Looking for measurements for 66 driverws outside rear view mirror
I've checked the archives and didn't find anything because the photos were not supported. Does anyone have the measurements so that I can install mine.
I would have been happy to measure it for you,
but you couldn't even be bothered to respond the last time I answered your questions. When Bart admonished you for just how inconsiderate you are, I chalked it up to 'maybe he had a bad day'. Nope, he was right. You're only here to leech off of us. Call GM. Ask for Customer Support. |
The Following User Says Thank You to 242177P For This Useful Post: | ||
Sorry that you feel that way. Maybe you don't know what is going on in other people's lives.
So you think you're the only person that has
troubles? Other members have gone through tough times, none of them pulled an Arby. If you honestly find that you're so overwhelmed that you can't even respond after soliciting info, maybe you ought not to be wrenching. PS- Couldn't help but notice you made time for me *now*. Weird. |
I could have sworn I had a template someone in this forum provided, but I'll be d__mned if I can find it. I know this attached pic is not the detail you need, but if may give you a starting point.
Fort Worth/Dallas TX area 1966 GTO Fontaine Blue 389 CID Carter AFB Muncie 4 speed (orginally an automatic car) |
Thanks for the response. I just drilled the holes this morning from some on another forum that supplied the dimensions. the front hole was easy drilling since it was the original factory hole covered with an all over skim coat and paint. What are the chances?
best anyway
bondo over a hole is just asking for trouble
Everything comes and goes Pleasure moves on too early And trouble leaves too slow |
If I offer sound advice to anyone on the 65-66-67 GTO’s, all I expect is a two second Thank You, since they did find the time to get on this site.
1) 65 GTO Survivor. 43,440 Original Miles. “Factory” Mayfair Maize Paint with Black Pinstripe, Black Cordova Top, Black Interior, OEM Numbers Matching Powertrain. Purchased from the Lady that bought it new. Baltimore Built (11A). 2) 66 GTO Survivor. “Factory” Cameo Ivory Paint with Red Pinstripe, Red Interior. OEM Numbers Matching Powertrain. Tri-Power (OEM Vacuum Linkage), Automatic "YR" code (1759 Produced). Fremont Built (01B), with the Rare 614 Option. |
The Following User Says Thank You to 60sstuff For This Useful Post: | ||
