Old 03-19-2008, 12:59 AM
TheLastNorell's Avatar
TheLastNorell TheLastNorell is offline
Default 71 LeMans
Original 350 .040 over, 363ci
stock ,crank, rods
#46 heads
1.5 rockers
Unknown cam, very lumpy idle (possibly 068 summit?)
Stock intake
Edelbrock 650cfm carb
GM HEI
AC delco wires
AC delco plugs
Cheap Flowtech full length headers
Home built cheap 2 inch exhaust exiting out the sides
TCI street fighter th-350, TCI 2500 stall Breakaway converter
Stock 8.2 10 bolt rear with 3.08's in an open differential
Suspension- stock except rear KYB gas adjust rear shocks, jacked all the way up
tires- 15x7 cragar ss's with 225/60/r15 bf Goodrich traction TA's
Weight- 3820 with me in it and about 5 gallons of gas
Gas mileage- about 12 mpg with my foot out of it (which is never )
Performance- Best run so far was 14.2 @ 94mph, 2.2 60' ,when it was about 38 degrees out side at Budds Creek MIR. This was with the old ignition system and burned out plugs & wires, and a completely blackened dist rotor that shouldn't have even been working.
It should run mid 13's with its recent tune up and the soon to come addition of limited slip
  #82
Old 03-23-2008, 06:35 PM
Scott Stoneburg's Avatar
Scott Stoneburg Scott Stoneburg is offline
1967 Firebird full interior,(racing buckets)
3550 race weight w/ 5gal. of fuel
462 w/ stock crank and rods, weisco flat top pistons
ported 62 heads flow aprox 258 on intake @.600
ultradyne cam solid roller .605 lift
port matched torker manifold(not a T II)w/ unmodified 850 holley carb.
th400 w/ tight 10" conv. (flash to 2800)
9" rear w/ 3.73's on 10.5 in slicks
Rally II wheels 8" in back 10.5" slicks
5" up front w/ 165s (narrowed by a local dirt track shop)
Best 1/4 mi. was...60" 1/8 et 1/8 mph 1/4 et 1/4 mph
1.52 6.88 102 10.66 128
  #83
Old 04-13-2008, 08:53 AM
Gordo's Avatar
Gordo Gordo is offline
Smile 1966 GTO 462
Here is my combo in my summer cruiser.
1971 455 YC 2 bolt block - bored 0.030, zero decked
Stock crank 0.020 0.020
Stock rods with ARP bolts
Forged TRW flat top pistons
Cam is the Hi-Tech version of the RA lV(Adv. 6 deg.)
Stock hyd. lifters
Heads - 6X-8's 2.11/1.77 Ferrea Valves(101 cc chambers)
Originally had the matched 66 heads, milled and ported for nitrous. Switched to
6X-8's after dropping a valve and destroying a piston
Bowls blended, ports cleaned by me
7/16" ARP rocker studs
Comp. Cam 1.65 roller tip rockers with ARP polylocks
Comp. Cam 995 springs installed at 1.7, 130 seat, 290 open
Stock retainers and locks
Edelbrock RPM intake
Holley 770 Street Avenger carb(out of the box)
Stock HEI distributor with Accel coil and 8.8 mm Accel wires
Electric fuel pump(Holley Red) mounted just in front of tank(set to 7 lbs with reg)
Hooker Super Comp headers into 2.5" dual flowmasters
M-20 4 speed
Hayes steel flywheel, 11" clutch(brand unknown as it came with the car)
Lakewood scattershield
Rearend: Original rear updated with 3.42 gears, posi, new axles and bearings
I have never run it at the track, but is a lot of fun on the street.
1966 GTO -sold
1966 Lemans -sold
1969 GTO - current project
1968 Lemans Convt - future project-sold
  #84
Old 06-15-2008, 04:57 PM
mjfitzz's Avatar
mjfitzz mjfitzz is offline
Default 1979 Formula 6.6, MT, WS6
My Firebird's current set-up, for street/club runs only:
Engine/Trans:
408 ci. code YT block (orig. PWH engine pulled)
Full windage tray, Melling select oil pump w/ 60 lb. spring
Stock crank oil holes chamfer, ACL bearings
KB flat top pistons, full float pins
Crower #60243 hyd cam, Crower lifters, custom push rods,
Edelbrock valve springs, Ferrea valves w/ 30 deg. seat, 1.5 roller rockers
Hayes flywheel, McLeod 12" clutch
Fully balanced, all bolts ARP
Stock Borg-Warner Super T-10, hi-po 1-2 synchro.
