I was wondering if I could get some input from the Pontiac Engine gurus out there. I have a Pontiac 400 RamAir service block (What I was told) . The block has been magnifluxed and is in excellent unmolested condition. I was hoping I could get some help with Idenetification. Pictures are attached.
Thanks! |
Born Feb 22 1972
Its missing the third ( upper ) motor mount bolt hole lug for some reason on drivers side could be a SR for a year prior that doesnt need that full lug like a 1969 RA IV Going to need a pic of the part number on the back of the block pics of full lug and a part number
If your not at the table you're on the menu A man who falls for everything stands for nothing. Last edited by Formulas; 12-17-2023 at 10:10 AM. |
Pontiac service blocks came fitted with pistons , there was no other way to get a new block.
The RAIII 4 bolt blocks where the same as the RA4 blocks, but the RA4 blocks would have been fitted with TRW Forged pistons where as the RAIII motors would have had cast. I hope you did not pay extra for a supposed RA4 block when like I said, a 4 bolt is a 4 bolt. Did you get the pistons with the purchase of that block like you should have?
For some unknown reason, Pontiac would cut or grind off the upper motor mount boss on the ram air service blocks. I had a NOS one that this had been done to also. If I'm not mistaken, this has been covered here on this site before.
I believe the deal was that Since these post 1969 cast replacement blocks ( yours being 1972) where cast with 5 motor mount pads on each side ( to work in the 2nd gen F body cars ) that upper one had to be ground or machined off to work in the pre 1970 cars.
This also shows that the RA blocks and the post 1970 455 HO blocks where really nothing special other then being fitted with the nodular iron 4 bolt caps , and of course however they then needed to be machined.
It's definitely an Service Replacement block and it appears that it will make a great foundation for a future build.
While NOS SR blocks were fitted assemblies and included pistons, this block appears to have been previously used, so who knows where the original pistons could be. It was certainly created from a typical 481988 400 casting produced on February 22, 1972. The ledge behind the number 8 cylinder will likely have that ground away and the intended block number stamped in place. You're likely to find a "9799914" or "9799915" on it. Can you share a picture of that? |
Rock I don’t know that the block was ever used since there’s no lines or marks that a Distributor was ever down in that hole.
![]() Quote:
Steve, you might be right. I guess we'll have to see what the OP comes back with.
I was basing my comments mostly on the attached photo, which appears to show (a slight amount of) the typical corrosion around the coolant passage and the gasket shadows where the timing cover would reside. |
The Following User Says Thank You to Rocky Rotella For This Useful Post: | ||
![]() Quote:
![]() Quote:
That 3 digit 979 code was used from 68 thru 70.
The 9792506 indicates that this particular SR block was intended for a late-1967, 1968, or early-1969 Ram Air application. That then corresponds with the engine mount boss being removed.
While the block itself offers no real performance advantage over any other 400 block of the era, it’s pretty valuable to the GTO and Firebird restoration crowd. And the 4-bolt caps are desirable if you plan to crank up the horsepower. Can you confirm if it’s NOS or used? |
Please guys go ahead and add your thoughts and input here but heres my thoughts on the Pontiac world of SR blocks.
Pontiac really hurt themselves with grinding/handstamping and doing a poor job at it. Anybody can order custom stamp sets off the internet relatively cheap. Now I know people are going to say 4 bolt mains proves its a raiv block etc. But doesn't THEPARTSPLACE sell reproduction 4 bolt main cap sets that match the originals? Seems to me a person can buy a run of the mill block and with some time and machine work turn it into a "rare" SR block cheaply and easily. I personally have a few Pontiac block stampings saved in my Gallery file for comparison to one's that come for sale. How does one prove an SR block to be legit? |
![]() Quote:
Here’s a tip off to the repro iron main cap deal.
Your not just dropping a set of them on a block and using the stock dowel pins in the block. Because things will not line up. So to use the repro caps they are installed with oversized dowel pins and then of course the blocks main bores get honed or bored . Also 4 bolt mains does not prove in anyway that a 400 block is a of RA lineage . The 360 hp motors that where ordered with a 4 speed over the baseline manual 3 speed got 4 bolt mains also. If you then go and look at the big 3.250” main motors like the 421, they all had 4 bolt mains as far as I know, and none of these ever had a RA prefix to there name, just HO. All the 428 motors other then the 1969 motors that where born with the # 46 castings heads where all 4 bolt mains also, and all of these motors never had a RA prefix, just HO for the top of the line 428s with the 376 or 390 hp rating.
Wernher Von Braun warned before his retirement from NASA back in 1972, that the next world war would be against the ETs! And he was not talking about 1/8 or 1/4 mile ETs! 1) 1940s 100% silver 4 cup tea server set. Two dry rotted 14 x 10 Micky Thompson slicks. 1) un-mailed in gift coupon from a 1972 box of corn flakes. Two pairs of brown leather flip flops, never seen more then 2 mph. Education is what your left with once you forget things! Last edited by steve25; 07-25-2023 at 07:06 AM. |
![]() Quote:
But it's still interesting to follow along. |
This block is the previous in sequence to a block which was for sale and sold on this forum a few months ago. 88043 and 88044. Same casting date too.
So if your information is correct about the sequence # isnt that a Red flag? Unless this block came from the same shop/collection?
![]() Quote:
The Following User Says Thank You to Dragncar For This Useful Post: | ||
