OHC-6 TECH Over Head Cam projects, questions and advice.
Old 01-01-2024, 01:37 AM
jayboyz28 jayboyz28 is offline
Originally Posted by sprintbird View Post
.078” & .160” are the dimensions of the ones I sell.
Thank you so much
Old 01-01-2024, 01:47 PM
Cammer-6 Cammer-6 is offline
easy fix is to braze or silver solder the old hole and drill a new hole 180* from the patch
Or buy one from Rob.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 01-04-2024, 10:31 PM
I have this old sheet from Gerry Woodland from back in the 1980's. Pretty much confirms what has been previously stated here.
Name:	OHC6 Oil Restrictor Spec's.jpg
Old 01-05-2024, 07:04 AM
Jeff Hamlin's Avatar
If you prefer not to re-weld/braze yours if it's needed.
The Woodland replacements are a good piece to use.
Name:	1966 OHC 4BC BUILD 1 (233).jpg
ID:	625970   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (234).jpg
ID:	625971   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (235).jpg
ID:	625972   Click image for larger version
Name:	1966 OHC 4BC BUILD 1 (236).jpg
