Old 04-19-2024, 04:08 PM
slowbird's Avatar
slowbird slowbird is offline
Default Removing trans from 69GP
I need to pull our th400 trans out of our 69GP that has headers. What are the odds I can pull it without loosening or removing 1 or both header???
Old 04-19-2024, 04:33 PM
Schurkey Schurkey is offline
Totally depends on the geometry of the headers.
First Guess: Not likely due to the width of the trans bellhousing where the torque converter dust pan attaches.
Old 04-20-2024, 07:33 PM
chiphead's Avatar
chiphead chiphead is offline
Cut the dust cover ears off the trans or loosen the headers.
The Following User Says Thank You to chiphead For This Useful Post:
Old 04-20-2024, 07:59 PM
mysticmissle's Avatar
mysticmissle mysticmissle is online now
No chance wo the above mod
1964 540 gto
1971 lemans sport convertible
1972 Maverick under slow construction
Old 04-20-2024, 09:28 PM
slowbird's Avatar
Ya I'll try loosening driver side header first (passenger is an absolute pia). Thanks guys. I was trying to be glass half full but I figured it wouldn't come out.
Old 04-21-2024, 07:29 AM
Post 3 has the solution.
To drop it out let both headers dangle on there bolts as far as possible and loosen up the collectors bolts.
If you put anti-seize on at lease one side of your header gaskets then you should not have to replace them just tighten the bolts right back up.
Once out if you hacksaw off the unnecessary ears and casting ridge then at least the next if the trans needs to come out your use of curse words will be less.
Old 04-22-2024, 02:49 AM
Dragncar Dragncar is offline
I could pull the T400 on my 69 GTO without removing a header. I would pull it back a bit and put it at a angle going down and it rubbed against the headers. But I could get it out.
Hooker round port Super Comps.
