#241
73ta
That is a one sweet bird! |
#242
We do have some nice Birds on here.
1970 Trans Am Ram Air III and Turbo 400 2002 WS6 6-speed Trans Am vert |
#243
Heres some pics of a 73 Formula 455 i did a frame off on over the winter.Original 455 4-speed,i converted it to a 455SD,with an automatic,will put the 4-speed back in when i am done racing it at the Pure Stock Drags.
#244
Oops,sorry so big,heres a couple more smaller ones
#245
WOW!!!
Thats just incredible!
Home of WFO Hyperformance Shaker induction. |
#246
Larry I agree, that is one incredible car. J GLASGO, I want to know what it runs the quarter in. Post some numbers when you go to the track.
#247
12.61 first time out on the wide ovals,didn,t do any tuning at the track at all.Iwanted to take it to the chassis dyno,but ran out of time before race!
#248
Boy am I jealous! An awesome looking car that is also runner. Don't see that every day. Great Job!
#249
OKAY!!!
Years ago I talked to a fellow from Indiana who was racing a red '74 SD455 T/A in the late '80's Musclecar Drags. The car had 4.11 gears and a 4 speed and had everything optimized for that particular series rules. From what I recall the car ran very low 13's in stock trim. Being the owner of a '73 SD and knowing what the SD is capable of in PURE STOCK form; Mr G, would you care to share the information on the engine and drive line?
#250
J GLASGO,
Wow... that 73 looks nice! What color of blue is that? This question leads me to another... is there a site online that contains OEM color chips for 70 - 73 Firebirds? Even one that has a list of available colors would be a start. Thanks. |
#251
Not really nothing special about the motor,.060 over,0 deck,heads are milled .040,ross pistons,2 valve reliefs(these are not nhra replacements,and will not pass certification at PSMCDR) Childs and Albert Z-gap rings,with a low tension oil ring,early style sd cam.Absolutely no port work,or bowl work.These sd heads make really good power! The color is Admirality Blue,i had a picture taken of the color under the trunk lid,and it crossed to 83 Rolls Royce color,since Dupont did not have the exact formula in chrome base for 73 .It is really close,i did not even paint the bottom of the trunklid.
#252
I saw the car in person at the PSMCDR. beautiful!!!! and runs as good as it looks.
Chris
http://gloryrestoparts.20megsfree.com/ 1970.5 Pontiac Tempest GT-37 400ci 4bbl 4sp 3.90:1 12.73 @ 112.42 2011 Pure Stock Drags 12.71 @ 110.58 2013 Martin FAST/FS race 12.70 @ 111.74 2014 Pure Stock Drags 12.60 @ 111.66 2015 Martin FAST/FS race 1968 Pontiac Firebird 400 TH400/3.08 open export car - factory heater delete 14.48 @ 95.86 w/ 2.14 60' 2018 Pure Stock Drags 14.47 @ 95.02 w/ 2.16 60' 2019 Martin FAST/FS race |
#253
110 MPH.....
John care to share any info on that camshaft, (specs, idle quality)? Years ago i built a complete SD motor with the stock SD issue components(8.4:1 c.r) exhaust manifolds and a Brad Urban optimized 750cfm Q-jet. The only part that wasn't stock, was an H-O racing SD cam (HC-63) which spec'd out at 242/250@.050; 113/119LSA and .501" lift w/1.5 rockers. It had a fairly choppy idle and pulled about 11" of vacuum. The engine was in a '73 t/a, which was a no option car, had a 4 speed and 3.90 gearset. Best 1/4 performance was high 12's @ 108 mph.
#254
Larry,the cam is a RA 4,which they supposedly came with at the beginning,i think it is even listed in the 73 service manual.I know that some people disagree with this.The 2 biggest things that make these cars run so well is the 2.5 mandrel bend crossflow exhaust with x-pipe(from PYPES)and straight through muffler.Also these repo tires when you heat them up really hook.I think that cam you had was pretty aggressive for 8.4 and exhaust manifolds.Open headers may have been something else.
#255
John, how did you get the cam? Is it a factory piece?
I also have the PYPES crossflow, how did you mount the muffler....flow across the raised baffles or in toward the baffles openings? Just noticed the slow 60' on the slip!....that car is making some killer power on the top-end!!! I want some tuning notes!!!
Home of WFO Hyperformance Shaker induction. Last edited by Larry Navarro; 10-04-2005 at 12:07 PM. |
#256
J GLASGO,
That car really looks great. I like the way the Rally Wheels, white lettered tires, and chrome decor package stand out against the Admiralty Blue body. It looks very classy. Add an SD455 motor and 12.60 1/4 mile times..... what more could you ask for? I'd sure like to see some more pictures of the car. Jim |
#257
Man what a beautiful car. That's a show winner for sure if you're into that.
Ric |
#258
Larry ,the car still has the original block,which is obviously not sd,so i dont have to deal with the cam gear issue.Heres a couple more shots to bore you with.The one in etch primer was taken last January.
#259
Just a quick Q for J GLASGO:
Did you swap the hood/shaker set up purely to make it look like an original SD Formula? - or was there another reason that made you change from the original hood? (just curious) That is one beautiful car! - it's currently my desktop picture at work!
#260
J GLASGO,
That is an amazing looking car! I love the stance. Did you use stock replacement springs to get that stance? Mike |
