Old 09-22-2010, 10:19 AM
gloryrestoparts's Avatar
gloryrestoparts gloryrestoparts is offline
I'd take two sets. not sure when the car will get stripped, rust fixed and then repainted as I have another car to do first. so one set for now, the other when the paint and bodywork is done ..... in 2025 lol
http://gloryrestoparts.20megsfree.com/
1970.5 Pontiac Tempest GT-37
400ci 4bbl 4sp 3.90:1
12.73 @ 112.42 2011 Pure Stock Drags
12.71 @ 110.58 2013 Martin FAST/FS race
12.70 @ 111.74 2014 Pure Stock Drags
12.60 @ 111.66 2015 Martin FAST/FS race
1968 Pontiac Firebird 400
TH400/3.08 open
export car - factory heater delete
14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags
14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race
Old 09-22-2010, 06:35 PM
4SLASH6's Avatar
4SLASH6 4SLASH6 is offline
great pic's, wish I were there racing too..... I read where my roller tips would have to be swapped out or risk dq for next seasons event. still looks like loads of fun. in the future, I would like to swap my 3;55's for a set of 3:90's. great post. SLASH
70 GTO 400/4SPD-13.97@102.31
Old 09-25-2010, 11:13 PM
S Courter's Avatar
S Courter S Courter is offline
Chris, Thanks for posting the pictures of our one matchup. I'm quite sure I would have lit the win light regardless. It would have made for some good fun on Sat. if not for the rain.
My engine is a STOCK 400 and I am running an m21 4 spd, a 12 bolt posi with 4:10 gears and BFG radial t/a.
I have run a best of 14.30 and ran 14.39 on Friday @ 98.4mph
To all who are thinking about participating in this event let me say DO IT!!! It is the most fun you will ever have with your car.
Steve
71 Pontiac GT-37 400 4 spd (sold)
71 Formula 400 turbo 400 (sold)
01 Firebird T/A WS6 auto (fun)
64 Tempest Post car LS1/4L60E (Love It!)
65 Lemans Post car LS1/4L60E (More Fun)(sold)
73 Lemans GT 400/auto 1 owner 52k miles
69 El Camino LS1/4L65E (Awesome)
70 Pontiac GTO Convertible 400/400 Original
69 Olds Cutlass S W31 Numbers matching 4Spd 3:91 one of 569
Old 10-14-2010, 07:37 PM
Judge Man Judge Man is offline
Originally Posted by gloryrestoparts View Post
fellow PY member Steve C and I were finally able to line up against each other this past weekend at the 16th annual Pure Stock Muscle Car Drag Race in Stanton, MI. He and I have the only GT-37s to ever participate in this event. Both are 400/4bbl/4sp cars. Sadly, I choked under the pressure and missed 3rd gear, which really sucked as Steve and I were fender to fender to that point. The gods smiled on us for Sat as we were matched up against each other in the 2 out of 3 shootouts. However, Mother Nature wanted nothing to do with it as Sat was rained out.
Cool picture. I'm glad your enjoying the car gloryrestoparts.
Old 10-14-2010, 09:26 PM
Thanks Tim. I'll get an update on the new engine tomorrow as a buddy and I are heading to Martin, MI for a fall FAST/FS race.
Chris
TH400/3.08 open
Old 10-15-2010, 08:38 PM
Chris
Hey Chris Sounds like you got it going on with the GT-37. Correct me if I'm wrong...your storing the orginal engine and putting another 400 in its place? If so I think thats a great idea to save from blowing up the orginal. Will this new engine be a WT engine? Are you taking the GT-37? Have fun.
Old 10-17-2010, 06:32 PM
yes, I'm storing the original VIN matching engine. The new engine will be built to the correct 70 WT specs, but the actual block is a 71 auto code (can't recall the specific code off the top of my head). This isn't an issue for the Pure Stock and Factory Stock Drag racing. Sadly, no I didn't bring my car (wish I did as a lot of guys ran personal bests). It was a 2 day event, but I had other plans on Sat so couldn't bring my car.
btw Tim, I almost did blow up the original engine a couple years ago. Got REAL lucky. Only damage was a cracked balancer (in the keyway) which has since been replaced and the bottom end was checked out too. Then the motor was dyno'd. And I know people are going to ask so, the build by the second owner put out just under 300hp and the power dropped off the table after 5000rpm as the valve springs are shot.
TH400/3.08 open
Old 10-18-2010, 06:53 PM
Wow Even with the motor being alittle weak 14.29 is pretty damn good. I'm looking forward in the progress of the car. I bet you'll dip into the 13 second range with no problem with the new engine.
