Old 03-10-2024, 04:25 PM
65 Lamnas's Avatar
Played around with the steels in direct and forward drums for my TH400 to get the clearances set at .040. Disassembled my Q-jet to get the castings, linkages and other steel parts plated.
ID:	630162   Click image for larger version
ID:	630163   Click image for larger version
ID:	630164   Click image for larger version
The Following 2 Users Say Thank You to 65 Lamnas For This Useful Post:
  #342
Old 03-11-2024, 12:20 AM
Verdoro 68's Avatar
Ken, Love the stance, love the color, love the wheels & tires...one of the nicest '68 GTO's I've ever seen...drool!
Dennis
I know you've seen a lot of these cars, and have a pretty impressive stable yourself, so I greatly appreciate the complement!
Ken
'68 GTO - Ram Air II 464 - 236/242 roller - 9.5” TSP converter - Moser 3.55 Truetrac (build thread | walk around)
  #343
Old 03-11-2024, 09:59 AM
nUcLeArEnVoY's Avatar
nUcLeArEnVoY nUcLeArEnVoY is offline
Had a very intermittent coolant leak (like, would occur literally months apart) that dripped behind the passenger tire under the fender only after I would turn the car off. Had the same leak last year that spurred a heater core R&R along with all heater hoses and clamps.
Same leak happened again a couple weeks ago, and my heart sunk wondering if my new heater core failed. Would've been super pissed, since the inlet line is double restricted to prevent water slugging, and I splurged and got the higher quality copper/brass unit. Thankfully, I was able to trace the leak to the inlet heater hose connection. When I did the R&R, I used one of the repro Wittek tower clamps - don't use these, at least for the 5/8" heater hose connection. The radius of the tower end of the clamp is too bulky compared to the actual strap, and so the strap ovals out the house and doesn't seal well. It even slightly caved in the copper tube where the tower part sat (luckily the fitting bead was still round). In hindsight, the same leak from last year might've just been the heater hose the whole time, since it was the original hose, and not the heater core.
And so I tried out, as recommended on this forum, a Gates PowerGrip heatshrink clamp (specifically the 32925# one), and admittedly smeared a thin glaze of Waterpump and Thermostat Housing RTV on the fitting to aid in the seal as well as provide lubrication to put the new hose on. Was able to position the PowerGrip clamp perfectly per the instructions, used my heat gun, and it resulted in a great seal which after two tests of running the system up to temp under pressure and then shutting the car down, didn't leak a drop and is bone dry. So far I'm a believer in these PowerGrip clamps.
Could've probably gotten a proper seal using an old-fashioned worm gear clamp like what the factory used (which I recently found out is how W72 cars actually came from the factory: the engine side of the heater hoses used the Wittek clamps, while the heater core connections actually used worm gear clamps) as well, but I wanted to try out these PowerGrip clamps since they are variable tension in response to thermal expansion/contraction, and I don't plan on removing this hose any time soon since it's a bear to get to in that I have to remove the inner fender liner.
So to nutshell, don't use Wittek tower clamps for the 5/8" heater hose connection, at the very least not flimsy repro ones, and the PowerGrip clamps really are amazing!
1979 Trans Am W72 400/4-Speed WS6 - Starlight Black Hardtop
  #344
Old 03-11-2024, 02:21 PM
Verdoro 68's Avatar
The Wittek tower clamps are pretty finicky. I do a little prep to them before I install and I'm super careful when I clamp them down usually using vice grips to keep them straight. Even then I always have extra because some just don't hold. Hadn't heard of the PowerGrip clamps. They look pretty easy!
Ken
  #345
Old 03-11-2024, 06:31 PM
Drag Star Le Mans's Avatar
I put Holley Retro bright headlights in my 73 Formula and 69 GTO. They are spendy at $200 each but well worth it in you night drive your old Pontiac. Before and after of the Formula.
ID:	630252   Click image for larger version
ID:	630253   Click image for larger version
ID:	630254   Click image for larger version
DragStarLeMans
The Following 3 Users Say Thank You to Drag Star Le Mans For This Useful Post:
  #346
Old 03-11-2024, 09:19 PM
65 Lamnas's Avatar
Are you using factory wiring or do you have relays?
