Old 10-20-2023, 04:38 PM
tom s tom s is offline
Default 76 TA front and rear glass installation
Has anyone here actually installed new F&R glass in their TA?Have a friend that has one with no glass and need info how to install.Tom
Old 10-20-2023, 04:42 PM
OG68 OG68 is offline
Rust Replace has what he needs. My wife and I installed the windshield and rear glass in my 68 with their products and advice. .
Great support too!
https://www.rustreplace.com/home/1967-1981-firebird
2007 Cadillac SRX
Old 10-21-2023, 05:34 AM
Trevor78 Trevor78 is offline
Do you mean how to add the sealant or perhaps how the trim and clips go around the edges?
Old 10-21-2023, 07:00 AM
They want to put in new glass and have only the car and the glass.Have nothing else.Tom n
Old 10-21-2023, 10:04 AM
78w72 78w72 is offline
I have installed rear glass on a 72 firebird & watched/helped a pro install the front on 3 2nd gens. The rear was pretty simple, it uses the tape type seal with added 3m window weld in a tube around the edges to ensure a water tight seal. basically just marked out the center with masking tape and made sure the spacers were installed along the bottom & laid it in.
The front was a little more involved, the installer made a "V" cut on the end of teh tube & when applied it made a ~1" tall bead of the 3m sealant, with the special primer applied to the glass & window channel it was just laid in place with the lower supports installed & nothing else was done besides a little trimming of the sealant that oozed through a couple spots inside.
If they have never installed front/rear glass before I suggest paying a pro to do it, its worth the minimal price to ensure a good leak free install & usually comes with a warranty for the work... or check with local body shops for who they use, the guy I use does work on the side & only charged $75 for the front (+ cost of glass) about 10-12 years ago, more recently it went up to $100 but he provides the sealant.
There are some youtube videos showing front/rear glass installs too if they want to see how its done before attempting themselves.