Induction/Exhaust:
Edelbrock 72cc heads, minor touch-ups
750 Speed Demon carburetor, annular boosters
Offenhauser split single-plane intake
Bosch Australia HEI ignition, 36 deg. all in by 3200 rpm
Hedman Hustler 1 3/4", 3" x 10" long collector, Pypes Violator 2 1/2", Pypes TA tips
Drivetrain/Chassis:
8.5" 3.73:1, Torsen-Gleeson differential (Detroit), Moser axles
Sub-frame connectors (welded)
New WS6 springs, Koni red shocks
Soft compound brake pads
235/70/15 BFG tires on 15x8 Snowflakes
  #85
Old 07-22-2008, 10:32 PM
Danimal's Avatar
Danimal Danimal is offline
Here's what I'm running:
original 1969 YS code 400 (+.040) = 408 CID
oil holes/casting ridges ground smooth for drainback/aligned honed
Original nodular crank, stock stroke, .010/.010.
Eagle H-beam 4340 steel rods 6.625 (stock length)
Speed Pro Forged pistons (coated skirts)
Arp rod bolts and main stud kit
Speed pro Rings
Factory deck -zeroed
Cloyes true roller timing chain
Clevite bearings (cam/main/rods)
rotate assembly balanced
Comp Cams XE-274 Cam .488/.491 lift/matching lifters
Harland sharp full rolller rockers. 1.5:1 ratio
Comp cams factory length pushrods.
edelbrock Performer Heads 87 cc/planed, slightly stiffer springs installed
10.6:1 compression
perfromer RPM intake/planed to match intake
Dougs 1-7/8" full length headers, 3 1/2 collectors, 2-1/2 mandrel bent exhaust, X-pipe
Holley 750 Vaccum secondary/dual feed carb
Pertronix HEI with Accel wires.
Moroso 8 quart pan
Factory windage tray
Brad penn break in oil (will be changed within next 3 weeks)
TH400 PX code (factory)
Rebuilt, shift kit.
2500 RPM stall converter
Factory open 8.2" 10 bolt with 3:23 gears
The carb is still out of the box tune and the timing will get played with once I change the break-in oil.
Still, with 6-year-old 215-65-15 well-used michelin radials on the back of this thing traction is only a dream.
Otherwise car looks like a well worn car that sat in a shed since 1983 (which it did)
Dan
Austin, Texas
Antique Gold 1969 Pontiac GTO YS400/TH400 3:23 10-bolt
2009 Pontiac G8 GT Maverick silver/Black Interior
1997 Chevrolet S-10
  #86
Old 07-30-2008, 07:08 PM
Talking
new times w/new top end
*67 firebird 3550 race weight
*462 w/ stock crank and rods, weisco pistons
*12.5 to 1 comp.
*ported e-heads flow 315 @ .600 w 250 cc port volume, 1.5 rocker ratio
*lunati solid roller 250@ .050 .605 lift using 1.5 rockers, installed 1 degree retard
*port matched victor manifold w/1" wilson spacer, 850 cfm unmodified holley, K&N stub stack
*2" hedman headers, 3" exhaust, "x" cross, and tail pipes
*th400 w/ 9" trans specialties 3500 rpm converter
*9"rear w/ 3.73:1 ,275-60 Drag radials, cal tracs
*leave @ 2000 against brakes/ flash to 3500, shift to 2nd @ 6500 and 3rd @ 6500
*new best
60' ....1.599
330"...4.371
1/8....6.698
MPH....105.04
1000".8.724
1/4....10.444
MPH....130.92
still lots of tuning to do....
  #87
Old 08-10-2008, 05:37 PM
Dr.Corvette Dr.Corvette is offline
Default 67 Firebird
I can finally post this as I finally got to dyno tune my Bird today.
1972 400 block. Stroker kit with 4.250 stroke. 6.8 Eagle H beam rods. 4.150 bore = 461 CID.
KRE 85cc d port aluminum heads with port job.
Intake flow peaked at 241 CFM @.550 @ 28in/H2O. Exhaust peaked @179@.550
SRP pistons Block zero decked. CR 10.4:1.
Comp Cams custom hydraulic roller. 230/242 @.050 on 112 LSA Valve lift .580 with Scorpion 1.6 rockers
Edelbrock Victor EFI intake. 1000cfm 4bbl. throttle body. 40 lb/hr injectors @40psi.
Accel DFI 7 controlling spark and fuel.
R.A.R.E long branch manifolds 2.5 outlet. Pypes 2.5 X pipe transverse muffler exhaust system. Dynomax muffler.
