Resto almost done - 1966 GTO HDTP Tiger Gold (paint code 1-2), black vinyl top and interior, 389 tripower, 068 cam, TH-350/Hughes TC, RA manifolds, 2.5" Pypes exhaust, Scarebird Front Disc, Ralley II's, factory PS, PB, PW, PA, A/C, headrest option. |
That was with a 455, right?
"The Mustang's front end is problematic... get yourself a Firebird." - Red Forman |
so what springs are people recommending?
Clay Marsh 1967 GTO convertible Twin Turbo 5spd project http://forums.performanceyears.com/f...d.php?t=618281 http://www.youtube.com/watch?v=eJ9KworCMRE |
No, the original 421 block (and crank) is in the car. Right now we have the #62 heads (76cc) and 24cc dished TRW pistons. Compression is 9.1:1, and we are running HS 1.65 rockers.
That is interesting about Summit -- the replacement 2802 cam and lifters are still unopened from when they sent me the replacements. I'll give them a call on Monday and see if they will be nice to me also. After the second 2802 went flat, I wasn't about to install the third one. Way too much work and expense cleaning everything and replacing bearings. I went with the 60919 with Rhoads and it has been thousands of miles and things are perfect with the cam. I took the 2+2 to the dragstrip last weekend for day #2 of Summit after breaking the drag car. I had leaned out the jetting (using an A/F meter) in an attempt to help the low fuel mileage we were getting. The good news is the fuel mileage came way up, the bad news is it was way too lean uncapped and ran slower than with the 2802 cam. I had set the carb up at my 3,000' elevation through the mufflers -- worked terrible uncapped at the tracks 1,200' elevation. I didn't want to hurt the engine so cut the day short.
Honestly, if your looking for a cam that will provide strong vacuum and have a cool factory muscle car sound the Crower #69016 is hard to beat. I ran this cam myself and even with 1.65 rockers it pulled a solid 15 hg of vacuum at idle. It will work great with 9.0-1 engine and pull very hard to 5600-5800 rpm. BUT there are many reasons to run a slightly smaller cam and explore tighter LSA cams to achieve the lowend your going to need. It's all in the combination through out the driveline. Good luck! JD
Good luck to the new owner of the Ventura II! Sold the car after 13+ years. Look for it on the Hot Rod Power Tour in the future as it's currently being re-configured as a Pro-Touring ride! |
I just bought a 2802 from Summit last week. Is there anyway to check the lobe hardness? I imagine its a case hardening? Does anyone know what it should be?
