Old 06-26-2008, 02:10 AM
pontiacpark pontiacpark is offline
Greetings guys from the "land of the long white cloud'. i see it stated in a lot of listings that the pontiac V8 GMC half ton trucks are rare. as a matter of interest guys, anyone know how many of these trucks were built in their respective years?.
  #42
Old 06-26-2008, 02:57 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
I've never seen any production totals for the V8 option in '55-59 GMC trucks. The V8 apparently wasn't extremely rare, but the great majority of pickups those years had the GMC six-cylinder. In my locale, I probably saw around a dozen new '55-59 GMC pickups back then, and none had the V8.
  #43
Old 08-24-2008, 01:20 AM
I'm getting closer to being able to say that my '59 GMC is "totally disassembled". Now that the cab is off, it shouldn't take me too long to take the chassis apart.
ID:	140878   Click image for larger version
  #44
Old 09-02-2008, 01:54 PM
Bill Hanlon's Avatar
Default Headers?
Jack: What are you planning to use for exhaust manifolds on your '59? If not stock, have you done any actual test fitting? Gary in Katy is too shy to ask.
  #45
Old 09-03-2008, 02:29 AM
Bill- I'm using R.A.R.E.'s repro longbranch manifolds with 2.5" outlets. It will be "interesting" to see if the left one clears the steering box as I believe it will! Before removing the 350 Pontiac that was in it, I did a bunch of looking/measuring in that area- looks like it will be close, might need to "fiddle" with engine position a little. The trans crossmember will need to be replaced by a fabricated one that drops straight down from the frame rails, to clear the headpipes. The longbranch manifold exits aim directly at the stock crossmember!
  #46
Old 11-10-2008, 01:54 PM
rwolf rwolf is offline
I am putting a 1960 389 in my 59 gmc that has the factory 336 in it. I am trying to find some headers that will clear the factory steering box and starter. Any ideas? Also I have a hydromatic that came out of the 60 catalina that I got the motor out of that I was thinking of putting in my GMC but I don't know what I could do for a shifter, any ideas.
Thanks for all the great info I have been reading about.
Robert
  #47
Old 09-25-2010, 03:12 AM
Default A couple of major pieces done...
Frame sandblasted and powdercoated. Not shown- sixty other chassis pieces powdercoated.
Cab metal/body/paint work all done.
ID:	219519   Click image for larger version
  #48
Old 09-25-2010, 07:53 PM
Bill Eveland's Avatar
Bill Eveland Bill Eveland is online now
Looking good Jack, did you ever find the trim piece for the bedside?
Illinois Outlaw Gassers
6.27@107
9.97@131
  #49
Old 09-25-2010, 10:23 PM
Bill: I'm surprised he hasn't made the trim pieces.
Don't you have a solid front axle on your '55? If so, you ought to see what he just did to the front axle on the truck. http://oldgmctrucks.infopop.cc/eve/f...36/m/776109227
  #50
Old 09-26-2010, 03:06 AM
Yes, I finally found three SS trim pieces for the bedsides. They were somewhat mangled- paid a professional trim restorer about $300 to "renew" them. Bedsides are all restored/painted/assembled/wrapped, as is almost everything else for the truck.
  #51
Old 09-26-2010, 10:20 AM
Bill, link doesn't work without being registered.
6.27@107
9.97@131
  #52
Old 09-26-2010, 11:13 AM
From Jack's post over on OldGMCtrucks.com ....
I finally received the Torrington bearings I had ordered. Measurements of all the pieces confirmed that I needed .018" more "space" for the axle-end/bearing combo. I milled the .018" from the tops of the axle ends, since trueness/squareness of that surface isn't as critical as the bottoms. Nevertheless, I got the tops true to about +/- .001". Assembled end play is .001" - .002", well within the .005" limit stated in the shop manual (with no shims). Everything went together good on a trial assembly, but needs to come all apart again for powder coating. Short pieces of bicycle inner tube make nice dust covers for the Torrington bearings, and should be more effective than the "umbrella" style shielding of the original bronze/steel thrust washer package.
Here's a photo of one of the Torrington bearings with its two .095" thick hardened steel races. The other picture is one kingpin assembled, complete with bicycle inner tube "boot" around the Torrington.
ID:	219643   Click image for larger version
  #53
Old 09-29-2010, 02:54 PM
Rocky 389's Avatar
Rocky 389 Rocky 389 is offline
My buddy, Chris has this 56...runs a [cough] small block chevy! I'm trying to talk some sense to him.
Name:	Chris Hays GMCsmall.jpg
Roll around in the excitement
  #54
Old 09-30-2010, 01:11 AM
Originally Posted by Rocky 389 View Post
... I'm trying to talk some sense to him.
Keep talking!!!
  #55
Old 11-22-2010, 03:30 AM
Finally actually ASSEMBLING some stuff! Rolling chassis is pretty much done- just need to finish fabricating the torque arm for the rearend housing.
  #56
Old 12-15-2010, 01:57 AM
Uphostery shop just finished the seat. High quality workmanship from Rancho Upholstery in Geneva, NY (Robert Monica).
[Sorry 'bout the low-resolution picture]
  #57
Old 01-12-2011, 02:22 PM
SteveGB21's Avatar
SteveGB21 SteveGB21 is offline
Send a message via Yahoo to SteveGB21
Default A 57 GMC pickup.
Although I don't own the truck (yet), wondering if it would be best if I used the factory engine frame mounts for a Pontiac powered engine, but then upgrade the engine for a '69 and later block. Or, would it be best to come up with something from scratch?
  #58
Old 01-13-2011, 02:55 AM
To put a '69 engine into '55 - '59 GMC, some of the mounting will need to be "from scratch" no matter how you do it. I can't really recommend one over the other, but you have two basic routes:
1) 3-point, the way the GMC V8 was mounted- single front mount with two mounts wide-apart at the bellhousing.
2) 3-point like the '69 Pontiac was- two on the sides of the block and one at rear of transmission.
  #59
Old 01-13-2011, 10:15 PM
SteveGB21's Avatar
Smile That was what I was wondering.
Pontiac Jack,
Thanks for the input. I would fabricate something from the '69 and later blocks. I guess whatever I get the Poncho block from, maybe get the frame mounts, alongside making an extra crossmember for it to mount, and then trying to make a transmission crossmember as well. That was what I did wonder about, and you did solve my question.
Steve
  #60
Old 01-14-2011, 02:08 AM
Pontirag Pontirag is offline
I dont think the aluminium timing chaincover is stout enough to handle an old style gmc v8 front mount.Dont think they fit either the 70 and later blocks accept the 2nd gen firebird mounts that move the mounts further forward. that gives you some room to clear the steering box not much but enough. I wrote up on this in great detail when I put a 74 400/th400 in a 50 pontiac. same deal. Same deal with a 55 pontiac too
