Old 05-26-2023, 01:26 AM
Mister Pontiac's Avatar
Mister Pontiac Mister Pontiac is offline
Default 74 (& up?) Adjustable Pedals
I'm trying to determine a little more about the adjustable brake/gas pedal option. I recently acquired a set from a fellow PY'er and am planning to install them on my 74 Bonneville so my 5'2" wife can drive without putting my knees into the dashboard.
I have the factory brochure on them, and the writing seems to allude to the fact that 74 was the first year these were available on all the B body platforms. I have seen an old thread where someone has a 75 with the pedals as well, so we have at least a two year production availability on them.
They are a very elegant design utilizing worm gears and (essentially) a speedometer cable to turn the gears for pedal movement. The adjustablilty seems very robust as well with several pedal positions to be chosen.
A couple questions:
1. Does anyone know the last year this option was available? I would assume 75/76.
2. Does anyone know how many cars may have been equipped? I would assume a very low production number.
Any info or insight, personal experience with them, etc... would be appreciated.
Thanks!
Eric "Todd" Mitten
'74 Bonneville 4dr Sedan (455/TH400/2.93 open)
'72 LeMans GT (455/M-13/3.23 [8.5"] posi)
'71 GTO Hardtop (400/TH400/3.07 12 bolt posi)
‘71 GTO Convertible (455HO/TH400/3.23 posi)
'67 GTO Coupe (455/ST-10/2.93 posi)
'67 Tempest Wagon (428/TH400/2.56 posi)
Deuteronomy 8:3
Old 05-26-2023, 08:17 AM
Stuart's Avatar
Stuart Stuart is offline
I don't know anything about the option but it appears you're correct on the year - it wasn't in the 1973 accessorizer brochure but appeared in the 1974 and 1975 editions, and was listed in the 1976 general brochure. http://oldcarbrochures.org/United%20...ure/index.html Of course they downsized the cars in 1977 so they were a totally different chassis and body.
Old 05-26-2023, 05:32 PM
Thanks Stuart. Those images look very familiar. I have an original dealer brochure on them. Very neat!
Thanks for checking on the 76 catalogue too. I assumed they would be in there, but wasn't sure. And as you said, 77 was a whole new ballgame, and likely the end of the one piece bench seat thus negating most of the need for the adjustable pedals.
If anyone has a car with the pedals installed, I would appreciate hearing about your experience. Also, if you have any pictures of the installation, it would be helpful, though I can probably figure out the install regardless. I'm simply interested in how the factory routed a couple items.
ID:	613283   Click image for larger version
ID:	613284   Click image for larger version
Eric "Todd" Mitten
Deuteronomy 8:3
