Old 06-16-2023, 02:00 PM
Verdoro 68's Avatar
Transmission decals are in and look good.
ID:	614288   Click image for larger version
ID:	614289   Click image for larger version
ID:	614290   Click image for larger version
Ken
  #242
Old 06-19-2023, 11:13 PM
Verdoro 68's Avatar
Received the PN code '71 455HO automatic stickers today. These are laminated like the manual stickers. I freaked out for a minute because I noticed the line under "DO NOT REMOVE CAPS" extended beyond the edge of the decal. I thought I made an error in my file, but it looks like something the printing company did. I reached out requesting that they print a new batch without the error. Glad it wasn't my fault.
Otherwise, they look pretty good. A little different from the manual version, but so was the original I referenced.
Ken
  #243
Old 07-03-2023, 04:35 PM
Verdoro 68's Avatar
Finally got the test batch of '68-'69 compressor decals in. These are done on brushed aluminum vinyl with a gloss UV coating and came out pretty nice.
I've been looking into aluminum asset tags which would allow stamping the mysterious codes, but I haven't been able to find a place that will do them in a large size, in two colors and in small batches so this is the next best thing.
This batch all uses the same code number. Current repros don't have a code on them (and have the wrong logo and fonts! see ) so I figured it was better to have a code than none at all.
While not 100% authentic because of the material and stamping, IMO these are a way better option than what's out there. I did the art for the '66 labels a few weeks ago and may have a few of those made too. One thing I'm not sure about is the brushed grain. It's vertical on these. It's hard to tell what direction it ran - and if it was even consistent - back in the day.
As a reminder, the current repro:
Test batch:
ID:	615321   Click image for larger version
ID:	615323   Click image for larger version
Ken
  #244
Old 07-04-2023, 12:53 PM
Cammer-6 Cammer-6 is offline
Ken is there any reason why you couldnt stamp that number yourself?
A roller stamp or flat stamp would work. Scan the original numbers and engrave,
make a positive from that as a stamp.
Everything comes and goes
Pleasure moves on too early
And trouble leaves too slow
  #245
Old 07-05-2023, 01:17 AM
Verdoro 68's Avatar
Possibly. I’ve been assuming this material wouldn’t stamp since it’s mylar, but maybe I’ll give it a try.
Ken
  #246
Old 07-05-2023, 09:29 AM
Shiny Shiny is offline
Finally got the test batch of '68-'69 compressor decals in. ....
These are exceptional. Wow.*
  #247
Old 07-05-2023, 10:15 AM
may need to add heat to the stamp with a layer of felt under it
As you well know practice makes perfect
  #248
Old 07-14-2023, 09:12 PM
Verdoro 68's Avatar
I had a lot of initial interest in the a/c decals, but surprisingly haven't had any takers on the small batch I ran. Maybe they'd do better without a pre-printed code. Every original example I've seen has a different code and I'm not sure if they were model specific.
I got a set of letter punches to try on the a/c decals. It's not going to work. First, as individual number stamps it's extremely difficult to line them up and space them nicely. I'm going need a different tool if I'm going to stamp them. Second, the mylar material is too soft for stamps. They work, but they work too well and the stamp is pretty deep. So, I'll keep hunting for a better solution.
Anyway, some good news. I finally got a batch of the '71 455 HO automatic emissions decals I'm happy with. It took a lot of hand holding with the printer and I'm sure they had some eye rolling on their side with how picky I was being. Funny since the manual decals weren't an issue.
The existing 455HO automatic repro isn't quite as egregious as the manual version, but there was still some opportunity for improvement. Notice the carburetor screw adjustment says "in park" on the existing repro and the fonts are wrong. At least the graphics aren't cut off.
Here's an original:
ID:	616046   Click image for larger version
ID:	616047   Click image for larger version
ID:	616048   Click image for larger version
ID:	616050   Click image for larger version
Ken
  #249
Old 07-15-2023, 11:13 AM
for stamping numbers warm the stamps and put hard felt under the item you want to stamp
2x2 wood with a slot routered out to press fit stamping dies into it
  #250
Old 08-24-2023, 06:07 PM
teaser pics of the artwork I did about 20 yrs ago for a few air cleaners
The Following 2 Users Say Thank You to Cammer-6 For This Useful Post:
  #251
Old 01-18-2024, 05:00 PM
Verdoro 68's Avatar
Work on this project slowed as I started a new full time job last fall, so I haven't been promoting these much, but I'm still getting a few orders a week from eBay and Etsy. I had some sizable orders from a few well known restoration shops which was super cool.
Top sellers are the '68 emissions decals, '71 455HO emissions and '64-'66 coolant waterslides. I've had pretty good feedback on the air cleaner kits as well, but they haven't been as big of a seller as I thought. They're also pretty high effort to assemble, so honestly, I'd rather sell more stickers. Ames expressed some interest in carrying some of these decals so we'll see where that goes.
