Old 10-30-2020, 04:09 PM
tom s tom s is offline
Finally got some progress.The crank has been set in the block to confirm clearance.Note to self,cheaper in the long run to use a aftermarket forged crank as the block needs no clearance work and pretty sure the crank won’t need any clearance work also.With the factory crank we had to grind in the block at a couple spots and then had to have the crank counter wrights 40 thou to clear the pistons.Tom
ID:	552615   Click image for larger version
ID:	552616   Click image for larger version
Old 10-30-2020, 08:19 PM
counter weights!
Old 10-31-2020, 01:04 PM
wbnapier wbnapier is offline
Looks good Tom! So, what's next on this build?
What engine is in the Fire Bird now?
1965 Pontiac GTO
455/469 w/ #48 Heads, '65 Tri-Power
9.25:1 CR
Stump Puller Cam
Muncie M22W 1st-2.56 2nd-1.75 3rd-1.37 4th-1.00
3.55 Rear Differential
Front: 225/60R15 Height: 25.6"
Rear: 275/60R15 Height: 28"
Old 10-31-2020, 03:30 PM
428 std deck RA V engine in the bird.He just has to finish up the short block then finish the rest of the engine.We have everything except for pushrods.The head gaskets will be the next real challenge.Tom
Old 11-09-2020, 01:34 AM
bobzdar bobzdar is offline
What forged cranks are available that fit the 301t block?
The crashes people remember, but drivers remember the near misses.
Old 11-09-2020, 09:34 AM
The Boss's Avatar
The Boss The Boss is offline
This is the pic he wants to see Tom!
And go racin' in the street.
Old 11-09-2020, 10:55 AM
I think I used a Ohio 400 crank,BUT you need to weld up the thrust or use a bearing spacer as the 301 thrust is more narrow than a 400.As I said I believe you are farther ahead using a forged crank.
That is the intake I hope to run on the engine when it gets put in the 69 bird!Note on that mock up it has spacers as its sitting on a std deck block but was designed for a short deck block.Tom
Old 11-09-2020, 10:59 AM
Yes,Ohio crankshaft
http://ohiocrank.com/crankshafts/
Old 12-18-2020, 09:23 PM
A little more progress
ID:	556453   Click image for larger version
ID:	556454   Click image for larger version
Old 12-19-2020, 09:48 AM
Gary H's Avatar
Gary H Gary H is offline
Default 301 build
Very nice! I love seeing your different builds. Do you have any thoughts on the HP capability that the 301 Turbo blocks can handle?
Old 12-19-2020, 10:55 AM
We have already made 475 with it in 383 form N/A.Tom
Old 01-23-2021, 06:42 PM
Working on the linkage for the Xram
ID:	559274   Click image for larger version
ID:	559275   Click image for larger version
ID:	559276   Click image for larger version
Old 01-23-2021, 07:06 PM
Had one hicup,had to take the short block apart,chamfer for both valves,reduce the valve size a touch and reduce to 1.50 rockers from 1.65.Because the heads have seat inserts for both valves it has them spaced a little farther apart.That one is on me.I think its back together now and waiting for me to take the 1.50s down to him.Tom
Old 02-05-2021, 07:03 PM
There is a reason I like to look at a engine when being built.Yesterday found a broken guide plate and water by pass plug put in from the wrong side.Tom
Old 02-11-2021, 04:08 PM
Should be on the dyno in 2-3 weeks.Tom
The Following User Says Thank You to tom s For This Useful Post:
Old 02-11-2021, 05:08 PM
definitely will need video of that!
-Jason
1969 Pontiac Firebird
Old 02-11-2021, 07:18 PM
I can't wait to see it! Are you sticking with black?
1965 Pontiac GTO
9.25:1 CR
Stump Puller Cam
  #38
Old 02-11-2021, 08:42 PM
Factory 303s were blk!Tom
  #39
Old 03-01-2021, 08:37 PM
It’s home getting ready for the dyno,will test fit the Xram.Tom
ID:	561855   Click image for larger version
ID:	561856   Click image for larger version
  #40
Old 03-01-2021, 09:22 PM
Sorry guys,no clue how or why that happens.Maybe someone can fix it.Tom
