Old 06-19-2012, 07:10 AM
The Boss's Avatar
The Boss The Boss is offline
Originally Posted by gloryrestoparts View Post
wow. light car. Not surprised at the mph, if you said serious traction problems. At the FAST/Factory Stock race at Martin this past weekend, mine weighs 3675 with me in it and roughly 1/8 tank of guess and an empty trunk. For reference, ran a best of 12.79 @ 110 with a iirc 2.03 60 ft for the weekend. And this was in bad air too as it was low 90s and humid.
Tire pressure also plays a big role. I'm sure Jeremy can give you input also. I think I'm running 47lb in the fronts and about 35 in the rears.
Light? You've got 150 pounds on me - with me & gas in the car it was 3845! I'm certain the car can do 12's but I need to get better!
Tire pressure may be part of it - I was running 21 lbs in the rears - need to try it with them bumped up.
And go racin' in the street.
  #222
Old 06-19-2012, 08:49 AM
Steve Hoog's Avatar
Steve Hoog Steve Hoog is offline
formerly Steved400
Send a message via Yahoo to Steve Hoog
I'm getting my 1-2 shift while they're spinning at the line & then it's downshifting once they grab!
Absolutely 100% the wrong thing to be doing!!!!
  #223
Old 06-19-2012, 08:51 AM
Steve Hoog's Avatar
formerly Steved400
I would guess 20-25 depending on the tire to car aspect; IMO this is near on the money.
  #224
Old 06-19-2012, 09:13 AM
goatless's Avatar
goatless goatless is offline
Chris, I get my best 60' with them right at 24 PSI. The 60's drop off pretty consistently with anything above or below. Each car is going to like it a little different, but I bet that 21 PSI is too low.
We'll have to hit a track rental at LVD sometime so we can get a bunch of runs and fine tune it.
1966 GTO
  #225
Old 06-19-2012, 09:26 AM
Steve Hoog's Avatar
formerly Steved400
Chris
There is a little plate inside the column that sort of guides the shift pattern; I have often wondered if that could be engineered to act like a Dual Gate, someone could make a little money if they could pull it off.
  #226
Old 06-19-2012, 09:59 AM
The Boss's Avatar
Originally Posted by steved400 View Post
Chris
Really? I need to take one apart.
It would be nice if it worked normal pulling towards you, and then had the ratchet effect pushing away with a positive stop before neutral.
  #227
Old 06-19-2012, 10:00 AM
The Boss's Avatar
Let me know if anyone picks one up - I'll take the day & go. I've got nothing lined up between now & Norwalk and I want this thing RUNNING at Norwalk!
  #228
Old 06-19-2012, 10:32 AM
Steve Hoog's Avatar
formerly Steved400
Chris
Stop screwing around and get down here!!!!
I'll let you know what is up with Chemo after Thursday and maybe we can pick a weekend; you really should while the time is still good for me.
  #229
Old 06-19-2012, 10:38 AM
Steve Hoog's Avatar
formerly Steved400
Chris
You have any valve covers you can donate to my son's car, Moroso take off's from a car your restored maybe? What about some exhaust manifolds that aren't good enough for a restored car, long branch kind of stuff D port?
  #230
Old 06-19-2012, 10:45 AM
The Boss's Avatar
No long branch ones Steve, but your car would take the regular A-body style anyways. I'll check what I've got - I know I've got round port ones. No Moroso covers but I've got factory chrome & painted, which do you want?
  #231
Old 06-19-2012, 10:48 AM
Steve Hoog's Avatar
formerly Steved400
Moroso or stock chrome. I'm like 99% sure this would take long branch manifolds; it has the same frame as first gen Firebird. By the way; I'm going to try and talk Gary into letting me do a little work on your 68, clean up and stuff plus get it rolling good for transportation.
  #232
Old 06-19-2012, 11:45 AM
The Boss's Avatar
Same front sub frame as the 2nd gen F-bodies not first gen.
Huh?
  #233
Old 06-19-2012, 11:47 AM
Steve Hoog's Avatar
formerly Steved400
No, first gen
  #234
Old 06-19-2012, 11:49 AM
The Boss's Avatar
2nd
  #235
Old 06-19-2012, 11:53 AM
Steve Hoog's Avatar
formerly Steved400
Are we taking bets?
  #236
Old 06-19-2012, 11:56 AM
The Boss's Avatar
No, you're right.
Still can't help you with the long branch.
  #237
Old 06-19-2012, 12:07 PM
Rob B's Avatar
Rob B Rob B is offline
No, you're right.
Yes he is...
What 68 do you have now Chris Steve is referring too???
74 GTO Bracket/Street car and another 74 for the wifey to race with!
70 GTO 400, 4 spd, #'s matching and a little to nice for me to own.
Friendship is like peeing your pants..everyone can see it but only you can feel the warmth!
  #238
Old 06-19-2012, 04:31 PM
The Boss's Avatar
Just some ole car sitting out in Gary's back yard that I need to pick up.
  #239
Old 07-07-2012, 07:29 AM
The Boss's Avatar
One of our members is sending me this - thanks Mike!
  #240
Old 10-19-2012, 05:17 PM
Steve Hoog's Avatar
formerly Steved400
Found these in my files, while it was in my garage.
