Ign switch
Is there a way of bypassing the ignition switch? I'm having electrical problems when the key is turned on, nothing works and it won't crank. I have power coming into the car with key off but not when key is on. 69 Firebird
69 Firebird 472, Bullet SFT, KRE 85cc, Victor, 850xp, TH400, TSP 9.5" 4800, 3.90 10 bolt, Viking DA rears, QA1 single fronts, 3558lbs. best to date 11.14@120 |
Do your headlights work when there’s no key in the cylinder?
No they don't
When you open the door does the dome light come on?
It's no longer there.
I suggest you first disconnect, then clean and retighten all your grounds . When you know the
grounds are good then start troubleshooting from there. Glenn |
May need adjusted?
He said headlights won't work? They don't need key on or off. Grounds as said sound like a good start.
How is this done Scott?
I'll check all grounds first
You just had the motor out yet again for a rebuild and dyno session so any wires you disconnected to get that yanked out of there are what I would visit first.
Make sense?
Yes Steve, going through everything I disconnected at the moment.
I've ordered another ignition switch just incase. It will take a while to get here though.
Sorted :-)
Cleaned all earths and had ignition switch off, so perhaps the rod adjustment helped?
The Following User Says Thank You to 461-69bird For This Useful Post: | ||