I did a few variants for guys in the community that previously haven't had a reproduction for their car. I recently did a variant of the Frigidaire a/c decal with for '69 Firebirds and a '68 wagon tire pressure decal. After doing a decal for Wade Congdon's dual quad RAV, I had a request to do some more custom decals from a few other Ram Air V guys
Most of my effort lately has gone into completely recreating the '67-'68 Firebird convert full size spare jack instructions which aren't reproduced. I put off doing jacking instructions because I knew they'd be a high level of work. I lost count of the hours I have into these but I think they're shaping up nicely. Next up is a test to see how they work as waterslides since they're so large. Thanks to RAIJohn for all the help on these.
Those illustrations were sooo time consuming!
ID:	626742   Click image for larger version
Name:	wagon tire pressure.jpg
ID:	626743   Click image for larger version
ID:	626746   Click image for larger version
ID:	626748   Click image for larger version
Ken
The Following 5 Users Say Thank You to Verdoro 68 For This Useful Post:
  #252
Old 01-20-2024, 04:49 PM
Verdoro 68's Avatar
Finished a few prototypes of the '67/'68 FB convert jack waterslides this morning.
I'm happy with the way these came out! I left a 1/16" of clear decal around them to emulate the factory application. The waterslide paper only takes 30 seconds or a minute to release the print from the backing. It's relatively durable stuff as far as the application goes. I was worried about tearing it since it's so large, but it wasn't an issue. Microfiber works well for applying these things and smoothing air bubbles. The decal is still wet in the pics below so you'll see some bubbles.
Gonna send a few test decals out to my helpers.
My graphics are much more crisp compared to the repro '68 GTO jack instructions. Not to mention the repro has the wrong corner radius and wrong fonts. I might have to tackle the one for '68 GTO next for my own benefit.
ID:	626859   Click image for larger version
ID:	626860   Click image for larger version
ID:	626861   Click image for larger version
ID:	626862   Click image for larger version
Ken
  #253
Old 01-20-2024, 06:22 PM
tempest1964's Avatar
Nice job!
  #254
Old 01-20-2024, 09:14 PM
bluejudge bluejudge is offline
Nice work, are you able to do the door VIN sticker for the 70 GTO’s. I was looking to get that for my car, they sell the sticker but do not add the VIN number as far as I know. Thanks, Marc.
  #255
Old 01-20-2024, 09:25 PM
Verdoro 68's Avatar
I haven’t gone down that path yet, but I think the folks at ECS can do one with the VIN.
https://ecs-automotive-concepts.mysh...72-gm-vehicles
Ken
  #256
Held for Ransom's Avatar
I believe ECS Automotive Concepts does. Contact to confirm ('73-up does).
https://ecsauto.com/collections/gm-decals
So long, farewell.
  #257
Old 01-23-2024, 12:37 AM
Verdoro 68's Avatar
I felt motivated after outputting the '67-68 convert jack instructions so I ordered a bunch more repro decals from Ames to work from.
The '73-'74 Super Duty valve cover repro decal uses the wrong fonts and has the incorrect number of dashes compared to the original. No one asked for these, but it seemed relatively easy to make a more correct version for a cool car. Not quite as easy as I thought, but I'm down the path now.
Existing repro
Original
I'm still refining the fonts and the spacing. It's not quite right yet. I had ot do some reverse engineering and make a grid and space things out based off the hash marks and dotted lines. In case anyone was wondering, there are 92 vertical hash marks and 48 horizontal dashes
I went scouring for more examples of original SD455 decals, but they're few and far between. If anyone has a clear shot of an original, I'd love another example.
Originals look to have been slightly embossed. I'll have to some research to see if I could make that happen. Otherwise, the metallic material I found for the A/C compressor decals would work great and be a higher quality improvement over the existing repro.
Work in progress new art...
ID:	626984   Click image for larger version
ID:	626985   Click image for larger version
ID:	626987   Click image for larger version
Ken
The Following 6 Users Say Thank You to Verdoro 68 For This Useful Post:
  #258
Old 01-23-2024, 07:30 PM
RA1John RA1John is offline
Outstanding work as always Ken.
Your graphics skills and attention to details are quite impressive.
Thanks for your patience and persistence on the '67-'68 Firebird conv. full size spare label.
Can't believe no one has reproduced this one until now.
John
'68 Firebird Ram Air 4-spd Conv.
John 14:6
Semper Fi
  #259
Old 01-24-2024, 04:54 PM
Verdoro 68's Avatar
I appreciate all the collaboration on this one! Couldn't have done it without your help collecting examples. Let me know how the samples work out and if they need any further tweaking.
Regarding the SD valve cover decals, I've been shopping for a place that can do embossed metallic decals that can withstand underhood heat and have come up empty so far. I can get brushed metallic that's heat resistant and actual brushed aluminum labels ($$$), but no one seems to do embossing of a material suitable for underhood use. The hunt continues.
Ken
  #260
Old 02-02-2024, 09:56 AM
MDSHARK81 MDSHARK81 is offline
I have a 71 Trans am, 4 speed, with AC. I’d be interested in a set of any decals you make for my car. Especially the emissions decal for engine bay!! and air cleaner.
