Old 08-28-2011, 10:48 PM
Held for Ransom's Avatar
I believe a 4-speed car like this w/o Ram Air option would have a '263 carb.
Old 08-29-2011, 02:07 AM
sehorn sehorn is offline
As far as putting it on the trailer it only got towed a few miles on side streets. Didn't have much of a choice because it would have been more dangerous putting it on frontwards since it had no power or brakes and the guy lived on a hill, getting it turned around could have been deadly, but thanks for the FYI.
Not sure about all the options yet cause I don't know much about them, other then it does have power disk brakes and hood tach. Wheels are just some of my spares since the original tires are flat. I think it may of had steel wheels with some hubcaps.
The carb on it has been changed, guy had it swapped out before he parked it. However, I checked the numbers off of it online and according to the website it's a 68' ram air carb (will post numbers tomorrow, don't remember). I imagine they are just as rare...?
In picture car had already been power washed. It's not waxing out.
And I already ordered the PHS documentation. Will get more pics up soon.
Old 08-29-2011, 06:43 AM
Big Moe Big Moe is offline
Great Find!!Good luck with the project
Old 08-29-2011, 06:59 AM
trishieldchief's Avatar
No, it is a WQ RA engine so it would have a 273 Qjet even without Hood Inlet pan option
Rich Johns
www.purestockauto.com
1970 GSX Stage 1 Auto 3.64 # 603 of 678 12.44@109.73 mph 2011 Buick GS Nats Pure Stock, 12.71@110.64 mph PSMCDR 2011
1970 GS Stage 1 Convertible Auto 3:64 12.71@109.15 mph PSMCDR 2009
1970 GS 455 M21 4 Speed 3.42
1987 GN Astro Roof
Old 08-29-2011, 01:14 PM
FunctionalShaker FunctionalShaker is offline
X2.
If it's a true R/A III, it's one of 1498 built. Be cool if it came with the optional functioning ram air.
Old 08-29-2011, 02:18 PM
The hood doesn't look like it ever had a ram air system under it,but who knows, maybe it was wrecked during its time? I'm the third owner and the guy I got it from bought it from some lady before that, so I doubt it was ever wrecked other than its current damage. The exhaust manifolds have the same heat tube pieces bolted to them that the Ram Air's had on the drivers side, according to ram air diagram. Would the factory air cleaner have the same piece?
Where would the hole for the pull lever be in the firewall? If it did have the 611 option it should have a hole I'm guessing.
Old 08-29-2011, 03:30 PM
Banshee Banshee is offline
I thought I read/heard that the WQ block could have been ordered with 348 RPO without the Ram Air pans..making it an HO. I have seen 69 invoices with WQ blocks with the RA option and the HO option.
It is vague to me as I never owned a 69, but there was a huge debate on whether a 348 RPO 400 was technically a "Ram Air" car or not.
1967 PMD Engineering Firebird 400 Auto Coupe
1968 400 4 speed HO Coupe
Old 08-29-2011, 05:12 PM
Banshee
You are correct L74 HO/RA III WQ Firebird engines are identical in very component with or without RA Hood Inlet pans.
A 69 400 HO WQ Firebird engine is identical to the WQ 400 RA III Standard in a 69 Trans am, less RA pans.
Rich Johns
1987 GN Astro Roof
Old 08-29-2011, 05:47 PM
Originally Posted by trishieldchief View Post
Banshee
Yeah, I've already read all those old arguments on hear about whether or not it's a Ram Air. Fact of the matter is they are the same car just some may have had the 611 option, some didn't. The early ones "may" of had it without the option since the sheets say ram air even though there was no 611 option to signify it. My guess is that this is a later car (somewhere around 17 thousandth built in Van Nuys) and if it did have the pans the PHS documentation will say that it had the 611 option. Seems like people with earlier HO's try and claim that their cars came with Ram Air's because there was no distinctions in the paperwork. If this one does happen to be early one, I'm not gonna play that game cause I'm pretty positive this is the original hood and it should have some marks if it came with pans.
Any whoo, what are these going for nowadays? Assuming it's an HO without the pans.
Old 08-29-2011, 05:52 PM
Have you checked the cowl tag to see when it was built?
Old 08-29-2011, 05:59 PM
Cammer-6 Cammer-6 is offline
all depends on what you tow it with.
towed a 99 Camaro SS Saturday,loaded backwards on my short equipment trailer.
Towed with a dually 3500 Duramax flatbed. No problems what so ever but Im sure this would be an exception.Hood on Camaro was about 2 ft higher than normal due to the PO hitting a power pole,so normal forward facing wasnt an option.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
Old 08-29-2011, 07:23 PM
The Boss's Avatar
The Boss The Boss is offline
I had no intentions of changing the topic of this thread and apologize to the OP for the distraction.
Killer car with or without the Ram Air - it's a keeper for sure.
And go racin' in the street.
Old 08-29-2011, 10:54 PM
We always drift and change lanes in most threads, even if nothing is getting towed anywhere.
Around April or May of 69 the Ram3's started getting 9273 XB's instead of 8273 XX's.
Only the buildsheet knows for sure what got what though.
I have to confess, by the pictures it looks like it would clean up a lot better still - with some elbow grease, hot water, good detergent and a green scotchbrite pad.
Even the front glass is still dirty ! lol
As far as what the WQ Bird Hdtps are worth -
Under-rated cars that are hard as heck to find intact.
Not enough change hands to really keep a pulse on their market.
I'd say probably under 30k if this one was finely restored, right now.
Old 08-30-2011, 02:20 AM
I would say an intact RAIII with correct block, trans, rear, carb and at least 95% original and complete (correct glass, alternator, heads, intake, distributor) essentially most all the hard to find parts with original sheet metal, no rust or panel replacement, unrestored, $15-20k.
It is rare...and difficult to find an HO as it is....all the other hard to locate parts with the car is a huge expense.
Old 08-31-2011, 02:24 PM
Here are some more pics including some of the No.'s.
intake, body tag, engine ID, axle, more engine id (by the timing chain)
ID:	255049   Click image for larger version
ID:	255050   Click image for larger version
ID:	255051   Click image for larger version
ID:	255052   Click image for larger version
Old 08-31-2011, 02:28 PM
And some more...
You can see the VIN and engine ID by the Timing cover match. Everything else if matching up too, I have no reason to believe everything is not 100% original. Except carb, which is a replacement 68' Ram Air carb
VIN, ENGINE ID, INSIDE, TRANNY, ANOTHERPIC AFTER CLEANING UP (AND A BUTT)
ID:	255054   Click image for larger version
ID:	255055   Click image for larger version
ID:	255056   Click image for larger version
ID:	255057   Click image for larger version
Old 08-31-2011, 02:37 PM
MORE...
ENGINE , CARB, AS THE CAR SAT FOR THE LAST 32 YEARS (NOTICE THE RETAINING WALL ABOUT TO FALL ON IT, PIC MINUS THE IVY THAT WAS COVERING IT), MORE CLEANED UP
ID:	255059   Click image for larger version
ID:	255060   Click image for larger version
ID:	255061   Click image for larger version
  #38
Old 08-31-2011, 02:42 PM
steveK steveK is offline
Nice find for sure!! Gets tougher every year!!
Steve Karew
  #39
Old 08-31-2011, 03:03 PM
You stole that car. Nice find.
  #40
Old 08-31-2011, 03:04 PM
muscle_collector's Avatar
cleaning up nicely. congrats on the score.
