Old 04-25-2024, 06:33 PM
jerry455 jerry455 is offline
I put the down tube onto the lowest head bolt hole on the front face of the head. I just finished my 455 build with Edelbrock RPM round ports.
The Following User Says Thank You to jerry455 For This Useful Post:
  #42
Old 04-25-2024, 06:43 PM
indymanjoe's Avatar
Sweet! we need to get a couple local guys together and hit some cruises. Do you go to lapeer at all? generalz came by last night and i got to check out his ride. Burd is also on here and he does a Great cars and coffee meet at his house. Projectfolly used to frequent here alot and i have met him really nice guy but i dont think he comes here anymore..
  #43
Old 04-30-2024, 05:55 PM
indymanjoe's Avatar
Looks like it's a go! Picked up the heads from the machinist and he found 2 intake valves slightly bent and 1 exhaust valve slightly bent. Just ordered everything else from butler. headers ,valves misc stuff. cant wait to get this back on the road! likely selling the old dougs headers to help offset the new ones. Plus i'll have a box to ship them in.
  #44
Old 05-05-2024, 10:21 AM
indymanjoe's Avatar
well chit! guess i have the early set of e-heads LOL ran out of the correct head bolts with the 85492 kit. jegs has the last set i could find of the Edelbrock Head Bolt Kit 8556 for the early heads. guess i wait some more.
  #45
Old 05-05-2024, 10:46 AM
65 Lamnas's Avatar
Originally Posted by indymanjoe View Post
any other issues you have found that i should get ready to address.?
Don't assume that fully assembled eheads are ready to run. On mine, the stock valve job from Edelbrock on the exhaust side was .005" OOR which is a lot. The ports were pretty rough too.
ID:	633217   Click image for larger version
  #46
Old 05-05-2024, 11:35 AM
Yup, and this goes for any new head you buy, even high dollar ones. They all don't seem to have perfectly round valve jobs and some of them won't even seal or hold a vacuum so I wonder if they are even testing some of them before they are shipped.
Anymore, new heads I buy go straight to the machine shop for a thorough going over checking springs, install height, valve job and valve guide clearances etc....In some cases changing/recutting the valve job if there is a more favorable one that shows gains on the flow bench. I typically pay for some flow bench testing as well because advertised numbers from many of these suppliers are often inflated.
https://youtu.be/XqEydRRRwqE
  #47
Old 05-06-2024, 06:29 PM
indymanjoe's Avatar
Ok for my next question...currently my pushrods for the old 96 heads are 5/16x,083 8.750
i want to get the correct length adjustable pushrod checker to make sure my valve train geometry is correct.
its seems they come in 1 inch increments. has anyone gone from iron to aluminum and did you need a smaller or longer pushrod?
just trying to get an idea of the size i should be looking to get ( adjustable pushrod ).
crower lifters and crower roller rockers fwiw. the cam is this one
https://butlerperformance.com/i-2936...tegory:1459686
Thanks for the help everyone!
  #48
Old 05-06-2024, 07:19 PM
What where you doing with that length push rods when using a late model head like a 96 casting?
The stock length push rod for that set up is 9.145”.
  #49
Old 05-06-2024, 07:36 PM
Maybe HR lifters? Just checked a friend's new 455 with RAIV heads with then new Comp HR cartridge and they are 8.70. Yes a big dish!
  #50
Old 05-06-2024, 08:14 PM
indymanjoe's Avatar
The same guy that "ported " the 96's i sent you pics of set the valve train up like that. i have to say though the pattern on the valve stem was definably in the center.
  #51
Old 05-06-2024, 08:15 PM
indymanjoe's Avatar
yes its all hyd roller.
  #52
Old 05-08-2024, 05:25 PM
indymanjoe's Avatar
Any ideas on the pushrod lengths? shameless bump but its closer to completion. i need to order a pushrod checker.
Or is there a way to ballpark it and get close to knowing what i may need? lots of searches hasnt turned up anything yet.
  #53
Old 05-08-2024, 06:12 PM
8.750” to 9.500” should do it easy.
  #54
Old 05-08-2024, 06:15 PM
I am running a 9.050" 3/8 pushrod from Trend. They have a perfect pattern on the valve tip.
  #55
Old 05-09-2024, 07:53 AM
Yeah, it's not wise to guess, you have to check. No sense putting a temp set in there, waste of money.
https://www.youtube.com/watch?v=o5is9BsH5OU
  #56
Old 05-09-2024, 06:12 PM
indymanjoe's Avatar
if you don't mind me asking what's the valvetrain consist of? roller rockers and lifters or?
  #57
Old 05-09-2024, 07:02 PM
There’s too many variables to just go with a length that’s working out in a different motor!
Do it right by checking and take the time to get near max lift while having decent centering of the pattern.
  #58
Old 05-09-2024, 07:27 PM
indymanjoe's Avatar
just ordered this
https://www.summitracing.com/parts/TFS-9002
im not leaving anything to chance! i have to say with your help and others i have learned ALOT.
  #59
Old 05-09-2024, 07:30 PM
indymanjoe's Avatar
i was just looking for a ballpark from jerry455
  #60
Old 05-25-2024, 09:19 AM
indymanjoe's Avatar
So after a lot of measuring frustration, everything that goes with being a newbie, I came up with 9.050 for my push rod length here are the heads bolted on and the best wear patterns I came up with. I think I’m OK.
