Old 05-30-2016, 09:41 AM
Boostedbird's Avatar
Boostedbird Boostedbird is offline
Good luck Charlie!
  #42
charlie66's Avatar
Originally Posted by BruceWilkie View Post
Build your plenum so you can easily add more. I stated 1.5 x engine displacement...I'd start there.as a minimum. Test and add space and see what it does for you. Pypemax runner length factors the distance from valve center to manifold face.
Bruce, can you tell me how to figure out and calculate intake runner area? Im trying to fill out this calculator over here... http://www.rbracing-rsr.com/runnertorquecalc.html
Thanks.
I couldn't find the pypemax site..
My Half AN Injun.....
  #43
Old 05-30-2016, 09:53 AM
charlie66's Avatar
Talking
Originally Posted by Boostedbird View Post
I would have loved to seen that! I like the new Vettes, but most of them guys are really cocky! After the track last night my buddie with the turboed LS Mustang put 3 lengths on a new nitrous Vette that money races around here. That guy has a mouth on him. It was great to see him get smacked on his own road! Sorry! Back to plenums!
That's why when im out I don't say anything. I just smile and say lets go.. Believe or not I haven't lost any roll races yet, and I've raced a lot of cars so far with this lill 4 banger... lol
I did not meet this guy but im sure he was cocky, the good part that I will never see is im sure his friends were all busting on him later on! lol. I bet they will be looking for me next time out...
I bet you and your friend were laughen your azzes of after he smoked that loud mouth guy.. . haha
  #44
Old 05-30-2016, 09:54 AM
charlie66's Avatar
Good luck Charlie!
Thank you sir.
  #45
Old 05-30-2016, 09:56 AM
Noone but his friends can stand the guy! His name is Waffles, so now he's pancakes, hotcakes, Ihop....Lol!
  #46
Old 05-30-2016, 10:00 AM
charlie66's Avatar
Now when talks shi$%#t you can just call him a loser to his face and laugh at him ... That will most likely turn him red .. hahaha
  #47
Old 05-30-2016, 10:17 AM
PipeMax
Hopefully Larry's new version will be out.
Supposed to be greatly improved and also power adder ability.
  #48
Old 05-30-2016, 02:18 PM
charlie66's Avatar
Can someone tell me if im doing this right.. Im trying to calculate my optimum runner size for my peak toque rpm. I measured my intake gasket height and width 2.335h 1.200 w. x"s it by 2 and came up with 2.802 . My dyno sheet says I made peak torque at 5750 RPM. This calculator says my optimum runner intake area should be 3.22. Im only at 2.80. Am I doing this right? Heres the link.... http://www.rbracing-rsr.com/runnertorquecalc.html
  #49
Old 05-30-2016, 03:23 PM
Yes, you are doing it right.
  #50
Old 05-30-2016, 05:39 PM
charlie66's Avatar
thank you.
what do you think of these links ?
http://www.enginebasics.com/Advanced...%20Length.html
http://www.gnttype.org/techarea/turbo/turboflow.html
http://www.musclecardiy.com/performa...mance-engines/
http://www.enginelabs.com/engine-tec...ake-manifolds/
http://www.team-integra.net/forum/bl...culations.html
  #51
Old 05-30-2016, 07:01 PM
charlie66's Avatar
See how the runners are cantilevering into the plenum? Is this a better idea then having them flush?
  #52
Old 05-30-2016, 09:28 PM
Tom Vaught's Avatar
Boost Engineer
1.3" wide x 2.45 gets you 3.185" area. Basically .100" wider and .100" taller.
Tom V.
  #53
Old 06-05-2016, 07:29 AM
taff2's Avatar
taff2 taff2 is offline
I used a dual quad Offy manifold for my combo,grinding out the runner dividing walls to make one big manifold plenum-similar to a blower manifold. My carb box/hat/plenum is also pretty big(not as big as I would have liked it but it had to fit under the hood) so that the velocity of the air going into the box is slowed down and converted to pressure over the carb inlets. Driveabilty is good ,as is fuel distribution, but footbrake launching is tricky with the big plenum and a tight converter.
  #54
Old 06-05-2016, 09:03 AM
JSPONT's Avatar
JSPONT JSPONT is offline
Do you have a photo??
  #55
Old 06-05-2016, 11:01 AM
Tom Vaught's Avatar
Boost Engineer
I spoke with Marty Palbykin for about an hour yesterday and he said that the original Pontiac 406 cid Intake with the large volume was boxed and stored away and would be very hard to locate, open the box, take pictures, post pictures, etc.... So it is not going to happen.
Tom V.
  #56
Old 06-05-2016, 01:43 PM
charlie66's Avatar
Is it a 2 plain?
  #57
charlie66's Avatar
Thanx for trying Tom.
  #58
Old 06-05-2016, 02:08 PM
charlie66's Avatar
I have a question for everyone In regards to whether or not my plenum is too small. When im on the break tying to build boost , what happens is the needle on the gage shakes really bad. It moves back and forth from 1 to 6 psi until it gets to 10 psi where it goes dead steady all the up from there. My question is , is it that the plenum doesn't have enough area for the air , so as the pulsations from each valve closing pushing back to the next valve pushing back is shocking and disturbing the small area of air in the plenum where if it was larger it would have more cushion with less disruption , almost like tossing a rock in a small body of water and having more disturbance then it would in a big body of water.
My friend has a 2JZ motor running the same amount of boost and his needled is steady from 1 psi all the way up. He has a plenum that is 1.5 the size of his ci. Mine is around .75 of my cubes.. So what do you think?
  #59
Old 06-05-2016, 07:52 PM
taff2's Avatar
Single plane manifold with a big open runner between the carb plenums. Before and after pics. Carb hat/box halfway through construction.
Name:	Offy manifold modified.jpg
ID:	429974   Click image for larger version
Name:	Offy manifold.jpg
ID:	429975   Click image for larger version
Name:	carb box pics 015.jpg
ID:	429978   Click image for larger version
Name:	Head pics,nick bike,intercoolers. 008.jpg
ID:	429979   Click image for larger version
Name:	Head pics,nick bike,intercoolers. 012.jpg
  #60
Old 06-05-2016, 07:57 PM
Tom Vaught's Avatar
Boost Engineer
A bigger volume will dampen the pulsations for sure. Was the engine doing the same thing before you went to the bigger turbo?
Tom V.
