My 66 GTO has been repainted a couple of times over the years (first time in 1988 when I was in high school), and I didn't realize that part of the hood scoop insert is supposed to be black. Can someone tell me if it's flat black, gloss or semi gloss?
Thanks, Importsmasher
Scott Baggiore 66 GTO convertible 389/4 speed (parents bought new) 73 Firebird Formula 400/4 speed 74 GTO 455/4 speed 74 Grand Am |
Not gloss.
I can't decide between semi, flat or matte. I never can tell. Edit: I just walked out and looked; would say not flat, either. K
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 Last edited by Keith Seymore; 02-18-2024 at 10:24 AM. |
The Following User Says Thank You to Keith Seymore For This Useful Post: | ||
Agree this black is NOT gloss or flat.
I say it’s the term seen often on these cars ….. 60 degree black or semi black. The most important thing on the 65,66,67 hood scoop is the black in the inner ribs. Drives me nuts that so many of these repainted cars people do not go back and paint the black.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
The Following User Says Thank You to 60sstuff For This Useful Post: | ||
![]() Quote:
Thanks for the input! Importsmasher
The Following User Says Thank You to importsmasher For This Useful Post: | ||
Nice photo of the Ruth Boehm '66:
'63 LeMans Convertible '63 Grand Prix '65 GTO - original, unrestored, Dad was original owner, 5000 original mile Royal Pontiac factory racer '74 Chevelle - original owner, 9.85 @ 136 mph besthttp://www.superchevy.com/features/s...hevy-chevelle/ My Pontiac Story: http://forums.maxperformanceinc.com/...d.php?t=560524 "Intro from an old Assembly Plant Guy":http://67-72chevytrucks.com/vboard/s...d.php?t=342926 |
Any info on how the factory painted the insert? Was it done after body color or prior? Try to wrap my mind around mass production and details like this one.
![]() Quote:
Good question. I painted the black on a few back in the 80’s and it was a little time consuming.
I have a NOS scoop and can add some pics when I next get a chance for that. It is red oxide primer with the scoop "Air Inlet" section already blacked out. Paul
The Following User Says Thank You to GTO.PAUL For This Useful Post: | ||
![]() Quote:
I would suggest they painted the black first, then masked the black (using a reusable mylar or aluminum shield) to paint body color over the top. We did some vehicle two tones that way, where the center (inset) secondary color was painted first, taped over, and then the primary body color painted. K
Body colored inserts just scream repaint.
Greg Reid Palmetto, Georgia |
[wiseguy] Whattabout the ones painted Starlight Black?
![]() Pls don't kill me, still needs less gloss |
Well yeah, Starlight doesn't 'scream' repaint...just whispers it.. lol
My original paint ‘67 for comparison.
1999 WS6 Formula, 1 of 175 1967 GTO Linden Green 4 spd, A/C, survivor 1967 Lemans convt 1967 Firebird 400 bench seat, deluxe interior, auto 1965 GTO 462, KRE unported D-port heads, Bullet 234/244 cam, th400, tight 10" converter, 3.73 gears, 87 octane, 3440 lbs. empty,1.59 60ft, 7.159@95.33 (1/8), a real daily driver, been totaled, rolled 3 times, hit a tree airborne. 1961 Catalina 2 door htp 1960 Ventura 4 door htp wife's car 1960 B'ville 2 door htp 1960 Catalina Wagon wife's car too |
The Following 3 Users Say Thank You to Ducks Goat For This Useful Post: | ||
I knew I had one showing the paint process.
Factory red oxide primer that someone was prepping for a color. Obviously the semi gloss Black was applied first. I would assume some type of a firm mask was temporarily pushed into the inner ribbed portion and then body color was applied.
For mass production it would be faster/cheaper to paint black and then block off the openings for body color application, than to apply body color and later mask the openings for black out.
The Following User Says Thank You to 400 4spd. For This Useful Post: | ||
Here are the pics from the NOS '65-'67 GTO hood scoop I have. Was it all in primer and then the black was sprayed in the scoop area with some kind of mask on the outside or was the black sprayed into the scoop (no primer under the black) and then a mask was placed into the scoop and the primer applied to the outside? From here I can believe that a mask was placed into the scoop area and the body color was applied over the primer. Just had to make sure the mask in the scoop was not covering any primer on the edges of the scoop opening or one would end up with body color, then a primer line and finally the black scoop. Who was there to know for sure? Paul
Just like covering the chrome valve covers and painting the engine. Every now and then, a little overspray on the chrome. Definitely a line on the dip stick bracket between the bolt and the dip stick. Who was there to know for sure?
![]() "Bill"! |
This photo of Ducks says a lot.
Red primer showing through the black.