Car made 404 HP and 450 ft/lbs @ the rear tires on my Superflow chassis dyno. (stp correction factor)
  #88
Old 08-27-2008, 11:22 PM
aMaizedGoat's Avatar
aMaizedGoat aMaizedGoat is offline
Default 69 GTO
I have been waiting to post on this thread, but couldn't meet the 'qualifiers'.. until yesterday.
462 ci
Eagle rotating assy, Ross pistons
Edelbrock 310 cfm CNC ported for Custom Comp Cam hyd roller 230/236 112 lobe sep .565/.570 lift
Port matched Edelbrock Performer RPM
Manley 4130 Chrome Moly pushrods, PRW stainless steel roller rockers
Melling Oil setup, Canton Road Racing oil pan
Custom Cliff's Q-Jet
Oversized Ram Air Exh Manifolds, 2.5 mandrel bent exh system with X-pipe
TCI Super Street Fighter TH400, aluminum drive shaft, Moser 12-bolt posi with 33-spline axles.
I took the car to a local carb/dyno shop for some fine tuning and a couple of "light" pulls.
Results: 370 HP, 395 FT/LBS
The dyno numbers were at 5150 RPM. The motor only has 4 miles on it, didn't want to twist it up too much.
The HP curve was still climbing, about 20 hp per 500 rpm. Torque peaked at 4250 and was 3750 at 5150 rpm.
Cant wait to get it on the strip!!
Name:	IMG_0079 v2_1_1_1.jpg
  #89
Old 11-27-2008, 01:16 PM
superdutybob's Avatar
superdutybob superdutybob is offline
74 SD block bored +.030
Ross forged pistons with flat 12cc dome to achieve 9.5:1 CR
Stock SD rods bushed for full floating .912" Ford style pins
SD crank cut .010/.010 and polished
Comp XR288 HR cam 236/242 @ .050 - .520/.540 lift
Comp Magnum roller tip rockers 1.5 ratio
SD heads with mild bowl work and full maganese bronze guides and Viton seals
Ferrea 5000 series valves with Comp springs 130 on the seat, 350 open
SD intake manifold matched to the heads
SD carb tuned for the combo
SD exhaust manifold running into a Pypes Crossflow with 'X' pipe
SD distributor tuned by Rocky with Crane XR1 electronic conversion set to 6000 rpm limit.
Never had it on the dyno or down the track. Very happy with how it runs.
I have attached a photo for your viewing pleasure.
Name:	1974 SD-455 Trans Am 056.jpg
Bob Woodard
Brighton, MI
2012 SRT8 Charger - 12.70 @ 111mph
  #90
Old 02-02-2009, 11:09 PM
71 lemans sport 455 71 lemans sport 455 is offline
71 lemans sport
stock weight
455 40 over
1971 #96 heads
eagle crank
eagle rods
comp cam .507 .510
turbo 400 full manual reverse pattern
12 bolt 390 rear
m/t 275/60/15 drag radials
11.83 e/t
1.65 60 ft
111.4
  #91
Old 02-10-2009, 01:41 PM
dynoray dynoray is offline
Default my build up
here's what i'm working on for my 67 bird.mostly street,maybe occasional strip:
72 400,bored/stroked to 461
eagle crank/rods/venolia pistons/hastings moly rings/FM bearings/60 psi melling.
moroso pan,cloyes chain,new timing cover,flowcooler w. pump.
87cc edelbrocks,port matched,10to1 comp. comp.xr288hr hyd. roller,crane 1.65's manley pushrods.going to have a torker 2 intake,not sure on a carb yet.
thanks to Larry Hansen for doing all the machine work and balancing,and head work.enjoy,Ray
pics of car,another engine shot. thumbnails this time.
  #92
Old 04-13-2009, 01:35 PM
Fast Floridian's Avatar
Fast Floridian Fast Floridian is offline
1980 transam
72 455 bored .035
JE Sportman pistons, eagle H beam 6.625 rods
Moroso 8 qt pan, used 7 qts oil with now windage tray, stock oil pump
used doug herbert lifters and sd bore brace
Ported Victor removed clover leaf smooth radius to high ports
High ports 2.250 wide port, 4.50 high, bowls hogged,
hand worked the short turns,
Polished combustion chambers,
radiused exhaust seats,
Grumpy Jenkins 1100 dominator built by Pat at pro systems
balanced by dynastat balance
Custom comp roller, with 3/8 push rods
Redneck 9 inch converter, turbo action tranny t-400
cools with stock fan and stock 4 core radiator
makes well over 700 hp on pump gas
hooks hard on rallys and radials 275 60 15 mickey drag radials
10.5 to 1 runs on 93 all day
All under the dude scoop and looks and sounds stock
finishing chassis work this week should go low 10s 1st pass
ID:	165289   Click image for larger version
ID:	165290   Click image for larger version
  #93
Old 05-09-2009, 09:50 PM
hungry69bird hungry69bird is offline
69 firebird 3500 race weight (with me)
69 428+40
4 bolt main arp studs
stock pan, fitted crank scraper and full length windage tray
stock crank
scat H-beam rods
arias forged pistons (deep trough for valve relief)
#62 heads 260 cfm sd ported w/ferrea 6000 valves
comp cams 260/268 @ 50 650 lift w/ 1.5 rocker rollers. mechanical roller
crower lifters
chev studs rocker arm brace
sd mega brace
3/8 push rods
rpm intake port matched
850 holley dp
redneck built th350 with aftermarket sprag.
