#81
Angelo,
Are you saying the factory A/F base clears all the fuel lines and bulges? As far as sitting on the throttle body. Not taking into account the height, just the fact that sits nice on top of the throttle body.
1978 Black & Gold T/A [complete 70 Ram Air III (carb to pan) PQ and 12 bolt], fully loaded, deluxe, WS6, T-Top car - 1972 Formula 455HO Ram Air numbers matching Julep Green - 1971 T/A 455, 320 CFM Eheads, RP cam, Doug's headers, Fuel injection, TKX 5 Spd. 12 Bolt 3.73, 4 wheel disc. All A/C cars |
#82
My 78 w72 air cleaner base does. Not sure if the 77-78 shaker bugle air cleaners clear or if the 70-76, but my 78-79 w72 fits on the fitech. I plugged the holes with machine screws and lock nuts and the vent hole I covered with fender washers crushed by a #10 machine screw and lock nut.
The fitech would not clear if you had to run a return line. |
#83
in your opinion would it fit if you massaged the A/F base?
#84
No, it would require some cutting and welding (more than just dimpling). But I think the blockers drop base may clear it, I contact them with measurements will see what they say.
#85
But if you use the fitech control module you do not need to run a return. I bet you could run anlow pressure electric pump to the fitechfuel center then you would be in business.
Did you install a high pressure fuel pump in the gas tank already? |
#86
Ok, I can live with a little cutting and welding...seems like you're saying the only place of concern is the one corner with the return and at least one of the other three(supply) clear.
#87
I really don't have room for the control center. I was going to use their inline fuel pump temporarily. Because I think the 600HP system is too borderline for me. I really want to use the 1200HP system so I can upgrade later. Plus they say the 1200HP system will run to 800HP with the in line fuel pump. So, now $1500 plus fuel supply, now getting close to the $2000.00 mark which now makes it not so competitive for me. It would be nice if you could buy the 600HP system and upgrade later but you really can't. Ultimately I would like to a legitimate 600HP motor. That puts me on the edge.
#88
The control center is not that big, but if you are pushing the 600 hp I think you're better served with the return line high pressure setup. I don't believe you can simply upgrade the FiTech, the different model is cast to house 8 injectors instead of 4, which is where the rated hp comes into play. Honestly I think if you start hitting that 800+ hp range you should be thinking about port injection or if possible, direct injection.
I'm almost done with my blog post and write up, hopefully finish it tonight. |
#89
I don't plan on ever getting to the 800HP mark. Just an honest 600HP.
#90
One thing to keep in mind is that at the 600 hp mark all the other tbi systems are running out of steam as well. So if you're going beyond that you're having to upgrade the other systems as well. The Go EFI 8 will get you enough headroom for 1200hp at still less coast than the competitors at 600 hp. It's not an apples to apples comparison.
#91
So far Ive heard nothing bad about these systems
-1967 GTO HO Restomod. PKMM 433ci, SilverSport T56 Magnum 6spd, Moser 9", SC&C and a bunch of other pro touring goodies - Build Thread http://forums.maxperformanceinc.com/...615847&page=23 |
#92
If I have this right, Angelo is running the factory intake with a Holley to Q-jet adapter which if it is the Edelbrock, is about .80" high. If you were to either mill that down to maybe .50" or use the 1/16" plate that everyone is talking about, it would seem that you could then use a .25-.375" air cleaner spacer to raise the air cleaner up off of the TP and end up exactly at the same overall height Angelo is at right now. The only question is if that would be enough for the air cleaner to clear the TB using a return line? I think we are going to need some pics.
I do have to say, I read the two Corvette Forum installs, two Pro-Touring.com installs and this one and no one has seemed to have any problems at all with getting their cars up and running well with overall driveability improved. All appearances are that the FITech owners who have posted their installs appear to be satisfied with their initial purchases which is more than I can say for some pretty hit and miss write ups on Fast, Holley and MSD. Still a bit early in the game though.
71 Formula 433, Splayed cap 400 block, 4" stroke Scat forged crank, 6.8 Eagle rods, custom Autotec pistons. SD 295 KRE D ports, Old faithful hybrid roller, Torker II, Holley Sniper Stealth, Tribal Tubes, TKO 600, 3.73 Eaton posi. Last edited by Formula8; 08-25-2015 at 02:55 AM. |
#93
My write-up of the installation: http://www.modsandrods.tv/2015/08/25...ject-trans-am/
Plenty of pictures, there are 2 videos, I have not tested them online yet but they should play ok. |
#94
Has anyone asked FItech about a individual port injector setup?
1963 Cat SD Clone (old school) streeter 1964 GTO post coupe, tripower, 4speed (build) 1965 GTO 389 tripower, 4 speed, driver 1966 GTO dragcar 1966 GTO Ragtop 1969 Tempest ET clone street/strip 1969 GTO Judge RA lll, auto 1969 GTO limelight Conv. 4speed go and show (sold) 1970 GP SSJ 1970 GTO barn find..TLB…390 horse?….yeh, 390 1972 GTO 455 HO, 4 speed, (build) 1973 Grand Safari wagon, 700hp stoplight sleeper 525ci DCI & 609ci LM V head builds |
#95
I think I read that may be coming in the future. At that point though you would just be buying their management software and wiring, all the other hardware is off the shelf gm parts as I understand it. There is some website that explains how to do port injection by yourself, though the fitech software and control module I think is worth the $1000 i paid for the whole system.
#96
Check out this site: http://www.diyefi.org megasquirt rings a bell as well.
#97
Angelo,
How do I get look at Randy's 3 gauge pod?
#98
There is a pic of the gauge pod map pocket not installed on this post: http://www.modsandrods.tv/2013/04/04...or-and-wiring/ and here: http://www.modsandrods.tv/2013/07/04...-for-may-2013/
Randy sold them a couple years ago for $48 shipped. Please message me directly and I will reply with his contact info. |
#99
Angelo,
Based on your write up it sounds like this system flat out works for a street car. I know you like the better driveability and cold starting. I am thinking about ordering up a system in the near future, any feedback on m.p.g. increases after installing the FItech system? I am curious to see if there is any help for my 462.
71 Goatman Hot Rods & Horsepower.......A diease for which there is no cure. 71 GTO, 463, SD 295 d-port heads, 10.75:1, RPM intake, 502hp/560tq @ the crank, 200r4, 10" Continental convertor, Bullet 234/244 cam, Cliff's Q-Jet, 3:42's w/Eaton True Trac, 5 Power Tours. New performance numbers coming |
#100
My mpg seems to have gone down. Will record my next fill up. May also be that I am driving more now that it's easy to start. I was having a lean condition before I switched to this fuel injection so I may have been getting good mileage because of that.
