#61
Looking good!
George |
#62
Hello Bub,
Any new updates? I am sure you are busy this time of the year. James |
#63
Update
Bub
1974 400 4 speed |
#64
Man can't wait to see the updates.
#65
Update - 1/15/08
Finally finnished painting the center section and axle tube and painted all the correct markings like I found after I pressure washed it. I have one mark to add to the bottom of the center section. Its the letter "G" painted in white. I'll add that when I put all the new brake hardware, shoes, bearings, seals and emergency brake cables on.
1974 400 4 speed |
#66
Looking great Bub,
I need to come see it. My wifes family lives all over New Orleans. Edgard,Covington(North shore),The Quarter,Vacherie(Cane fields) and a few others cities as well.We are there a lot it seems. I gain 10 lbs every trip yeah! I have a few buddies as well that worked at Salsbury Dodge. Keep it up!
Nothing is impossible if you break it down into possibilities. It's all a matter of "Want to". |
#67
1974 400 4 speed |
#68
Frame Update 1/22/08
Wire wheeled, Sanded and blasted the frame. Ready for a good coat of epoxy primer. Some before pics...
1974 400 4 speed |
#69
Frame update continued....
After wire wheeling sanding blasting the final prep before prime.
1974 400 4 speed |
#70
Epoxy primed. Ready for some Black frame paint..
1974 400 4 speed |
#71
Bub,
I looks like I have a wedding in Vacherie the weekend of April 4th.I will let you know a little closer to the date...if you will be around. Its lookin good!
#72
1974 400 4 speed |
#73
Progess update 2/8/08
Painted the frame and started the blasting and sanding of the upper and lower control arms. Here is a couple of before and after shots of one of the uppers. Framed pictures to follow............
Comments on the color of steel look around the ball joint. To dark or ???? Bub
1974 400 4 speed |
#74
Continued....
Frame pics and the lower control arm paint line. Misc picutes...
1974 400 4 speed |
#75
More............
1974 400 4 speed |
#76
Looking great Bub!
What paint are you using on the frame and related parts? Thanks, James |
#77
Bub,
This may seem simple but be sure to clear the unpainted metals. They will rust/discolor and look like ***** the first time you wash the car. That goes for all the unpainted engine components,Brake calipers,fasteners,bushing washers etc. Go for a satin to flat clear so it will not be obvious.For the items that you want to stay cast iron looking Martin Seymour makes a great product called "Cast Blast" that keeps its color well. But clear over that as well for insurance. That was one of my many mistakes. Had to refinish and clear a lot of small parts that I just forgot would rust. A little clear was all it took. Great job on the upper A arms!
#78
1974 400 4 speed |
#79
Update 2/11/08
Sand blasted, primed, and painted the trans mount. Also painted the engine mounts. Sand blasted springs, upper and lower control arms, spindles,
Starting Tuesday I will be on vacation for 9 days. All dedicated to the car. My goal is to : A) complete the sub frame. including painting remainder of pieces and install the front suspension. Just ordered all new moog tie rod ends drag link etc...to complete. Already had the complete front end bushing kit. b) Finish sanding the underbody and cowl areas then prime, paint with brown oxide primer and satin black on the cowl and top dash area. Matched the brown from a piece of quarter panel that I cut out. Perfect match. c) Once B is complete and dried. Install leaf springs and rear end. Looks like a ton of updates are on the way....Stay Tuned.........
1974 400 4 speed |
#80
Painted Trans Mount 2/11/08
continued....Included in this segment is the motor mount painted.
1974 400 4 speed |