3200 conti stall
10.5 nova rear with 3.42 gears
caltracs mono leaf and bars
28 in nitto drag radials (still dont hook)
have not made it to the track yet but
thinkin i can hit high 11's easy enough if i can get some traction
on 5000 ft track
shift 6500 first around 6000 2nd and 6000 3rd
69 bird, 428 custom solid roller, rpm intake, #62 heads sd ported 260 cfm, 850 holley dp. arias pistons.scat rods redneck tranny, continental 3200 stall
  #94
Old 07-01-2009, 11:12 PM
656769gto's Avatar
656769gto 656769gto is offline
Default 65 GTO HT nightwatch blue
Here is my combo. Accually I stole it from Cliff R.
1970 455 4 bolt block - bored 0.030, zero decked
Stock crank 0.010 0.010
Eagle rods with ARP bolts
Forged Ross flat top pistons
Crower Cam 10919 at 108.5 icl
Stock hyd. lifters
Heads - Out of box Kre 85cc gasket matched
H/S 1.65 roller tip rockers
Butler pushrods
80 quadrajet Built w/ Cliff's book
MSD ready-to Run distributor
Stock fuel system w/ 5/16 lines. (bad)
Doug's headers into 2.5" Pypes x pipe and race mufflers.
TH400
10" Continental Jim Hand special
Rearend: Moser 12 bolt 3.42 gears, posi,
Tires- M/T ET street radials 255/15
First time out E.T. 12.70, 103 MPH. 1.73 Sixtyfoot
Still tuning.......
  #95
Old 08-07-2009, 06:36 PM
Danimal's Avatar
Here's what my combination posted on 7/22/08 (above) is capable of.
From a standstill at 1/2 throttle. in 98 degree heat. With a dinky, restrictive, 8" air cleaner.
http://http://www.youtube.com/watch?v=tGruoBavQmM
I'm taking it to San Antonio Raceway tonight to see what it runs, which, given the open dif, 95+ degree temps, and restrictive intake, should be a worst-case scenario.
Any bets on what it will run as is?
FYI, the rear tires are now 5 year old Michelin Hydroedges - 215/70/15.
Dan
Austin, Texas
1997 Chevrolet S-10
  #96
Old 08-22-2009, 09:42 PM
NeighborsComplaint's Avatar
Here is mine. Just finished and started. Some parts are a little dated as the motor was built by me about five years back and stored. Just got back into it and got it going.
'74 455 Block bored 0.040" over.
'73 SD rods, forged Speed-pro pistons
Stock crank cut 0.030"/0.030", oil holes chamfered, polished, balanced
'76 6X-8 Heads, bowl-hogged and cleaned up, light pocket porting
2.11/1.77 valves/Comp 1.52 magnum rockers
Crane double springs and retainers 1.70" Installed height
Crane 234/242 .488"/.505" cam
Holley SD intake, 770 Holley avenger
Mellings M54D oil pump, full length windage tray
8 Qt Moroso oil pan
HEI converted to mag trigger, 6L MSD box
Holley red pump, 3.8" lines
Drove it around the block a couple time. Sounds bad-ass, jerks the nose of the car pretty hard. Too early to tell. Drained the old fuel but the tang and pickup keep clogging. Just replaced the tank and blew out the lines, finishing up shorly.
