Can I get away with running this on the street with pump gas 91 octane?
Shouldn’t be a problem.
The Following User Says Thank You to b-man For This Useful Post: | ||
My .060 over 400 with KRE heads runs just fine on 91 octane
The Following User Says Thank You to max 93 For This Useful Post: | ||
I use thecalculator onSD Performance site.
With zero deck height 7 cc valve reliefs total .039 head gasket. I get 10.3:1. With aluminum heads that should be a plenty safe deal. Of course all the details make a diffetence...
1977 Black Trans Am 180 HP Auto, essentially base model T/A. I'm the original owner, purchased May 7, 1977. Shut it off Shut it off Buddy, I just shut your Prius down... ![]() |
The Following User Says Thank You to 77 TRASHCAN For This Useful Post: | ||
Actually don’t assume that there 74 CCs, confirm that yourself!
The Following 2 Users Say Thank You to steve25 For This Useful Post: | ||
Please tell us you're gonna run a snotty solid flat tappet with deep rear gears and a muncie .... buzz it to the moon!
Should be no problem at all running that combination on 91 octane pump gas, if it is cammed correctly
1978 Trans Am Pump Gas 461 Stroker |
The Following User Says Thank You to TransAm 474 For This Useful Post: | ||
![]() Quote:
30 over 400 with 74 cc 290 KRE d ports. 10.14 cr. H-O 744 HL cam. Slight detonation on 87, none on 91. 30* total mechanical advance.
Frank M. 75 Firebird 68 Firebird 400 RAIII 66 Chevy II 461 Pontiac in AZ |
Butler Hydraulic Roller BP8023SP
Ok so what’s your initial on top of your mechanical 30 degrees?
That camshaft should work very well with your combination on 91 octane ... I would start conservative with timing, probably 30° total. The chamber design in those Kauffman heads usually don't require much more than that. Also, make sure the fuel side is up to par, whether it is a Carb or EFI, and you should be good to go as long as you keep coolant temp in check.
Thanks guys! It's going to the machine shop!!
Let me rephrase that. 30 total; mechanical + initial, no vacuum..
The Following 2 Users Say Thank You to tooski For This Useful Post: | ||
You should be able to pee in the tank and be fine with that cam.
You also need vacuum advance, at least if you want the best power, efficiency and throttle response for "normal" driving. With that combo about 10-12 degrees would be plenty....IMHO....
The Following 4 Users Say Thank You to Cliff R For This Useful Post: | ||
