Old 08-05-2011, 10:29 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is online now
I think even the one I posted still has the long inlet and get in the way of the bracket, I think the side fitting pumps would be the best deal also .
Illinois Outlaw Gassers
6.27@107
9.97@131
  #62
Old 08-14-2011, 02:05 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
Originally Posted by Rocky 389 View Post
... Enough to weaken the mount?
I don't think so. I'll try to remember to take a look at the mount.
  #63
Old 04-15-2013, 08:49 PM
I picked these up the other day, I couldn't get the originals but these duplicates are identical except for the holes not drilled for the biscuit mounts. The straps bolt to the backside of the flat area and go to the head. These are the 2nd style mounts for the later side mount engines.
I won't be using the first style mount on my 455 going in. I'm debating how strong these will be, previous owner of the original set had a 389 in a 55 Chevy .
One little thing I changed per Bill Hanlons front seal upgrade article was a newer style seal. The seal in the article went all the way through the cover, but I used a more common type that had a metal flange on the front. I had to remove some of the flange for the contour of the front cover so It would sit flush.
ID:	319921   Click image for larger version
ID:	319922   Click image for larger version
6.27@107
9.97@131
  #64
Old 04-16-2013, 08:53 AM
Teej's Avatar
Teej Teej is offline
Just so I'm picturing this correctly, these utilize the square flat areas to mount to the front frame spot where the previous engine had the timing cover mount. The longer edge bolts to the 61-up style mounts on the side of the engine.
(Or am I backwards?)
Thad
1958 Chieftain Safari (370,4 spd, 9 passenger) Daily Driver
1966 Bonneville Wagon (Factory 421,3x2,4spd, 9 passenger) On the road!!
  #65
Old 04-16-2013, 09:21 AM
The longer edge bolts directly to the side of the block.
6.27@107
9.97@131
  #66
Old 04-16-2013, 03:57 PM
Teej's Avatar
Interesting... So are these still produced, or who made those? (And where do I get a set?)
Thad
  #67
Old 04-16-2013, 04:05 PM
No one makes or sells these anymore. I was told the originals like these were purchased thru Honest Charlies back in the day. They were designed/sold by Hurst , but I think they subleted some of there work out and may have some small variances like the early mount. I may make some copies of these myself.
6.27@107
9.97@131
  #68
Old 04-17-2013, 09:09 AM
Teej's Avatar
If you do, I'd probably be interested in a set. No hurry, I'd just toss them on a shelf "just in case".... My 370 is running great these days!!! (Knock, Knock)
Thad
  #69
Old 04-19-2013, 06:01 PM
I've got one of those I've had for years. I never knew what it was. I suspected it was early car because it came with a bunch of 60-62 stuff I bought.
Are the old Mallory Rev-Pol distributors worth anything? I've got one of those as well.
Mike
  #70
Old 04-20-2013, 10:31 PM
grrowl grrowl is offline
Hi guys. Just wanted to chime in on the 61 thru 67 Hurst mounts. I have a set of those that I've had for many years. I'll post a few pictures here. I also have the brackets/mounts for the 55 thru 57 Chevy. I'm only missing the support brackets that go from the mount to the head. The box is long gone though.
I'm sure I'll never use them. If you're interested in them PM me.
Thanks, Jim
BTY there is a set on EBAY right now.
ID:	320537   Click image for larger version
ID:	320539   Click image for larger version
ID:	320540   Click image for larger version
  #71
Old 04-20-2013, 11:34 PM
REEDRACER's Avatar
REEDRACER REEDRACER is offline
I bought a NOS set of Hurst mounts for later engines still in the box and instructions on Ebay. I used the set for my Model A Gasser, Pontiac power. Also found Hurst mounts only, chrome plated on Ebay as well and picked them up. They are out there and really cool to have in your car!
69 Judge RAIII 4SP 2ND OWNER
63 Catalina 421HO 4sp
73 Trans Am 455 4sp
http://www.sdperformance.com/
Drag racing. An adrenalin rush like no other. It felt like going into combat, tasting your first beer, and losing you virginity, all in about 8 seconds.
  #72
Old 08-10-2013, 10:52 AM
ClassicDriverMan's Avatar
ClassicDriverMan ClassicDriverMan is offline
Hello Bill,
Would you happen to have the part number of that seal you used with the flange? Would appreciate it.
Thanks!
Tribal Tube Header Rip Off Victim. Ordered March 27, 2012. Told 3-4 weeks. Still waiting
  #73
Old 08-11-2013, 03:15 PM
No I don't, they came with the gasket sets I used from Mr. Gasket, Felpro and Butler performance. I couldn't get a number off the seal in the 60 cover.
6.27@107
9.97@131