  #97
Old 10-11-2009, 02:59 PM
ta man ta man is offline
Default My current combo 2009
462 stock crank,stock rods,trw pistons bought rebuilt from previous owner
SD 290 cfm KRE 85cc heads
Dave's old faithful cam installed at 108
Harland Sharp 1.65 rollers
Torker 2 intake with 3/4 open wood spacer
Holley 950 hp
3/8 inch lines with a Mallory 140 pump
WFO shaker assembly
HEI with a MSD 6AL
Continental "Jim Hand" 10 inch convertor
TH 350 with manual valve body
3.42 posi
1 3/4 Hooker Super Comp Headers Pypes 3 inch X crossover, 2 1/2 ultraflos,2 1/2 tailpipes
Stock suspension with air shocks in rear
Car idles at 800 rpm runs on 89 octane
Ran 11.882 at 114.59 with a 1.703 60ft through the exhaust Sept.25/2009
  #98
Old 10-11-2009, 03:13 PM
1972GTOmachine's Avatar
1972GTOmachine 1972GTOmachine is offline
Hi guys,
Here's my combo:
*My car specs are:
-Pontiac 1972 GTO.(all steel)
-TH-400 aut trans.(1972)
-10 Bolt , 3.08 gear.(1972)
*Engine specs:
-Pontiac 474ci engine.(455ci,1972).
- 4.250" Ohio crank.
-6.800" Eagle rods.
-Forged CP pistons
-Edelbrock alu heads 87cc (out of the box).( i want to let them porting)
-Edelbrock Torker 2 intake (Wenzler street tunnelram , with 2x edelbrock 600 cfm carbs on top.)
-Holley street avanger 870cfm.
-Crane Hydrolic roller cam special:
0.50@ int dur :242 degr , exh dur:252 degr.
Power-range:3000/6800rpm.
-Continental 10" stall converter 3000/3200 rpm
-NOS cheater kit 150/250 hp.
-Manton Custom's pushrods.
-Crane hydrolic roller lifters.
-Mechanical Carter fuel pump , 120gph
-10.25:1 compr.
-Harland/Sharp 1.5 roller rockers.
-Doug's headers.
-Flowmaster 40 serie mufflers.
-rear tires are 295/50R15 BF goodrich radials.
*On the chassis-dyno:...............406 HP , and 604NM torque .(without Nitro!!)
Eddy
  #99
Old 10-16-2009, 12:02 PM
Baz's Avatar
Baz Baz is offline
Send a message via MSN to Baz Send a message via Skype™ to Baz
79 301 ci engine from my 79 Firebird.
The engine is nearly stock, there is no big performance modification on it.
Here the parts I replace :
- Melling high pressure oil pump : MEL-M54DS
- Melling oil pump shaft : MEL-IS-54A
- Milodon High volume aluminum water pump MIL-16281
- Stainless water pump plate and pipes with grommets from the seller "ozpont" on ebay.
- Cloyes timing gears and chain : CLO-C-3027K
- Fel Pro gasket set : FEL-FS8532PT
- Viton rear main seal (ebay).
- Federal Mogul bearings.
- Sealed Power pistons rings : SLP-E-251K
- Comp Cams valve locks : CCA-601-16
- Comp Cams 252H camshaft : CCA-51-229-3
- Rocker arms Comp Cams CCA-1251-16
- Sealed Power Valve springs : SLP-VS-521
- Sealed Power lifters : SLP-HT-969
- Proform 66402c chrome moly push rods : PRO-66402C
- Mr Gasket carb adapter : MRG-1932
- Holley 4160 1850c 600 cfm Carburator : HLY-0-1850C
- Holley fuel pump : HLY-12-837
- Ansen aluminum valve covers
- Proform HEI upgrade kit : PRO-66945BKC
- Moroso ignition wires : MOR-73220
- R&M ignition wire loom : RNM-1110-90-K
- Proform black air cleaner : PRO-141-690
Arp fasteners :
- Camshaft bolt kit : ARP-190-1001
- Timing cover & water pump bolt kit : ARP-190-1502
- Damper bolt kit : ARP-190-2501
- Engine bolt kit : ARP-190-3102
- Cylinder heads bolt kit : ARP-190-3607
- Intake manifold bolt kit : ARP-194-2001
- Rods stud kit : ARP-194-6001
- Oil pan bolt kit : ARP-200-1802
Note :
I've buy ARP rocker arms stud (ARP-135-7101) to convert the stock valvtrain to an ajustable (chevy like) valvtrain.
I also buy Mr Gasket polylock nuts (MRG-921G) and some guideplates (on ebay).
But i still don't have install these parts.
http://www.chezbaz.fr
  #100
Old 11-24-2009, 06:50 AM
KARGUY KARGUY is offline
1965 GTO
3650 Lbs w/driver
461 (400 stroker) 2 bolt mains w/stock bolts
310 cfm CNC by KRE Aluminum d-ports -9.9 compression
Torker 2 w/750 Holley DP
1 inch Wilson tapered spacer
Comp cams 242/248 XE Solid roller
1 3/4 x 3" dougs headers w/3" x pipe
T-400 w/10" 3600 Conti
3.73 12 bolt
275/60 MT Drag radials
10.94 ET
121.85 MPH
1.53 60 ft
KARGUY
