#1261
No but that's how you cut the line, then soften it
#1262
Looking great, Bob (and Darrel)! It's moving right along!!!
69 GTO 400, 4-Speed, Matador Red 69 SCJ Mach 1 Mustang, 4-Speed, Drag Pack 72 Trans Am, 455HO, 4-Speed, Lucerne Blue 73 Trans Am, SD-455, 4-Speed, Brewster Green 73 Formula, 455, 4-Speed, Ascot Silver 73 Formula, 455, Navaho Orange Survivor |
#1263
Looks great. You guys have four months until the show. Remember it does not have to run. I've pushed more cars into that show than I have driven.
#1264
....and we've helped.
Some guys they just give up living And start dying little by little, piece by piece, Some guys come home from work and wash up, And go racin' in the street. Bruce Springsteen - Racing In The Street - 1978 |
#1265
...There won't be any pushing. This baby is going to get finished, but I appreciate the willingness to help.
The dash is mostly finished and back together. It turned out pretty nice I think. I have tried to identify and label all the wiring connectors that attach somewhere else, but there are still 4 or 5 wires that I can't figure out. I'll do a followup post on them later. MPD is off watching his grandson play baseball for the weekend so Mini Me pitched in today and helped. It was good to have her hanging out. Here's a few pics. Sent from my iPad using Tapatalk |
#1266
A question on the tach harness. The engine harness has a pink wire and a yellow with black stripe wire that drops out at the distributor. We plugged the yellow/black wire into the top of the unitized distributor. In looking at old pictures it appears the brown fused tach wire should plug in here. Is that correct, and if so is the yellow/black wire just left unused? Here's a picture of the unitized currently with the yellow wire and the old engine harness.
Also, does anyone have a dash harness schematic that is easier to follow than the service manual detailed wire diagram? Sent from my iPhone using Tapatalk |
#1267
1976 LeMans B09 Freeway Enforcer, 455/M40 Smokey 1977 Trans Am, 400/M21 Black/Gold Bandit. 44K actual miles 2017 Sierra SLT 1500 Z71 4X4 2019 Canyon SLT Crew 4X4 |
#1268
Thank you very much. That is helpful. I did a search, but skipped Glenn's old posts that came up because those were usually dark days.
Now if I could just find a dash harness diagram that even a coal peddler could understand. Thanks again. |
#1269
What do you need help with Bob?
#1270
Thanks for checking Mike. I have half a dozen or so loose connectors coming of the dash harness and it's driving me crazy not knowing what they are for so I can get all OCD and label them. I'm sure somewhere in the mix is power windows, power locks, intermediate harness, rear speaker harness, et cetera. I'll post some pictures of them. Darrell will probably know exactly where they go anyway, but I really have this problem with getting everything accounted for and identified.
I also have one broken pink wire....I'll stick some pictures up. |
#1271
Wire number one is a broken pink with black stripe. It is bundled with another pink with black stripe wire that goes to the flashers and a purple wire. Should there be two pink with black stripe wires connected to the same terminal on the flasher control?
#1272
One pink/black wire will also connect to the reverse switch. I have also seen the pink/black wire as a part of the tach harness that plugs into the center of the under dash fuse block.
#1273
Yes, there should be two together at the connector housing.
#1274
Bob does this help?
First photo is my 73 SD Formula automatic Second photo is my 72 T/A four speed (And yes that yellow wire by the distributor is the shaker solenoid wire that shouldn't be on a Formula wiring harness - I believe it was T/A only but the wiring harness makers don't know this) |
#1275
Steve, it was cheaper to have it on all wiring harnesses for the year/model. It was just taped/tucked out of the way.
#1276
Thanks so much for all the help on wire number one. The next one is a single gray wire with a black connector. It comes out near the radio and steering column wires, and it has a very short lead. My best guess is that it connects to the windshield antennae harness.
#1277
Cigar lighter lamp?
Gray is typically a lighting power wire.
#1278
My old bronze 70 Formula 400 had standard gauges and I wanted to convert them to rally gauges, so I bought a set of eBay. The dash harness came with the gauges, but they were out of a car with an automatic trans with a floor shift. There was a long single gray wire with a bulb socket on the end that plugged into the dash harness right near the radio. The long gray wire was for the shift indicator light on the console shifter. Since my car was a manual trans, I just unplugged the wire leading to the console. Maybe the gray wire shown in your picture is not used in your application.
ES13 - That seems very probably. It is dropping out of the harness with another gray wire that goes to the radio lamp terminal and as 77CAM points out the cig lighter lamp also has a gray wire. I also noticed this morning that the lamp for the heater controls and fuel/volt gauges are also on a gray wire feed.
#1280
my knee-jerk reaction was that it was for underdash lighting... so shift indicator bulb seems quite feasable.
