Old 08-09-2012, 11:07 PM
Scott Roberts Scott Roberts is offline
would the 90deg help cure the vibration issues in ur opinion
Old 08-09-2012, 11:28 PM
charlie66's Avatar
Originally Posted by Drag Star Le Mans View Post
You should post those links on the 61-63 tempest forum. Those guys should go nuts.Your car is bad ass. Ive' been thinking of doing a turbo setup on my 62 Lemans. I will have some questions for you in the future.
Any question you have i'll be glad to answer.....
Old 08-09-2012, 11:30 PM
charlie66's Avatar
Originally Posted by mechanickeith View Post
What RPM's are you turning??
6500 so far . in the video i hit the limiter which is set for 7500rpm's. but i shift it at 6500.
Old 08-09-2012, 11:31 PM
charlie66's Avatar
Originally Posted by Scott Roberts View Post
is that a 153? The slant 4 engine?
Its bored to 4.095 3.75 stroke . i think that makes it a 198ci now? not sure....
Old 08-09-2012, 11:34 PM
What Turbo you running?
charlie66's Avatar
ok...got ya. i am thinking about a 151/2.5 build but most dont consider it a Pontiac i dont believe? can the 194's take 600+ hp in ur opinion?
Yes . this one is over 700 hp . but for the critics i'll be going to the chassis dyno at the end of the summer to see for real......
Old 08-09-2012, 11:37 PM
charlie66's Avatar
Dont remember when I got the pic of Rogers car but I copied it from here on PY. Rusty's motor looks good no matter what angle you look at it. He is running a CV-1 head on that motor. The M/T Blown motor is in the Museum of American Speed in Lincoln Nebraska.
Then you have a M/T Blown tempest dragster, a rail with 2 Tempest 4 Cyl motors & here is one from the phoenix area with a Tempest 4 cyl with an adaptor plate with a chevy 409 valve cover on it.
Thanks for the pictures. very cool!
Old 08-09-2012, 11:40 PM
charlie66's Avatar
Originally Posted by RA6T7GTO View Post
think i will buy stock in drag radials !
Nice to see you interacting again Perry..
did you blow the cobbwebbs off your motor in richies garage! Lol!
Old 08-09-2012, 11:44 PM
charlie66's Avatar
What crank are these guys running in these boosted engines?
Mine is just a stock thick block crank. The thin blocks come with a very noticeable weaker crank... There 10lbs lighter too........
Old 08-09-2012, 11:45 PM
marks73ta's Avatar
marks73ta marks73ta is offline
Charlie, good to see you getting some recogniton with that 4 cylinder. It's well earned. Mark L
My Gasser '63 Catalina build. Oh sorry, it's a Street freak. Either way it's a fun build.
Old 08-09-2012, 11:46 PM
charlie66's Avatar
Its a hp76 from Turbonetics.. It has a costom A/R .68...
Old 08-09-2012, 11:47 PM
charlie66's Avatar
Thanks Mark! You have to get over here too....
Old 08-10-2012, 12:09 AM
mechanickeith's Avatar
Thought I heard it bouncing off a limiter!!
I dont know how big a stroke you can shove in one of these. I know Mickey Thompson stroked them. Here is a couple pictures of one of his Tempest motors with a large curved plate bolted to the left side of the block. I can only assume it is for crank/rod throw clearance. Also is a cool way of checking out the inside!!! .060 overbore with stock stroke is an even 200CI. Should be pretty easy to go with a custom crank & a 2" rod end & stroke it another 1/4" without any internal interference. Dont quote me on that, just numbers out of my head. CRS may be kicking in.
ID:	294004   Click image for larger version
Keith Collier
61-63 Pontiac Tempest
Tech advisor
POCI.org
Old 08-10-2012, 12:41 AM
Drag Star Le Mans's Avatar
Keith,
I had a real WTF moment when I saw the 409 rocker cover on the 195. What kind of ets does it run? Injected on alcohol?
DragStarLeMans
Old 08-10-2012, 01:24 AM
Dont know the times, Carb on gas. I didnt see it but was given the pictures by Steve Barcak who was at the event it was at. I took a double take also. Here is the other Pic I have. This was at Speedworld in Whitman Az.
Name:	Tempest digger.jpg
Keith Collier
Tech advisor
POCI.org
Old 08-10-2012, 01:46 AM
Jack Gifford's Avatar
formerly 'Pontiac Jack'
A ninety degree crank will be odd-fire... period. Doesn't matter what firing order you build the cam to do.
Keith- Is the "expanded crankcase" engine the one that they put a steel plate on top of the block to allow for a huge stroke? I don't remember just how huge- 5" or more? All I remember for sure is Fritz telling about not being able to get dyno results, due to the horrible shaking!
As for that burnout... track prep left something to be desired...
Old 08-10-2012, 02:06 AM
Jack,,,Here is a front view of that motor. Looks like it has at least 1/2" maybe 3/4" plate between block & head.
Keith Collier
Tech advisor
POCI.org
  #38
Old 08-10-2012, 02:52 AM
charlie66's Avatar
Sometimes those plates are for the hole the rod made in it. Lol! But i see what you're talking about with the way its rased up.....
  #39
Old 08-10-2012, 02:56 AM
charlie66's Avatar
Nice way to add to the deck height.... cool i didnt know they did that....
  #40
Old 08-10-2012, 09:22 AM
gene simmons gene simmons is offline
Video of the 4 cyl.
http://www.youtube.com/watch?v=OMs0v...feature=relmfu
Cool!
