looking to buy a reverse back up switch for a Muncie m 20 tranny .or where can i buy one
For what car?
![]() Quote:
This switch is on the steering column, near the base. I'm pretty sure Ames has them. This switch is actuated by the back drive linkage.
![]() Quote:
not sure what you mean about the back drive linkage. do u have a photo |
![]() Quote:
https://forums.maxperformanceinc.com...d.php?t=870388 Often missing due to header fitment problems or not included during an auto to manual swap. It is a series of rods that operate when the shift lever is moved into reverse. Engages the reverse lights via a switch in the base of the steering column. Also works with the reverse lock out function to lock the car in reverse when the ignition is turned to the lock position.
Peter 1974 Trans Am, 400 4-speed, 3.42 rear. ![]() |
The Following User Says Thank You to pontiacstogo For This Useful Post: | ||
![]() Quote:
have that all in place .just want to confirm is the switch at the tranny or under the steering column |
Here is a pic of a Factory 1970 4 speed column. Switch is what you see on it . This comes on when car is in reverse AND Key is able to come out once engine is off. Its only a 2 pin connector. To do a conversion correctly you need a bunch of backdrive linkage And this switch and connectors for it. You can use an auto harness by just using the 2 wires for reverse that are on the combo neutral safety switch, and replace switch with smaller std switch with reverse only.
Neutral safety is accomplished by the clutch switch. This column is Hanging upside down by the lever that moves this switch and hooks to the backdrive.
![]() Quote:
yes i have this same switch ,but can not seem to see any wire for this .how does it look like
Not sure about earlier years but pink and green in later.
1977 Trans Am 400/4speed (swap) Brian |
i think i found it ,but mine is orange and pink
Double check it. I just found my 72 diagram and it shows pink/blk and lt green.
i checked again i see orange and pink will take a photo and post
