Old 09-23-2023, 02:29 PM
Good idea. Now that I think on it, the Ame's Tech could probably answer the question.
Old 09-23-2023, 09:28 PM
gtospieg gtospieg is offline
The piece for the grill support is 67 only, the pieces for under the headlights are for 67 only. The other pieces work for 66 and 67.
The Following User Says Thank You to gtospieg For This Useful Post:
  #103
Old 09-24-2023, 08:33 AM
Thanks, that's what I wanted to know. Unfortunate that they won't sell the splash shields alone.
Old 09-24-2023, 03:34 PM
I may have a set of splash shields. I'm not sure of the condition. I bought the kit you referenced for my current 67 project because I needed some of the other pieces.
  #105
Old 09-25-2023, 01:47 PM
ZeGermanHam's Avatar
I concur with this. These parts (below) are the only items in the C104G kit for '67 what will fit on a '66.
Since Dominc (RedDirtRoad) and I both have A/C cars, our panels also have the extra pieces of stamped steel that screw onto the larger main panels which the flexible rubber attaches to. I could be mistaken, but I don't think non-A/C cars have that extra stuff. They get the main large metal panels and nothing else, IIRC.
1998 BMW 328is (track rat)
The Following User Says Thank You to ZeGermanHam For This Useful Post:
  #106
Old 09-25-2023, 07:11 PM
Thanks for the clear photo. I see now that the parts you show with the tape labels are basically what I already have and I'm missing the rubber parts.
So the rubber parts are not needed except for on AC cars?
I'm going to remove mine to see how rusty they really are. I think that the one on the battery side has some rot.
Old 09-26-2023, 12:45 PM
Correct, you don't need the rubber parts on a non-A/C car. You won't even have anything to attach the rubber seals to unless you also get your hands on the additional metal pieces that screw into the bottom of the larger main panels, which are specific to A/C cars and are somewhat difficult to find.
But with all that said, if you are feeling adventurous and are willing to go on a treasure hunt, installing the full suite of A/C baffles and seals on a non-A/C car will still benefit your non-A/C car. When the front bumper is installed, it results in all the air being forced through the radiator core, which will benefit any car with or without A/C.
  #108
Old 09-26-2023, 12:55 PM
Beautiful. Great pics. That helps a lot and yes, I may fabricate that stuff. Thanks guys. I'm getting hyped about digging into this car after years of neglect.
Old 10-18-2023, 05:55 PM
RedDirtRoad RedDirtRoad is offline
I have the whole car stripped to bare metal and 2 costs of epoxy primer. Both doors are solid and no rust whatsoever. I need small patch panels in each fender and both rear quarter panels. The rear tail light panel looked good but after stripping it just has too many pin holes.
I got lucky and scored an NOS tail panel
Overall the car has very little rust issues and very solid.
ID:	621904   Click image for larger version
ID:	621905   Click image for larger version
ID:	621906   Click image for larger version
ID:	621907   Click image for larger version
  #110
Old 10-18-2023, 08:00 PM
MUSLCAH MUSLCAH is offline
Get that pick hammah out...and look for trouble.
Nice score on the tail light panel. I ended up buying one from Ames.
What’s a panel like that worth ?
  #111
Old 10-18-2023, 08:01 PM
  #112
Old 10-18-2023, 08:11 PM
Costs too much!
Last time I found one about 5 years ago it cost me 400 bucks
This time it was 700 but the guy was local and could not find another anywhere else
I heard a few guys were selling them at Norwalk this year for around 500.
  #113
Old 10-18-2023, 08:37 PM
Do the repros have the inner brackets that the taillights mount to or do you have to transfer from the old panel?
  #114
Old 10-18-2023, 09:05 PM
The repros are missing the wire loom holders for the taillights.
  #115
Old 10-18-2023, 09:13 PM
Ok but still has all the inner structure?
  #116
Old 10-18-2023, 09:27 PM
Yes...I've used 2 of them without issue.
  #117
Old 10-18-2023, 09:41 PM
6d7gto 6d7gto is offline
The front fender in the photo shown with patch panel is not that bad at all. I urge you not to use that patch panel! Fix the original and don't mess with that original body line. Ask me how I know!
  #118
Old 10-18-2023, 11:10 PM
Thank you for that tip and suggestions. I was planning on sacrificing that patch panel and just use what little I need to replace the rotted metal
I wasn’t planning on using the whole panel
In fact, the bracing behind it is in perfect condition
  #119
Old 10-18-2023, 11:26 PM
If that was my lower fender...I’d be flowing some lead in those punky areas. And if there is a brace behind it ...I carefully cut what needs to be removed to access the back side of the repair ( lead work ) and seal it up real nice on the back side. Then weld that brace back in.
Like noted above ...you won’t lose your factory lines/ gaps
  #120
Old 11-08-2023, 08:19 PM
Making some progress with the front fenders
All fitted up. Weld thru primer and welded up
1 fender down and 1 to go
ID:	623032   Click image for larger version
ID:	623033   Click image for larger version
The Following 2 Users Say Thank You to RedDirtRoad For This Useful Post:
