Old 03-11-2024, 06:47 PM
BILL BOWMAN1's Avatar
BILL BOWMAN1 BILL BOWMAN1 is online now
Default Custom color rattle cans
I see a couple companies on line that can do this, any of you ever used them, which ones would you recommend?
Old 03-11-2024, 06:51 PM
Stuart's Avatar
Stuart Stuart is offline
There may be a paint store or auto body supply house near you that can make custom color spray cans. I had some made years ago for my car and the color matched perfectly. In my case there was a minimum number of cans I had to buy, if I remember correctly the smallest can of paint they would mix up was a quart so however many spray cans that translates to - it was four or six, I think.
Old 03-11-2024, 07:15 PM
lemans67 lemans67 is offline
I used Kolor Korrect in New Jersey. Excellent customer service. This was for a factory color. Not cheap, but it was worth it to me. The couple of old paint shops I went to had gotten rid of their old paint books and told me to look elsewhere. They may do custom colors too. Worth a call. They are super nice to talk with, even with the Jersey accent!
https://kolorkorrect.com/
67 LeMans convertible. Tyrol blue, M22z autogear, 2.73 8.5, 455, FAST MPI fuel injection. 243/ 251 112. solid roller. SD performance ported 6x heads.
The Following User Says Thank You to lemans67 For This Useful Post:
Old 03-11-2024, 07:47 PM
Thank you!!
Old 03-12-2024, 12:26 AM
jhein's Avatar
jhein jhein is offline
If you're trying to match a factory color, these guy do rattle cans.
https://touchupdirect.com/?msclkid=6...=TouchUpDirect
70 TA, 467 cid IAII, Edelbrock D-port heads, 9.94:1, Butler HR 236/242 @ .050, 520/540 lift, 112 LSA, Ray Klemm calibrated Q-jet, TKX (2.87 1st/.81 OD), 3.31 rear
The Following User Says Thank You to jhein For This Useful Post:
Old 03-12-2024, 03:25 PM
jamesq's Avatar
jamesq jamesq is offline
I used the company below, they mixed up single stage of my original code in spray cans. They are very easy to work with.
https://www.automotivetouchup.com/to...63/all-models/
Good luck,
James Q
James Quayhagen
1963 Bonneville Safari - Nocturne Blue, 4-speed
The Following User Says Thank You to jamesq For This Useful Post:
Old 03-12-2024, 09:27 PM
VCho455's Avatar
VCho455 VCho455 is offline
If your looking to match old paint then finding someplace local that can scan your existing paint is best.
Firstly if it comes out wrong it's easier to return and get the correct shade. (I will usually test it at the store to be sure.)
And second a fair percentage of the old formulas have morphed over the years and today's formula is not the correct color.
Photo shows the 1967 light green #503 code that some suppliers are selling. It is much closer to Detroit Diesel green engine paint. Compare to the original 503 of my Burban in the background.
ID:	630308   Click image for larger version
Old 03-12-2024, 09:42 PM
It’s actually for the chassis, it’s all painted car color so perfect match isn’t a must. Thanks for all the replies.