  #347
Old 03-11-2024, 10:45 PM
GtoFM's Avatar
GtoFM GtoFM is offline
Removed LH exhaust manifold to access mini starter. Connected battery cables and tested rotation. Plan to compare compression pressure of each cylinder. If good, will replace worn cam and HFT lifters and move on. If bad, will consider rebuild of numbers matching spare '64 engine.
  #348
Old 03-12-2024, 12:46 AM
Simple plug and play.
DragStarLeMans
The Following User Says Thank You to Drag Star Le Mans For This Useful Post:
  #349
Old 03-12-2024, 09:18 AM
FirebirdHank's Avatar
Cleaned up the G8 with a clay bar. Didn't find any new chips or scratches so that made me feel pretty good.
  #350
Old 03-12-2024, 07:53 PM
form74's Avatar
form74 form74 is offline
Picked up the new motor for the Formula 😀
74 Formula
3 inch exhaust with x-pipe
Quadrajet done by Cliff
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
The Following 2 Users Say Thank You to form74 For This Useful Post:
  #351
Old 03-12-2024, 08:05 PM
67drake's Avatar
67drake 67drake is online now
No fair! Need details.
13.95 @ 102.1 on street tires @ 4055lbs.
  #352
Old 03-12-2024, 09:55 PM
fyrffytr1's Avatar
fyrffytr1 fyrffytr1 is online now
Let's see. First, I took my boat to a local shop to have some small holes in the aluminum hull welded, then I moved the GTO from my shop up to my garage so I could put my 50 Streamliner in the shop to put the intake/ exhaust manifolds and cooling system back in it.
The pollen is terrible right now, so I won't be taking the Goat out for a couple weeks to a month, if then. I had to move the boat to get to the 50.
  #353
Old 03-13-2024, 09:08 AM
form74's Avatar
400 block 30 over with a Stroker kit to make it a 461
E-heads 87 D port
Rpm intake
Roller cam
74 Formula
3:42 gears
12.075 @ 112.70
12.092 @ 112.43
12.128 @ 111.71
The Following 3 Users Say Thank You to form74 For This Useful Post:
  #354
Old 03-13-2024, 11:33 AM
67drake's Avatar
E-heads 87 D port
Rpm intake
Roller cam
Ah, the 11’s are calling!
  #355
Old 03-13-2024, 02:33 PM
triathlonx13's Avatar
Thumbs up
WOW - Really a big difference!
  #356
Old 03-13-2024, 04:34 PM
Picked up my glide.
The Following User Says Thank You to triathlonx13 For This Useful Post:
  #357
Old 03-13-2024, 05:23 PM
tom s tom s is online now
Pulled a oil sample from the new engine.Will start taking it off the run stand tomorrow.Tom
  #358
Old 03-13-2024, 09:31 PM
65 Lamnas's Avatar
Still on the TH400. Got the case saver installed but f**ked up the intermediate pressure plate, and had to get another one. Painted the pump red for an additional 10HP. Looks like there was a rear thrust issue
ID:	630349   Click image for larger version
ID:	630350   Click image for larger version
The Following User Says Thank You to 65 Lamnas For This Useful Post:
  #359
Old 03-14-2024, 03:18 PM
Tempest's Avatar
Tempest Tempest is offline
Default fun with 3D printing
a friend of mine made me some custom inserts for my Rally 2s (for my 58 wagon project)
I may add some clear epoxy resin to coat them with for a smooth glossy finish
ID:	630372   Click image for larger version
ID:	630373   Click image for larger version
The Following 2 Users Say Thank You to Tempest For This Useful Post:
  #360
Old 03-14-2024, 07:29 PM
65 Lamnas's Avatar
Scored a decent set of Cal Custom VCs that will polish up nicely....IMO the best-looking retro valve covers.
The same guy has a couple of OEM aluminum intakes (one NOS)and a couple sets of 7F6 heads for sale...He's advertising on FB under Pontiac Pickers Classified group, if anyone is interested...his name is Marty and in St. Louis area
