offline
Originally Posted by GT182 View Post
I try and make do with what I have, I can't afford those high end cameras you guys have that make perfect pictures. And no, your probably thinking about someone else's GTO.
Originally Posted by Old Goat 67 View Post
UH, he's pulling your leg Grrrs.
Can't you feel the tug?
The bold'd part seemed a little serious from Gary. Just sayin'
Tod Hoffmann
1966 GTO Montero Red Hardtop - Holley EFI'd 462, KRE DPorts/Muncie 4spd
1990 Chevy 454SS pickup - Accel DFI/T56 6spd - Hot Rod Power Tour Long Hauler
1996 Chevy K2500 ECSB 'Poopy'
2002 Honda VTX1800C
2016 Cadillac CTS Premium
My project thread: http://forums.maxperformanceinc.com/...d.php?t=516826
  #122
Old 07-22-2012, 04:21 PM
goatmanmitch's Avatar
goatmanmitch goatmanmitch is offline
Finally got around to doing mine and it looks great. I only used one connector like tempest did in post number 17, which references post number 15.
Mitch Kunath
  #123
Old 07-27-2012, 09:44 AM
GT182's Avatar
GT182 GT182 is offline
Here's a better night photo thanks to a new camera......
Gary
Get in, ShuT Up, Hang On!
"Crusin' Is Not A Crime"
Keep yer stick on the ice.
  #124
Old 07-27-2012, 10:06 AM
Old Goat 67's Avatar
YEAH.
  #125
Old 08-05-2012, 10:19 AM
One step further.
http://forums.maxperformanceinc.com/...d.php?t=705426
  #126
Old 08-21-2012, 08:18 PM
fyrffytr1's Avatar
Hey Y'all,
I did the deed with my parking lights. What do Y'all think?!!
Name:	parking lights on 1.jpg
  #127
Old 08-21-2012, 08:51 PM
Not quite the way we had it envisioned Phil.
  #128
Old 09-06-2012, 09:42 AM
GT182's Avatar
LOL... might look better with the grills installed. We're just pickin on ya Phil.
Once you get the grills in you'll like it even more.
Gary
  #129
Old 01-19-2013, 10:09 PM
fyrffytr1's Avatar
I got the grilles in!!
Name:	GTO lights.JPG
  #130
Old 01-19-2013, 10:18 PM
GT182's Avatar
Lookin good Phil.
Gary
  #131
Old 01-19-2013, 11:33 PM
Now, dat's what I'm talking bout!
  #132
Old 06-03-2013, 09:45 PM
1967Tempest's Avatar
1967Tempest 1967Tempest is offline
Send a message via MSN to 1967Tempest
Charles[ Old Goat 67] and I have finally figured it out... maybe a total of 6 hours phone time.... you DO NOT need a jumper wire for the headlights and parking lights to be on at the same time. We believe this applies to the 65 as well as the 66 and 67 headlight switch. And, it could possibly apply to other body styles also. You need to look at your switch and see if terminals 3 and 5 have the factory copper strap connecting them. And please, check your switch in these other body styles and report back here on your findings. This will save everyone looking to do this a lot of headaches from Jack Daniels.
Now on with the show. And first off, make sure your battery is disconnected.
You need to pull the wiring plug off the switch. You'll see a slot next to the terminal to push the wire into the wiring block from the side that plugs onto the switch.Take a stiff piece of wire , or a small screwdriver, slide it up into the slot and pop the Purple wire out of the block. This will collapse the tab that locks the terminal in the block. Pull the Purple wire out from the wiring side of the block. Then pry the lock up so it will lock in the new position. Look at your disconnected switch and you will see the Brown wire is in the #5 slot, which has the copper strap that connects it to the #3 slot which is empty. #3 is where you insert the Purple wire's terminal. Make sure it locks or you'll have no connection.
And viola, you now have the headlights and parking lights connected together so they are both on at the same time. It seems GM had this all set up from the start. Then some dummy said no you can't do it. That's why the jumper was thought of but not needed. So there's no need for scotch locks or a piece of wire for the jumper. And you won't ruin your wiring.
Thank ya Charles, you Old Goat... I love ya man. Charles and his wiring schematics actually made this happen. And without you this wouldn't have happened at all.
My new Tempest Wagon needed a new head light switch as it was 45 years old... So I removed the purple wire from the harness with a small screwdriver. Then bent the catch tab back out alittle and installed it on the brown buss bar and it is great! Total time from start to finish was 20 minutes. 5 of which was trying to depress the pull lever release tab enough to remove the rod.
AWESOME fix and factory style mod!!!
Thanks Gary!!!
1967 Pontiac Tempest 2dr HRDTP Coupe 468 C.I. 500 HP 5 speed = FUN!!!
1990 Chevy Suburban R2500 Daily Driver
1986 Volvo DL245 Wagon.. Project car!!!
The Burb Files
  #133
Old 11-02-2014, 08:04 PM
SD421's Avatar
SD421 SD421 is offline
I just did this 15 min ago!!! and thank you! I didnt have to cut up my new wiring harness!!
Don
1966 GTO
1966 421-9.3-1 comp-Race Tec 23cc Pistons
1966 Tri-Power
1967 670 Heads
Pontiac "Highlift" TriPower Cam by SpeedPro
DUR 214 Int 224 Exh @.050 - 107 ICL
LIFT .445" Int .465" Exh
Tri-Y-Headers by Tribal Tubes w/ Goerlich Mufflers
1966 Muncie Wide Ratio 4-Speed
1968-72 Chevy 12 Bolt Rear End w/ 3.73 rear gears
  #134
Old 11-02-2014, 09:43 PM
GT182's Avatar
1967Tempest and SD421, I'm g lad to hear you guys like it. Actually it shoulda been done before they came off the assembly line. But better late than never.
Gary
  #135
Old 11-02-2014, 09:58 PM
SD421's Avatar
Thought I'd post some pics!
Thanks Again!!
Don
ID:	380757   Click image for larger version
1966 GTO
1966 Tri-Power
1967 670 Heads
  #136
Old 11-04-2014, 11:50 PM
GT182's Avatar
Yeah Don, looks great.
Gary
  #137
Old 05-24-2016, 09:31 PM
blue67gtoragtop's Avatar
blue67gtoragtop blue67gtoragtop is offline
Any concerns with this change shorting out the headlight switch?
  #138
Old 05-24-2016, 10:28 PM
No, as you should be running relays on your headlights as SOP.
I still need to do this to my 67 Tempest Coupe. FAIL.
The Burb Files
  #139
Old 11-07-2016, 01:46 PM
GT182's Avatar
Last Saturday (11/5/16) at the show in Rose Tree Park in Media, PA I explained to 4 guys with 67 GTOs how to do the mod. If they'd had tools with them they would have done it right there on the spot.... but they had to wait until they got home.
They wanted it done for the reason of safety at night, and that it also looks great at night.
Gary
  #140
Old 11-07-2016, 06:46 PM
Cool beans.