Old 11-08-2010, 12:29 PM
did a little TnT at US41 in Morocco, IN yesterday. This track hooks!!! 5 runs, 60 foot times were 2.16, 2.12, 2.15, 2.10, 2.08 got the et down to a 14.10 @ 98.82. all this with a pretty good headwind too.
TH400/3.08 open
Old 11-08-2010, 01:19 PM
67drake's Avatar
67drake 67drake is offline
Great times! I wonder if you had the high barometric pressure down there too? I have run my car in the cold before,and the MPH always goes up,but not like yesterday. I posted times in the other thread. I think it was a combination of high pressure and cool air in my case.
I always ask the 4-speed guys this,but I don't know if I asked you before. What is your launch technique? I've tried picking various RPM's and letting off the clutch quickly and also tried feathering the clutch slightly and rolling into the throttle,playing with tire pressures,burnout time length.ect and just can't get my 60' better than 2.2. It has improved over the last few years,but still fighting traction!
I dream of the day I have your 60'!
13.95 @ 102.1 on street tires @ 4055lbs.
Old 11-08-2010, 01:46 PM
I'm still learning to launch a 4sp. My best times prior to yesterday was 2.17. At Stanton and Martin (Pure Stock and Factory Stock races) I can consistently do 2.20s, not that great. When I dip into the 2.teens I'm happy. I rev to 1500rpm and then go. Sometimes I have to peddle depending on what happens. US41 is a track which is known to have a great starting line. So I decided to try rev to 2000 and just dump the clutch and go. She hooked and went each time. I even tried 2200 on the last one, same thing.
I'm running repro bias plys, which I know are much easier to get traction back when you start to spin. Street radials are a bit harder to get them back to hooking after you spin. Only thing I can recommend is practice. Lots and lots of practice.
TH400/3.08 open
Old 12-15-2010, 11:46 AM
adam woodmancy's Avatar
adam woodmancy adam woodmancy is offline
Send a message via AIM to adam woodmancy
love hearing about the car and all the fun your having with it chris. id love to make it up sometime to see it again.
1972 Pontiac LeMans
Thanks to
Fuelab Digital Fuel Delivery
Quarter-Max Chassis and Racing Components
Old 12-15-2010, 06:21 PM
thx adam. she is a LOT of fun.
TH400/3.08 open
Old 12-15-2010, 10:09 PM
thats what its all about!!
1972 Pontiac LeMans
Thanks to
Old 12-16-2010, 10:01 PM
a few pics from the US41 track photographer
from 11/7
from 11/28
TH400/3.08 open
Old 12-17-2010, 09:48 AM
from 11/7
from 11/28
I am interested in the hood pins you have. Are they held on by clip or lock? Do you know where you bought them?
Matt
71 LeMans Sport Convertible
04 Pulse Red GTO A4
10 GMC Sierra 1500
Old 12-17-2010, 05:36 PM
Matt
the studs or pins are screwed into the core support. the scuff plates on the hood are held on with 4 screws each. The clips and lanyards were missing when I bought the car, but they bolt on near the grills and then the clips slide through the pins. they came with the car as they are part of the GT-37 option from the factory. Another thread in here has a bunch of pics of mine and a post 70 GT-37 as were we comparing them. We believe they are Mopar A & E body hood pin assemblies.
TH400/3.08 open
  #38
Old 12-18-2010, 10:34 AM
Thanks for the info. I didn't know it was an option on the GT-37. We're putting on a fiberglass hood and need it to be pinned down on all 4 corners.
Are there springs under the hood pins? Or is the center spring retained? Or is a spring not needed at all?
04 Pulse Red GTO A4
10 GMC Sierra 1500
  #39
Old 12-18-2010, 02:11 PM
Jack Peters's Avatar
It is not an option on the GT-37 it is part of the GT package.
All springs are retained. It is just a T-37 hood with hood pins installed.
JLP
  #40
Old 12-18-2010, 02:25 PM
Evil Stu's Avatar
Evil Stu Evil Stu is offline
If you ordered hood pins on a 70 GTO (through the accessory catalogue), I think that's what you got too. My 70 GTO was delivered to it's first owner with them and I've long thought they were the Mopar pieces.
Stu
"Having a 10 second Civic must be just like coming out of the closet; you'll surprise some people, but you're still gay"
1970 GTO, 455+.034", 0 deck, Wiseco's, Eagle rods, 60919, Rhoads, E-Heads, 1.65 Scorpions, RPM, Custom Qjet by Cliff, Doug's 1 7/8", THM 400, Gear Vendors OD, 3.55s.........Her name is Blandorf; after a girl I knew once, 'cause she's just Bitchin, always.
